Easy convergent subsequence question.
In summary, to determine if the sequence {x_k} is bounded, we need to show that both the x and y coordinates are bounded. The range of arctan(k^2+1) is between -pi/2 and pi/2, and the range of sin(k) is between -1 and 1. However, we also need to consider the norm of the sequence, which in this case is the square root of the sum of the squares of the x and y coordinates. By showing that this norm has an upper bound, we can conclude that the sequence {x_k} is bounded.
pantin
Consider the sequence {x_k} = {(arctan(k^2+1),sink)} in R^2. Is there a convergent
subsequence? Justify your answer.
Every bounded sequence in R^n has a convergent subsequence.
To show {x_k} is bounded: The range of arctan(k^2+1) is (-pi/2, pi/2) and the range of sin(k) is [-1,1].
A sequence is bded from above and below if there exist an M and an m both belong to R, such that a_k<=M and a_k>=m for all a_k in the sequence. Here, I want to state let M=1 and m=-1. because they are max and min y coordinate value for {x_k}, is this correct?
No, it's not. But you're close. What you've stated is not the correct definition of a bounded sequence in R^2.
Actually, I think that depends on the precise definition of "bounded" in R2 in your text and, in turn, upon the norm used.
Morphism's point (I think) is that you have shown that the x and y of (x,y) are each bounded. For R2 you must show that |(x,y)|= [itex]\sqrt{x^2+ y^2}[/itex] has an upper bound. That, of course, is easy.
It is also possible to define |(x,y)| as max |x|,|y| as a norm on R2 in which case you are done! Of course, that is not the standard norm.
we just have 2 similar concepts on the text, one is
every bded sequence in R has a convergent subsequence
the second is what I stated before..
every bded sequence in R^n has a convergent subsequence
or should I use the definition of upper and lower bd?
1. What is a convergent subsequence?
A convergent subsequence is a subset of a sequence of numbers that approaches a specific value as the number of terms in the subset increases. In other words, the terms in the subsequence get closer and closer to a limit or endpoint.
2. How do you determine if a sequence has a convergent subsequence?
To determine if a sequence has a convergent subsequence, you need to check if the sequence is bounded. If the sequence is bounded, then it must have a convergent subsequence. However, if the sequence is unbounded, it may or may not have a convergent subsequence.
3. What is the difference between a convergent subsequence and a convergent sequence?
A convergent subsequence is a subset of a sequence, while a convergent sequence is a sequence in its entirety. In a convergent subsequence, only a portion of the terms approach a limit, while in a convergent sequence, all of the terms approach a limit.
4. Can a sequence have more than one convergent subsequence?
Yes, a sequence can have multiple convergent subsequences as long as the sequence is bounded. Each convergent subsequence may approach a different limit or endpoint.
5. Is a convergent subsequence always unique?
No, a convergent subsequence may not be unique. A sequence can have multiple bounded subsequences that approach the same limit or endpoint, resulting in multiple convergent subsequences.
