Is Amplification same as gain?
In summary, the difference between gain and amplification is that gain is a measurement of the increase or decrease in amplitude of a signal while amplification is the process of increasing or decreasing the amplitude of a signal. Gain is often expressed in dB and can be added together for multiple stages, while amplification is measured using the formula 20 * Log(Vout/Vin) for voltage gain and 10 * Log (Pin/Pout) for power gain.
JJ91
41
Hello,
I can't figure out what's the difference between the two:
Gain - how much the amplitude of the signal was increased/decreased
Amplification - how much the amplitude of the signal was increased/decreased
If we take a basic inverting amplifier circuit:
http://alturl.com/39n78
We can see an amplification of signal by 3 times from 5V to 15V
This is equivalent increase of 300%
300% to dB would mean a gain of 4.77dB according to http://www.lightmachinery.com/percent-to-dB-conversion-calculator.php
Is gain (dB) simply an amplification rate in different units?
Thanks.
First of a gain of 3 from 5V to 15V is not a 300% increase, it's a 200% increase. Yes, the calculator you reference does show that a gain of 3 is 300%, but that's not the same as a 300% increase. A 100% increase would be an increase from 5V to 10V. Second the dB calculator is calculating power increase not voltage increase. Power gain varies as the square of voltage increase. A voltage gain of 3 would have a dB value of 9.54 dB.
Gain is often expressed as dB so the gains of multiple stages of other elements can be added together instead of multiplied or divided. It's not different units, it's a different mathematical operation. For voltage gain you should use the formula 20 * Log(Vout/Vin).
amplification is what is "occurring ... the gain figure quantifies the amount of amplification occurring
skeptic2 said:
...Gain is often expressed as dB so the gains of multiple stages of other elements can be added together instead of multiplied or divided. It's not different units, it's a different mathematical operation. For voltage gain you should use the formula 20 * Log(Vout/Vin).
and to follow on from skeptic2's formula above ...
power gain = 10 * Log (Pin/Pout)
Dave
Super simple, thanks.
Hello,
Thank you for your question. To answer your question simply, yes, amplification and gain are essentially the same thing. Both terms refer to the increase or decrease in amplitude of a signal. However, there are some technical differences between the two terms that are worth noting.
Amplification is a more general term that refers to any increase or decrease in the amplitude of a signal. It can be used to describe the increase in voltage in an electronic circuit or the increase in volume in an audio system. Gain, on the other hand, is a more specific term used in the field of electronics and signal processing. It is a measure of the ratio of output signal to input signal and is usually expressed in decibels (dB). In your example, the gain of the amplifier circuit would be 4.77dB, which means the output signal is 4.77 times larger than the input signal.
In summary, amplification and gain are similar concepts that describe the increase or decrease in amplitude of a signal, but gain is a more specific term used in electronics and is measured in decibels. I hope this helps clarify the difference between the two terms. Let me know if you have any further questions.
Related to Is Amplification same as gain?
1. What is the difference between amplification and gain?
Amplification is the process of increasing the amplitude or strength of a signal, while gain is a measure of the ratio of output to input power. In other words, amplification refers to the physical process of increasing signal strength, while gain is a quantitative measurement of the amount of amplification.
2. Are amplification and gain interchangeable terms?
No, amplification and gain are not interchangeable terms. As mentioned before, amplification refers to the process of increasing signal strength, while gain is a measurement of the amount of amplification. While they are related, they are not the same concept.
3. Can amplification and gain be negative?
Yes, both amplification and gain can be negative. In audio systems, negative amplification is used to decrease the strength of a signal, while negative gain indicates that the output signal is smaller than the input signal. Negative amplification and gain are also commonly used in electrical engineering to describe the attenuation of a signal.
4. Is amplification the same as volume?
No, amplification and volume are not the same. Amplification refers to the increase in signal strength, while volume is a subjective measure of how loud a sound is perceived to be. Volume can be affected by factors such as distance, room acoustics, and individual hearing abilities, whereas amplification is a measurable quantity.
5. How is amplification or gain measured?
Amplification is usually measured in decibels (dB), which is a logarithmic scale that compares the strength of the input signal to the strength of the output signal. Gain is also measured in decibels, but it specifically refers to the ratio of output to input power. Both amplification and gain can also be measured in linear units, such as voltage or current ratios.
  • Electrical Engineering
