Do black holes swallow dark matter?
In summary, dark matter exhibits gravitational effects and is expected to be consumed by black holes along with normal matter. However, due to its low density and lack of friction, it is difficult to observe the effects of dark matter being consumed by black holes. While there have been attempts to observe annihilating dark matter, it remains speculative at best. Additionally, the density of dark matter near the galactic center is expected to be larger, but this has not yet been confirmed through observations. Overall, dark matter does not interact with normal matter and would pass through a black hole, making it difficult to distinguish from normal matter after being consumed.
  • #36
Saul said:
1) How does one keep the dark matter from clustering around the super massive object? It appears dark matter works in one direction only. (i.e. It is invoked when required to explain anomalous motion and must cluster to explain the anomalous motion. It does not cluster around super massive black holes.)
It's nearly frictionless, so it has no mechanism to cluster significantly around a supermassive black hole.
Saul said:
2) See thread in astrophysics section "Dark matter on the ropes?" I agree the explanation for the anomalous motion is not MOND.
It's not just about anomalous motion. Today, a wide body of mutually-corroborating evidence all points towards dark matter.
Space news on Phys.org
  • #37
The cuspy halo problem is that dark matter density should increase around mass centers such as super massive black holes. If the super massive object is a classical BH it will continue to grow if dark matter in falls into it.
Yes or No? If No explain why it does not.
The paper I quoted has no mechanism to avoid dark matter clustering and super massive black hole uncontrolled growth. Dark matter must interact with matter via gravity. The authors state a maximum density for dark matter in the vicinity of super massive black hole.
What you are missing when you state dark matter does not form cusps, is if it does not form cusps it will also not form halos about galaxies.
As there appears to be no physical explanation for why dark matter does not form cusps, the hypothesis that super massive black hole is a physical object that can evolve and change as opposed to a classic BH appears to be viable. My point is there is observation evidence of ejection from the massive object. (I will start a separate thread to discuss.)
As to whether dark matter does or does not exist, the thread "Dark Matter on the Ropes?" includes specific observations (the observed change in rotational velocity of spiral galaxies with radius and the number of satellite galaxies that form around a spiral galaxy for example.) which are not in agreement with the dark matter hypothesis. The correct hypothesis must explain all observations. The fact that the dark matter hypothesis does not explain all observation is indication that something is fundamentally incorrect with the hypothesis.
From the standpoint of solving the problem it is better to have no explanation than an incorrect hypothesis.
As I stated MOND also cannot explain the observations.
http://en.wikipedia.org/wiki/Cuspy_halo_problem
The cuspy halo problem arises from cosmological simulations that seem to indicate cold dark matter would form cuspy distributions — that is, increasing sharply to a high value at a central point — in the most dense areas of the universe. This would imply that the center of our galaxy, for example, should exhibit a higher dark-matter density than other areas. However, it seems rather that the centers of these galaxies likely have no cusp in the dark-matter distribution at all.
This remains an intractable problem. Speculation that the distribution of baryonic matter may somehow displace cold dark matter in the dense cores of spiral galaxies has not been substantiated by any plausible explanation or computer simulation.
  • #38
There are two problems with your presumptions:
1. Simulations aren't very good at modeling baryonic matter, and the "cuspy halo problem" is critically dependent upon the baryon matter model.
2. Because we currently don't know how dark matter interacts, simulations ignore any interactions that dark matter does have. For instance, a small annihilation cross section may easily solve the "cuspy halo problem" because dark matter annihilations could prevent high density regions from forming.
It is not reasonable to throw out dark matter when simply implementing expected non-idealities of dark matter may well solve the "cuspy halo problem".
  • #39
Dark matter survives these issues when it is resistant to accretion by black holes [links already provided]. It strongly suggests dark matter either does not exist [unlikely], or has properties not yet understood. The fact that eddington [and mass] limits are obeyed in all suspected black holes observed to date is not insignificant.
