How Do You Calculate the Half-Life of Thorium-232?
In summary, the problem asked for the half life of Thorium-232, given the initial mass and the rate of decay. The student converted the mass into number of particles and used the first equation to find the decay constant. From that, the second equation was used to obtain a value for the half life, which was then converted to years. The student encountered some discrepancies in their calculations, but eventually arrived at the correct answer by properly converting between units of mass and particles.
sam400
Basically, the problem asked for the half life of Thorium-232, given the initial mass and the rate of decay.
\begin{equation}
\frac{dN}{dt} = 4100 \frac{ \alpha }{s}
\end{equation}
initial mass = 1.0 g
\begin{equation} \frac{dN}{dt} = \lambda N \end{equation}
\begin{equation} t_h = \frac{ \ln 2}{\lambda} \end{equation}
[/B]
Started off converting the mass into number of particles:
\begin{equation} 1.0 g \frac{1.0 mol}{232 g} 6.022*10^{23} molecule/mol \end{equation}
That gave me N, which was ##2.59*10^{21}## molecules. From that, I guess I could use the first equation to find the decay constant, so I got ##1.58*10^{-18}##
From that, the second equation can be used to obtain a value for the half life, which then gave me the value, but I had to make sure to convert to years next. After using the proper conversion factor, I got a value of ##8.1* 10^{11}## years, which is different from the literature value of 1.4*10^{10}. I have a feeling I shouldn't have done what I did to find the decay constant, but I'm not entirely sure what other approach I can take, since I'm still new to nuclear. Thanks in advance.Edit; I just realized that the method in my original post does give me the value found in literature. However, if I try to do it with a slightly different method, ie. convert the decay rate into grams/second, I seem to be getting the wrong answer.
\begin{equation} 4100 \frac{\alpha}{s} \frac{ 6.64E-27 kg}{ 1 \alpha} \frac{1 g}{10^{-3} kg} = 2.72E-20 g/s \end{equation}
This gives me a different decay constant value entirely, which then gives me the value I originally stated, so I think my original method is still wrong, or I made a conversion error.
sam400 said:
dN/dt
is in units of what?
sam400 said:
2.72E−20g/s
dN/dt is in alpha particles per second, and the second is grams per second
... and, g/s would be how many alpha/s?
to convert g/s to alpha/s, I would have to at first take 1 mol/alpha mass in g then multiply by avogadro. This would mean that the conversion I did in the second part was incorrect. However, doing the method described here also gives me a different decay constant value.
... and, how many alphas/s per how many thorium atoms?
when I used that method, I do get the right answer, but for the alternate method, which is converting alpha/s to g/s, and leaving the thorium to just 1.0 g, I get the wrong answer. The conversion I used for alpha/s to g/s is after the edit on my original post. Since one method works and the other doesn't, I am guessing either I made a conversion error on the second method, or the process itself was incorrect and I got lucky in the first method.
When you're working with half-life, you're counting particles, not their masses. If half-life is discussed as N1/2/N0, and people say, "Gee after one half-life, there's only half the material left," it's natural to think that half the mass has disappeared. Half the original parent isotope mass has disappeared, but that has been replaced in the sample with whatever "daughter" product is the result of the decay --- for an alpha decay process, this is a measureable mass loss, 232 to 228, but the product is still present in the sample.
so converting it into mass as I did it the second time would be like saying the sample is gaining or losing mass, when in reality the mass just stays constant, it's the particles that's change, which would mean everything has to be converted to number of particles, and the other way would just give an incorrect answer?
Yes, with the qualification that some wise guy is going to throw masses of this or that at you on tests, homework, quizzes, or give you a "mass half-life" and ask for a "population half-life," and all permutations/perversions and combinations of the above. Radioactive half-lives are all in terms of populations.
Likes sam400
What is half life?
Half life is the amount of time it takes for half of a radioactive substance to decay into a stable form. It is a measure of the rate at which a substance decays.
How is half life calculated?
The equation for calculating half life is: t1/2 = (ln 2) / λ where t1/2 is the half life, ln 2 is the natural logarithm of 2, and λ is the decay constant of the substance.
What is the relationship between half life and decay constant?
The decay constant (λ) is directly proportional to the half life (t1/2). This means that as the decay constant increases, the half life decreases and vice versa.
Can half life be used to predict the amount of a substance remaining?
Yes, the amount of a substance remaining can be predicted using the equation: N = N0 * (1/2)n where N is the remaining amount, N0 is the initial amount, and n is the number of half lives that have passed.
What factors can affect the half life of a substance?
The half life of a substance can be affected by external factors such as temperature, pressure, and chemical reactions. It can also be affected by internal factors such as the size of the substance and its chemical structure.
