Lightest diesel engine known to man
In summary, the conversation discusses the weight differences between diesel and gasoline engines, with diesel engines typically being heavier due to their higher compression ratios. The lightest diesel engine available for a rated output of 1-3 kW is a 2.5kWe Yanmar genset weighing 65kg. However, there are also smaller diesel engines available for modelers. The original poster is looking for a diesel-fueled electricity generator that is as light as possible for outdoor use, but it is unclear what their exact power needs are. They prefer diesel engines for their lower maintenance and higher reliability, but these benefits may not hold true on a very small scale. It is suggested that the poster prioritize their requirements in order to find the best solution.
  • #36
Mech_Engineer said:
However, a diesel will also have more torque than a similar displacement gasoline engine.
"Bmep is a useful measure of torque output. Typical maximum bmep are:
NA gasoline 8-11 bar
Turbo gasoline 12-17 bar
NA diesel 7-9 bar
Turbo diesel 10-12 bar"
Diesel engines typically make more torque than hp, but specific output of both is lower than gas engines.
<h2>1. What is the lightest diesel engine known to man?</h2><p>The lightest diesel engine known to man is the Volkswagen 1.6 liter diesel engine, weighing only 187 pounds.</p><h2>2. How does the weight of the lightest diesel engine compare to other diesel engines?</h2><p>The lightest diesel engine is significantly lighter than other diesel engines, which can weigh up to 500 pounds or more.</p><h2>3. What makes the lightest diesel engine so light?</h2><p>The light weight of the Volkswagen 1.6 liter diesel engine is due to its use of lightweight materials and advanced engineering techniques, such as aluminum alloy components and a compact design.</p><h2>4. What are the benefits of having a light diesel engine?</h2><p>A light diesel engine offers improved fuel efficiency, reduced emissions, and better performance due to its lighter weight. It also allows for a lighter overall vehicle weight, which can improve handling and increase payload capacity.</p><h2>5. Are there any downsides to using the lightest diesel engine?</h2><p>While the lightest diesel engine offers many benefits, it may not be suitable for all applications. It may not have enough power for heavy-duty vehicles or large loads, and its lightweight design may not be as durable as heavier diesel engines.</p>
  • Mechanical Engineering
19K