  • #40
The are two problems with what you are proposing. The first is why would dark matter annihilate itself? The second is when the universe was formed there would be high density and all the dark matter would annihilate itself.
  • #41
To explain the observations the Dark matter hypothesis requires a smart particle that changes it properties to resolve the paradoxes. The dark matter hypothesis appears to be in trouble.
What is required is a mechanism to stop dark matter from forming cusps in the center of galaxies. The dark matter will in fall into the super massive object if dark matter exists, however, if the density of the dark matter particles at the center of the galaxy is less the in fall of dark matter into the SMBH will not cause the galaxy to collapse on itself, in the period of the universe's life to date. Eventually, the galaxy will however collapse on itself. Reducing the density of dark matter only delays the collapse.
This paper hypotheses that dark matter is a smart particle "BDM" that changes its properties to resolve the paradox. At high density BDM has no mass and moves at the speed of light due to quantum interactions of BDM to BDM particle . At low density BDM is a massive particle.
What is required is a dark matter halo that reaches a maximum density, hence the need for the smart Dark matter particle. i.e. bimodal dark matter "BDM".
http://arxiv.org/PS_cache/arxiv/pdf/0908/0908.0571v1.pdf
BDM Dark Matter: CDM with a core profile and a free streaming scale
We present a new dark matter model BDM which is an hybrid between hot dark matter HDM and cold dark matter CDM, in which the BDM particles behave as HDM above the energy scale Ec and as CDM below this scale. Evolution of structure formation is similar to that of CDM model but BDM predicts a nonvanishing free streaming _fs scale and a inner galaxy core radius rcore, both quantities determined in terms of a single parameter Ec, which corresponds to the phase transition energy scale of the subjacent elementary particle model. For energies above Ec or for a scale factor a smaller then ac, with a < ac < aeq, the particles are massless and _ redshifts as radiation. However, once the energy becomes E ≤ Ec or a > ac then the BDM particles acquire a large mass through a non perturbative mechanism, as baryons do, and _ redshifts as matter with the particles having a vanishing velocity. Typical energies are Ec = O(10 − 100)eV giving a _fs ∝ E−4/3 c < _Mpc and Mfs ∝ E−4 c < _ 109M⊙. A _fs 6= 0, rcore 6= 0 help to resolve some of the shortcomings of CDM such as overabundance substructure in CDM halos and numerical fit to rotation curves in dwarf spheroidal and LSB galaxies. Finally, our BDM model and the phase transition scale Ec can be derived from particle physics.
The model simply consist of particles that at high energy densities are massless relativistic particles with a velocity of light, v = c, but at low densities they acquire a large mass, due to nonperturbative quantum field effects, and become non relativistic with a vanishing (small) dispersion velocity. We will name this type of dark matter BDM, from bound states dark matter. The name is motivated by the particle physics model, discussed in section III, but we would like to stress out that the cosmological properties of BDM do not depend on this particle model but on the different behavior of the BDM particles. The phase transition energy density is defined pc ≡ E4 c and its value can be determined theoretical by the particle physics model or phenomenological by consistency with the cosmological data.
A large number of candidates have been proposed for DM of which cold dark matter (CDM) has been the most popular. CDM model has been successful on large scales in explaining structure formation in the early universe as well as abundances of galaxy clusters [1]. However, CDM predicts steeply cusped density profiles and causing a large fraction of haloes to survive as substructure inside larger haloes [4, 5]. These characteristics of CDM haloes, however, seem to disagree with a number of observations. The number of sub-haloes around a typical Milky Way galaxy, as identified by satellite galaxies, is an order of magnitude smaller than predicted by CDM [6] and the observed rotation curves for dwarf spheriodal dSph and low surface brightness (LSB) galaxies seem to indicate that their dark matter haloes have constant density cores [7, 8] instead of steep cusps as predicted by the NFW profile. Low surface brightness galaxies are diffuse, low luminosity systems, with a total mass believed to be dominated by their host dark matter halos [9]. Assuming that LSB galaxies are in dynamical equilibrium, the stars act as tracers of the gravitational potential, and can therefore be used as a probe of the dark matter density profile [10]. Much better fits to dSph and LSB observations are found when using a cored halo model [11]. Cored halos have a mass-density that remains at an approximately constant value towards the center.
