Undetermined Coefficients / Variation of Parameters
The discussion centers on solving the ordinary differential equation (ODE) y'' + 4y = 4sec(2t) using the method of undetermined coefficients. The user attempted a particular solution of the form Yp = Acos(2t) + Bsin(2t), which was unsuccessful. It was concluded that the method of undetermined coefficients is not applicable in this case because the right-hand side, 4sec(2t), does not correspond to a particular solution of any homogeneous linear differential equation with constant coefficients.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with the method of undetermined coefficients
  • Knowledge of variation of parameters
  • Concept of homogeneous linear differential equations with constant coefficients
  • Study the method of variation of parameters in detail
  • Learn about the conditions for applying the method of undetermined coefficients
  • Explore the characteristics of non-homogeneous ODEs
  • Investigate the solutions of ODEs involving trigonometric functions like sec(2t)
Students and professionals in mathematics, particularly those focused on differential equations, as well as educators teaching ODE methods and techniques.
amcavoy
I know how to solve the following ODE with variation of parameters:
[tex]y''+4y=4\sec{\left(2t\right)}.[/tex]
Is there any way to solve this with undetermined coefficients? So far I have tried Yp=Acos(2t)+Bsin(2t), but that didn't work.
Thanks for the help.
Now that I try different methods, it seems that reduction of order won't work. At least, I come up with a function I can't integrate:
Y=vyh
v'=u
[tex]u=\frac{2c_1t-2c_2\ln{\left(\cos{2t}\right)}}{c_1\cos{2t}+c_2\sin{2t}}[/tex]
The method of undetermined coefficients is applicable only if the RHS of the non-homogeneous equation is itself a particular solution of some homogeneous linear differential equation with constant coefficients. Since Sec(2t) is not such a solution, this method is not applicable.
