jpo
- 47
Bead slides on a wire (no friction) shaped as [itex]r = r(\theta) [/itex] in the Oxy plane. The Oxy plane and the constraining wire rotate about Oz with [itex]\omega = const[/itex]
[itex]r, \theta[/itex] is the rotating polar frame; [itex]r, \phi[/itex] is the stationary frame.
Find the trajectory [itex]r = r(\phi)[/itex] in the stationary frame.
Minimize the time of motion
[itex]T = \frac{1}{\omega} \int_{\pi/2}^{\phi_1} \sqrt{\frac{r'^2+r^2}{r}} d\phi[/itex]
in polar coordinates
The trajectory [itex]r = r(\phi)[/itex] in the inertial frame is unknown; In the rotating frame the trajectory is known: it is [itex]r = r(\theta) [/itex]. Then the integral in the rotating frame becomes
[itex]T = \frac{1}{\omega} \int_{0}^{t_1} \sqrt{\frac{\dot{r}^2(\theta)+r^2(\theta) (\dot{\theta}+\omega)^2}{r(\theta)}} dt[/itex],
because
[itex]\phi=\theta+\omega t[/itex] and
[itex]\frac{dr}{d\phi}=\frac{\dot{r}}{\dot{\phi}}=\frac{\dot{\theta}}{\dot{\theta}+\omega}[/itex]
I have tried to write the integral into the rotating polar frame and then enforce the constraint, by substituting [itex]r[/itex] and its derivative through [itex]\theta[/itex] and [itex]\dot{\theta}[/itex]. Then I'll minimize [itex]T[/itex]with Euler-Lagrange
[itex]\frac{\partial J}{\partial\theta}-\frac{d}{dt}\frac{\partial J}{\partial\dot{\theta}}=0[/itex]
Is this correct?