  • #42
Because dark matter is weakly-interacting, it is unlikely to have the same matter/anti-matter asymmetry that baryonic matter has (the primordial asymmetry in baryonic matter/anti-matter was very small, but nearly all of it annihilated due to the fast reaction time of baryonic matter).
A majority of dark matter models, as a result, predict annihilation to occur (albeit slowly).
The expansion rate dampens the annihilation. Given a particular model, it isn't that difficult to compute the expected abundance of dark matter. Yes, there is a parameter space where it all self-annihilates (a region of parameter space that is therefore excluded). But there is also substantial parameter space where there is self annihilation, but enough of it survives in the early universe for it to be as abundant as we observe today.
  • #43
A majority of dark matter models, as a result, predict annihilation to occur (albeit slowly).The expansion rate dampens the annihilation. Given a particular model, it isn't that difficult to compute the expected abundance of dark matter. Yes, there is a parameter space where it all self-annihilates (a region of parameter space that is therefore excluded). But there is also substantial parameter space where there is self annihilation, but enough of it survives in the early universe for it to be as abundant as we observe today.
I do not see why dark matter would self annihilate when its density exceeds 250 Solar masses/pc^3. (The point is 250 solar masses/pc^3 is not a high density.) Think of baryonic matter in a star or a planet. Does it self annihilate?
However, setting aside the physics question of why dark matter would self annihilate at low densities, the self annihilation hypothesis appears to fail as the density of dark matter in the early universe would be higher than 250 Solar masses/pc^3, therefore all of the dark matter would have self annihilated.
The author's solution is as noted above to hypothesis bimodal dark matter where dark matter is hot dark matter (Moves at the speed of light) for densities that are greater than 250 solar masses/pc^3 and cold dark matter when the density of dark matter is less than 250 solar masses/pc^3.
http://arxiv.org/PS_cache/arxiv/pdf/1002/1002.0553v1.pdf
An upper limit to the central density of dark matter haloes from consistency with the presence of massive central black holes
Since reaching runaway accretion would strongly distort the host dark matter halo, the inferences of QSO black holes in this mass range lead to an upper limit on the central dark matter densities of their host haloes of po (Dark matter density) < 250 solar masses/pc^3. This limit scales inversely with the assumed central black hole mass. However, thinking of dark matter profiles as universal across galactic populations, as cosmological studies imply, we obtain a firm upper limit for the central density of dark matter in such structures.
  • #44
http://arxiv.org/PS_cache/arxiv/pdf/1001/1001.4691v3.pdf
If dark matter self annihilated when the dark matter density was at the modest 250 solar masses/pc^3 the self annihilation would have affected the CMB.
CMB data constraint on self-annihilation of dark matter particles
Recently, self-annihilation of dark matter particles is proposed to explain the “WMAP Haze” and excess of energetic positrons and electrons in ATIC and PAMELA results. If self-annihilation of dark matter occurs around the recombination of cosmic plasma, energy release from self-annihilation of dark matter delays the recombination, and hence affects CMB anisotropy. By using the recent CMB data, we have investigated the self-annihilation of dark matter particles. In this investigation, we do not found statistically significant evidence, and impose an upper bound on hvi/m. The upcoming data from Planck surveyor and the Fermi Gamma-ray telescope will allow us to break some of parameter degeneracy and improve constraints on self-annihilation of dark matter particles.
