Angular momentum and coordinates
In summary, the joint eigenstate of \hat{L^{2}} and \hat{L_{z}} is denoted as |l, m> and it depends on the spherical coordinates θ and ∅. This is because the wavefunction, represented by the bra-ket, is a complex number that can be expressed in terms of the spherical angles. By finding simultaneous eigenstates, we can work with these eigenstates and operators in a more aesthetically pleasing manner using spherical coordinates.
M. next
382
let us denote the joint eigenstate of [itex]\hat{L^{2}}[/itex]and [itex]\hat{L_{z}}[/itex] by ll,m> and we know that if we are in spherical coordinates,
[itex]\hat{L^{2}}[/itex] and [itex]\hat{L_{z}}[/itex] depend on θ and ∅, so we denote the joint eigenstate by: <θ∅l l,m>.. why?
The bra-ket is a complex number, the value of the wavefunction (singled out by a choice of l and a choice of m) in terms of the spherical angles, i.e. coordinate variables.
are you looking for simultaneous eigenstate.then L2 and Lz commute so that it is possible to find simultaneous eigenstates.
We denote it that way because we've chosen to project the eigenstates and the operators in terms of [itex]\theta[/itex] and [itex]\phi[/itex]. We could equally express the eigenstates [itex]|l, m \rangle[/itex] and the operators [itex]\hat{L^{2}}[/itex] and [itex]\hat{L_{z}}[/itex] in terms of Cartesian coordinates. We express the eigenstates in the standard Cartesian basis as [itex]\langle x, y, z|l, m \rangle[/itex]. They aren't as pretty to work with, which is why we choose spherical coordinates to express spherical harmonics.
Thanks jmcelve. It is clear now.
Related to Angular momentum and coordinates
1. What is angular momentum?
Angular momentum is a physical quantity that describes the rotation or spin of an object around an axis. It is a vector quantity, meaning it has both magnitude and direction, and it is conserved in a closed system where there are no external torques acting on the object.
2. How is angular momentum related to coordinates?
The angular momentum of an object is dependent on its position and velocity, which are described by coordinates in a specific reference frame. The direction of the angular momentum vector is perpendicular to the plane formed by the position and velocity vectors, and its magnitude is proportional to the product of the mass, velocity, and distance from the axis of rotation.
3. What is the difference between angular momentum and linear momentum?
Linear momentum describes the motion of an object in a straight line, while angular momentum describes the rotational motion of an object. Linear momentum is a vector quantity with direction in the direction of motion, while angular momentum is a vector quantity with direction perpendicular to the plane of rotation.
4. How is angular momentum conserved?
Angular momentum is conserved in a closed system where there are no external torques acting on the object. This means that the total angular momentum before and after an interaction or event will be the same, as long as there are no external forces or torques acting on the object.
5. How is angular momentum used in physics?
Angular momentum is used in many areas of physics, including mechanics, quantum mechanics, and astrophysics. It is a fundamental concept in understanding the behavior of rotating objects and systems, and it has practical applications in fields such as engineering, astronomy, and robotics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
