How can you derive the effective mass?
In summary, the energy of the band structure is defined in the following form and to obtain this form of the equation, you can manipulate algebraically and solve for the effective mass of the electron. This is only applicable near the minimum or maximum of the band. The effective mass can also be derived using Newton's second law, as explained in a comprehensive lecture on solid state physics by Colorado School of Mines. However, the first equation is not mentioned in this paper. In classical physics, kinetic energy is defined as 1/2mv^2 or p^2/2m, while in quantum mechanics, momentum is represented by p=hbar k.
bluejay27
68
I have seen that the energy of the band structure is defined in the following form. How do you obtain this form of the equation? Additionally, how can you obtain the effect mass of the electron? Do you just manipulate algebraically the equation of the energy of the band structure and solve it for for the m_e*?
In classical physics, kinetic energy is 1/2 mv^2 or p^2/2m.
In QM the momentum p=hbar k...
1. What is effective mass in physics?
Effective mass is a measure of the inertia of a particle in a solid or a crystal lattice. It is a concept used in condensed matter physics to describe the behavior of electrons or other particles in a material. It is defined as the mass of an electron in free space multiplied by a factor that takes into account the effects of the crystal lattice on the electron's motion.
2. How is effective mass calculated?
Effective mass is calculated using the band structure of a material, which is a graph that shows the allowed energy levels for electrons in a crystal lattice. The effective mass is determined by taking the curvature of the band structure at a specific energy level and comparing it to the curvature of the free electron band. The ratio of the two curvatures gives the effective mass.
3. What are the uses of effective mass in physics?
Effective mass is a useful concept in understanding the behavior of electrons and other particles in a material. It is used in various applications such as semiconductor devices, where the effective mass of electrons determines the conductivity of the material. It is also used in the study of optical and electronic properties of materials, as well as in the development of new materials for specific purposes.
4. How does effective mass affect the mobility of electrons?
The effective mass of electrons plays a crucial role in determining their mobility, which is the ability to move freely in a material. A lower effective mass means that the electrons can move more easily, resulting in a higher mobility. This is why materials with a lower effective mass, such as metals, have higher electrical conductivity compared to materials with a higher effective mass, like insulators.
5. How does temperature affect the effective mass of a material?
The effective mass of a material is temperature dependent. As the temperature increases, the crystal lattice of the material vibrates more, causing the effective mass to increase. This is because the increased vibrations make it more difficult for the electrons to move through the lattice, resulting in a higher effective mass. Therefore, the effective mass of a material is not a constant value and can change with temperature.
  • Atomic and Condensed Matter