By analyzing the recent CMB data, we have constrained the self-annihilation of dark matter particles. We do not find statistically significant evidence on self-annihilation, and impose an upper bound on Fdm < 0.7314 at 95% confidence level. Due to the parameter degeneracy (i.e. Fdm hvi/m) in our analysis, significant self-annihilation is still possible, provided a dark matter particle is very massive (i.e. ≫1GeV). Therefore, a dark matter particle should be quite massive (i.e. m≫1GeV), if the excess of energetic positrons and electrons in PAMELA/ATIC data is attributed to self-annihilation of dark matter particles. Self-annihilation of dark matter particles leads to high level of gamma-ray emission from the region around the Galactic halo. Therefore, Fermi Gamma-ray telescope will allow us to break some of parameter degeneracy and impose independent constraints on self-annihilation of dark matter. Using the upcoming Planck data as well as Fermi Gammaray telescope data, we shall be able to impose important constraints on self-annihilation properties of dark matter particles.
  • #45
Baryonic matter in a star is basically all normal matter. Obviously it can't annihilate. But due to the weak interactions of dark matter, those annihilations in the early universe would generally have been rather slow, leaving nearly equal parts matter and anti-matter around (if not exactly equal, as the asymmetry that produced the overabundance of normal matter for baryons wouldn't work for dark matter).
Anyway, if you want to see how this is computed, you can look in most any cosmology textbook about how the primordial neutrino abundance is computed. The calculation for most WIMP candidates is similar, just with a different set of parameters (mass, interaction strength, interaction turnoff temperature, etc.), and without the confounding factor of neutron/proton interactions. The physical process for self interaction becomes slow compared to the expansion rate before they all annihilate, and you're left with lots of matter/anti-matter laying around.
The point is, however, that the annihilation interaction never disappears entirely. It just becomes a low-probability interaction. But when you collect lots of dark matter in the same location, the number of close encounters between dark matter particles grows dramatically, and thus so does the self-annihilation rate.
This density is about 1.7*10^9 times the current critical density. Thus the dark matter would have been around this dense at around a redshift of z=2000, when the universe was a mere 133,000 years old. So the annihilation rate only needs to be slow enough that it would have taken longer than a few hundred thousand years or so to annihilate at those densities (possibly less, depending: the primordial abundance could have been very very high).
But if it takes a few hundred thousand years to annihilate, that should be well within the range to solve the cuspy halo problem.
  • #46
Dark Matter Self Annihilation is invoked to:
1) Limit the density of dark matter in the vicinity of super massive black holes (SMBH), to limit the growth of SMBHs. A classical BH has no mechanism to eject matter/mass/energy. (Hawkings radiation besides being undetected is not a theoretical solution.) Dark matter or matter that in falls into the SMBH will cause the SMBH to continue to gain mass with time. That is not observed. SMBH have a maximum mass of around 3 x 10^9 solar masses.
2) To limit the density of dark matter in the center of galaxies to explain the galaxy inner core rotational problem. (Simulations show the galaxy rotation velocity in the inner core of the galaxy should vary as 1/r where observations indicated the rotational velocity of galaxies varies as r in the inner core of galaxies.)
3) Explain the cluster intergalactic gas heating problem. (The temperature of intergalactic gas in the center of clusters is roughly 10^7 k. There are two problems. What heats the cluster intergalactic gas? And why does the cluster intergalactic gas not cool? There is also a third interesting problem, what is the source of the cluster intergalactic gas. The mass of the cluster intergalactic gas is roughly the same as the mass of all stars in the cluster.)
To prove or disprove the hypothesis that Dark Matter self annihilates one can look for dark matter self annihilation products.
