- #106
- 3,121
- 7,712
The phenomenon described is real, but the wording is misleading:Moretorque said:the engine that makes HP earlier is more powerful at building and maintaining it under load in real world app.
If 2 engines are at the same (low) rpm, and one has more torque than the other, then it necessarily has more power too (hp = rpm * torque / 5252).Moretorque said:more powerful
This is the wording that is the most hurtful. This is not a consequence of a better vs worst engine, it is a consequence of well-match vs mismatch engine/tranny combo.Moretorque said:building and maintaining it under load
If you need a certain amount of power at a certain wheel rpm, you can either increase the engine power at the rpm it is in OR you can change the gear ratio such that engine is at rpm where it already produce more power. From the point of view of the wheel -> same power, same thing.
The transmission modification generally implies more gear ratios, which have other consequences (complexity, cost, weight, more shifting, ...) that can also affects performance (and finance!). Usually, it is a lot easier and cheaper to have a fixed transmission design and to play with the engine. When an engine performs better than another (giving same average hp), all it means is that it is better suited to the drivetrain.
You can do an experience with your own vehicle with a manual gearbox. Drive at certain initial speed and, by being in the appropriate gear that set your engine in its high HP rpm range, give it all you can, shifting upward as you need. You will attain a certain maximum speed while being in your last gear. Why can't it go faster? Because the power needed the fight the aerodynamic resistance is equal to the maximum power of your engine.
Now repeat, starting at the same initial speed, but in your last gear. In theory, you should get to the same maximum speed, since you will have the same maximum power at the same wheel rpm. The only difference should be that it will take a longer time because your initial power is lower (the engine is in its lower power band). But the reality is that you will probably never be able reach the same maximum speed; why? Because at some point, before you can reach your maximum power output, the power produced by the engine at a lower rpm will be equal to the (lower) power produced by the aerodynamic resistance. At this point, the vehicle won't be able to accelerate, hence you will be stuck at that speed forever, never being able to get that maximum power.
Of course, the more power you have in the lower rpm range, the less likely this will happen (or the higher will be your final speed). The point I want to make is the following: Even with your own car, you can see how much a difference a proper gear ratio makes. This is also true with race cars. For example, some race teams will slightly alter the gear ratios depending on the tracks; why? Because, on one track, with one gear ratio, at the big curve before the long straight, the car will be at, say, 80 mph with the engine rpm at slightly lower than its max hp; So the driver snaps it and he gets everything he can out of the car. On the other track the curve is more pronounced and the exit speed is at 60 mph, which would put the engine rpm in its lower range, well under its desired power range. Downshifting is a possibility, but then it puts the engine at the end of its power range; That would make 2 gear changes almost back-to-back. But if he changes the gear ratio for that particular gear, @ 60 mph he will be right at the beginning of its power range and will performs at its best (at least for that particular location on the track).
So you should understand by now that what is important is the average power you get in your usual rpm range that matter, while also being transmitted appropriately by the drivetrain. If you engine needs to go in the low rpm range, you will need more power (or torque) to have better performance. If it doesn't go there, or very briefly, than nobody cares how much power it produces, as long as you have enough to have an adequate acceleration to get to the higher rpms. (Does anyone really care how much power an engine makes at idle?)
Stop thinking in terms of the best engine and the best transmission; Look for the best powertrain.
