rowdy3
- 33
Find the following.
∫ (56t^(5/2) + 18t^(7/2))dt.
I did
(2/7)56 t^(7/2) + (2/9)18t^(9/2) + c =
16t^(7/2) + 4t^(9/2) + c
I did
An antiderivative is the inverse operation of a derivative. It is a mathematical function that, when differentiated, produces the original function. It is also known as the indefinite integral.
To find an antiderivative, you must use the rules of integration. These include the power rule, substitution, and integration by parts. You can also use tables of integrals or computer software to find antiderivatives.
You can check your antiderivative by differentiating it. If the result is the original function, then you have done it correctly. You can also compare your answer with known antiderivatives or use a graphing calculator to verify your solution.
Yes, you can have a constant, also known as the constant of integration, in your antiderivative. This is because when you differentiate a constant, it becomes zero. So, adding a constant to your antiderivative does not change the result when differentiated.
Yes, there are a few common mistakes to avoid when finding antiderivatives. These include forgetting the constant of integration, using the power rule incorrectly, and not applying the chain rule correctly. It is also important to watch out for algebraic errors and to simplify your final answer as much as possible.