The detection of dark matter self annihilation products is currently negative.
http://arxiv.org/PS_cache/arxiv/pdf/1002/1002.2239v4.pdf
Constraints on Dark Matter Annihilation in Clusters of Galaxies with the Fermi Large Area Telescope
Nearby clusters and groups of galaxies are potentially bright sources of high-energy gamma-ray emission resulting from the pair-annihilation of dark matter particles. However, no significant gamma-ray emission has been detected so far from clusters in the first 11 months of observations with the Fermi Large Area Telescope. We interpret this non-detection in terms of constraints on dark matter particle properties. In particular for leptonic annihilation final states and particle masses greater than 200 GeV, gamma-ray emission from inverse Compton scattering of CMB photons is expected to dominate the dark matter annihilation signal from clusters, and our gamma-ray limits exclude large regions of the parameter space that would give a good fit to the recent anomalous Pamela and Fermi-LAT electron-positron measurements. We also present constraints on the annihilation of more standard dark matter candidates, such as the lightest neutralino of supersymmetric models. The constraints are particularly strong when including the fact that clusters are known to contain substructure at least on galaxy scales, increasing the expected gamma-ray flux by a factor of 5 over a smooth-halo assumption. We also explore the effect of uncertainties in cluster dark matter density profiles, finding a systematic uncertainty in the constraints of roughly a factor of two, but similar overall conclusions. In this work, we focus on deriving limits on dark matter models; a more general consideration of the Fermi-LAT data on clusters and clusters as gamma-ray sources is forthcoming.
Clusters of galaxies are the most massive collapsed objects in the Universe and are very dark matter dominated, making them potentially bright sources of gamma-ray emission from dark matter annihilation. No significant gamma-ray emission has been detected from clusters of galaxies in the first 11 months of Fermi-LAT survey mode observations [10]. In this paper, we explored the implications of the non-detection of clusters by Fermi-LAT in terms of constraints on models of dark matter annihilation. In particular, we focused on the six best candidate clusters and groups of galaxies in the context of searches for gamma-ray emission from dark matter pair annihilation [2] after excluding from the sample clusters which host bright central AGN or lie close to the Galactic plane. We analyzed the Fermi-LAT data to derive upper limits on the gamma-ray flux from dark matter annihilation in specific models, self-consistently incorporating the expected spectral shape for a given particle mass and annihilation final state. We conservatively assume only gamma-ray emission from dark matter annihilation when interpreting the ...
  • #47
Dark matter if it exists, should theoretically interact with itself and should form clusters.
If dark matter forms clusters the clusters should show evidence of self annihilation. (See comment above as to why dark matter self annihilation is theoretically required to explain observations, via the dark matter hypothesis.)
http://www.nature.com/nature/journal/v433/n7024/abs/nature03270.html
Earth-mass dark-matter haloes as the first structures in the early Universe
The Universe was nearly smooth and homogeneous before a redshift of z = 100, about 20 million years after the Big Bang1. After this epoch, the tiny fluctuations imprinted upon the matter distribution during the initial expansion began to collapse because of gravity. The properties of these fluctuations depend on the unknown nature of dark matter2, 3, 4, the determination of which is one of the biggest challenges in present-day science5, 6, 7. Here we report supercomputer simulations of the concordance cosmological model, which assumes neutralino dark matter (at present the preferred candidate), and find that the first objects to form are numerous Earth-mass dark-matter haloes about as large as the Solar System. They are stable against gravitational disruption, even within the central regions of the Milky Way. We expect over 10^15 to survive within the Galactic halo, with one passing through the Solar System every few thousand years. The nearest structures should be among the brightest sources of γ-rays (from particle–particle annihilation).
  • #48
Given that our observations of dark matter annihilation are in their infancy, it's not really much of a surprise that we have yet to definitively detect such annihilation products. It will be a little while before we begin to explore an interesting fraction of the available dark matter parameter space.
  • #49
Dark matter interacts about as often as centegenarians have torrid extramarital affairs. We have all manner of very sensitive devices designed to detect dark matter annihilations, and it remains very shy.
  • #50
Ich said:
Huh?
Nothing passes right through a black hole.
There are theoretical speculations that propose just such a thing. The material coming out the other end of the black hole is called a white hole!
White Holes
http://www.astronomycafe.net/qadir/q1470.html
  • Cosmology
