Find the Distance (Momentum)
  • Thread starter Tom2
  • Tags
    Momentum
In summary, Tom2 believes that the model of firing a gun applies to a thrower, and that the speed of the bullet would be the same with or without friction.
Tom2
You are 60kg and you are holding a 10kg weight as you stand at rest on a frictionless surface. you can throw the weight 5m on ground where there is friction to keep you from moving backwards. How far will the 10kg weight be from you after you throw it on the frictionless surface?
M1V1 + M2V2 = 0
Total momentum of the system (you + weight) after the throw must be the same as it was before so it will be 0. [/B]
M1 = 60kg
M2= 10kg
V1 = ?
V2 = ?
Please help! Thanks!
There isn't really enough information. To answer this you will need to make some assumptions about how arms work.
Which of the following do you think will be approximately the same in the two cases:
  • the force exerted by the muscles
  • the distance over which the force is exerted (as far as the muscles are concerned)
  • the power delivered by the muscles
  • the time for which the power is delivered
M1V1 + M2V2 = 0
Yes.
M1 = 60kg
M2= 10kg
V1 = ?
V2 = ?
Try solving for V1 in terms of V2. Assume you the throw the weight horizontally.
Hi Tom2,
Just had a private chat with PhanthomJay. His model is like firing a gun. That's rather different because the speed of the bullet would be the same with or without friction. For that to apply to a thrower, the thrower would have to absorb the recoil initially by flexing the body, so as to avoid any horizontal force on the feet until the mass has been released (with and without friction).
I regard that as the least realistic of three models (the other two being constant force and constant power), but if the question is not intended to be much advanced then it may be what the questioner has in mind.
The constant force model can also be analysed without calculus, but I regard constant power as the most realistic.
To find the distance that the weight will be from you after you throw it on the frictionless surface, we need to use the equation for momentum, which is:
p = mv
Where p is the momentum, m is the mass, and v is the velocity.
We know that the total momentum of the system (you + weight) must be 0 after the throw, so we can set up the following equation:
(60kg)(0m/s) + (10kg)(v2) = 0
Solving for v2, we get:
v2 = 0m/s
This means that the weight will have a velocity of 0m/s after the throw on the frictionless surface. Since the weight is not moving, it will remain 5m away from you, the same distance as when you threw it.
What is the formula for finding the distance in a momentum calculation?
The formula for finding the distance in a momentum calculation is distance = momentum/mass.
Can you explain the concept of momentum and why it is important in science?
Momentum is a measure of an object's motion. It is calculated by multiplying an object's mass by its velocity. In science, momentum is important because it helps us understand how objects move and interact with each other.
How is momentum related to Newton's Laws of Motion?
Momentum is related to Newton's Laws of Motion, specifically the second law, which states that the force applied to an object is equal to the rate of change of its momentum. This means that the greater an object's momentum, the more force is needed to change its motion.
Is momentum a conserved quantity?
Yes, momentum is a conserved quantity, which means that it cannot be created or destroyed. In a closed system (no external forces acting), the total momentum before an event is equal to the total momentum after the event.
How does mass affect the distance in a momentum calculation?
The greater the mass of an object, the smaller the distance it will travel for a given momentum. This is because the formula for distance in a momentum calculation includes mass in the denominator, meaning that as mass increases, distance decreases.
