Gauss hypergeometric series
In summary: Substituting this into our original series, we get:\sum_{n=0}^{\infty} \frac{1}{(\frac{2}{3})_n} \frac{(z^3/9)^n}{n!} = \sum_{n=0}^{\infty} \frac{(n+\frac{3}{2})_n}{(\frac{3}{2})_n} \frac{(z^3/9)^n}{
Ted123
446
Express [tex]\sum_{n=0}^{\infty} \frac{1}{(\frac{2}{3})_n} \frac{(z^3/9)^n}{n!}[/tex] in terms of the Gauss hypergeometric series.
The Gauss hypergeometric series has 3 parameters a,b,c: [tex]_2 F_1 (a,b;c;z) = \sum_{n=0}^{\infty} \frac{(a)_n(b)_n}{(c)_n}\frac{z^n}{n!}[/tex]
I can express it as a hypergeometric series: [itex]_0 F_1 (-,-;\frac{2}{3};\frac{z^3}{9})[/itex] but my question is specific in saying it wants it expressed in terms of the Gauss hypergeometric series which has 3 parameters, not 1. I'm stuck as how to do this?
Hello,
Thank you for your question. Expressing the given series in terms of the Gauss hypergeometric series can be done by rewriting the given series using the properties of the Pochhammer symbol (also known as the rising factorial).
First, let's rewrite the given series:
\sum_{n=0}^{\infty} \frac{1}{(\frac{2}{3})_n} \frac{(z^3/9)^n}{n!} = \sum_{n=0}^{\infty} \frac{1}{\frac{2}{3}\cdot \frac{5}{3}\cdot \frac{8}{3} \cdots \frac{3n+2}{3}} \frac{(z^3/9)^n}{n!}
Now, using the property (a)_n = \frac{\Gamma(a+n)}{\Gamma(a)} and the fact that \Gamma(a+1) = a\Gamma(a), we can simplify the Pochhammer symbol in the denominator as follows:
\frac{1}{\frac{2}{3}\cdot \frac{5}{3}\cdot \frac{8}{3} \cdots \frac{3n+2}{3}} = \frac{\Gamma(\frac{3}{2}+n)}{\Gamma(\frac{3}{2})} \cdot \frac{\Gamma(\frac{5}{2}+n)}{\Gamma(\frac{5}{2})} \cdot \frac{\Gamma(\frac{8}{2}+n)}{\Gamma(\frac{8}{2})} \cdots \frac{\Gamma(\frac{3n+2}{2}+n)}{\Gamma(\frac{3n+2}{2})}
Now, using the property \Gamma(a+1) = a\Gamma(a), we can write the above expression as:
\frac{1}{\frac{2}{3}\cdot \frac{5}{3}\cdot \frac{8}{3} \cdots \frac{3n+2}{3}} = \frac{\frac{3}{2}+n}{\frac{3}{2}} \cdot \frac{\frac{5}{2}+n}{\frac{5}{2}} \cdot \frac{\frac{8}{2}+n}{\frac{8}{2}} \cdots \
1. What is a Gauss hypergeometric series?
A Gauss hypergeometric series is a type of infinite series that was studied by the mathematician Carl Friedrich Gauss. It is defined as a power series with three parameters, and its terms are given by a specific formula involving factorials.
2. What is the purpose of studying Gauss hypergeometric series?
Gauss hypergeometric series have many applications in mathematics and physics. They can be used to solve differential equations, compute integrals, and study special functions. They also have connections to other areas of mathematics such as number theory and combinatorics.
3. How is a Gauss hypergeometric series different from other infinite series?
One key difference is that a Gauss hypergeometric series has a finite radius of convergence, meaning that it only converges for values of the variable within a certain range. This is unlike other infinite series, such as geometric series, which converge for all values of the variable.
4. Can a Gauss hypergeometric series be evaluated for specific values of the parameters?
Yes, there are certain combinations of parameters for which a Gauss hypergeometric series can be evaluated in closed form. For example, when the parameters are integers, the series reduces to a finite sum. In other cases, the series can be expressed in terms of special functions such as the hypergeometric function.
5. Are there any open problems or unsolved questions related to Gauss hypergeometric series?
Yes, there are still many open problems and ongoing research related to Gauss hypergeometric series. Some of these include finding new closed forms for the series, investigating their properties and connections to other areas of mathematics, and developing efficient algorithms for their computation.
