Why Does the Majorana Vector Current Vanish?
In summary, you have successfully shown that the Majorana vector current vanishes by using the given equations and rearranging them to obtain the desired result. Your solution is correct and provides a clear explanation of the steps taken.
gasar8
63
I am trying to show that Majorana vector current vanishes. I am following this article and I am trying to get to the very right hand side of eq. (27).
[tex]\psi_M^C = \psi_M,\\ \psi^C_M = C \overline{\psi}_M^T,\\ C^T=-C, \hspace{1cm} C^T\gamma_{\mu}C = -\gamma_{\mu}^T.[/tex]
Vector current is
[tex]\overline{\psi^C}_M \gamma_{\mu} \psi_M^C = C\psi_M^T \gamma_{\mu} C \overline{\psi}_M^T\\
=-\overline{\psi}_M^T C \gamma_{\mu} C \psi_M^T\\
=\overline{\psi}_M^T C^T \gamma_{\mu} C \psi_M^T\\
= -\overline{\psi}_M^T \gamma_{\mu}^T \psi_M^T,
[/tex]
where I switched the order of [itex]\psi_M^T[/itex] and [itex]\overline{\psi}_M^T[/itex] from first to second row and then used the last row of relevant equations to the end result.
Is this correct and enough?
Your solution looks correct and sufficient to show that the Majorana vector current vanishes. However, it may be helpful to provide a brief explanation of your steps and how they lead to the final result. Additionally, you may want to mention any assumptions or definitions that were used in your solution. Overall, your response provides a clear and concise explanation for the forum post.
1. What is a Majorana vector current?
A Majorana vector current is a type of current in particle physics that involves the exchange of a neutral, self-conjugate particle called a Majorana fermion. This current is important in understanding certain physical phenomena, such as neutrinoless double beta decay.
2. How is a Majorana vector current different from other types of currents?
A Majorana vector current is unique because it involves the exchange of a Majorana fermion, which is its own antiparticle. This means that the current is not affected by the presence of other particles or antiparticles, making it more stable and easier to detect.
3. What is the significance of the Majorana vector current in particle physics?
The Majorana vector current plays a crucial role in understanding the nature of neutrinos, which are fundamental particles that have very little mass and interact very weakly with other particles. It also has implications for theories of dark matter and the unification of fundamental forces.
4. How is the Majorana vector current detected in experiments?
The Majorana vector current can be detected through its effects on other particles, such as in neutrinoless double beta decay experiments. It can also be indirectly observed through the violation of certain conservation laws, such as lepton number conservation.
5. Are there any practical applications of the Majorana vector current?
While the Majorana vector current is primarily studied in the context of particle physics, it has potential applications in quantum computing and information processing. The unique properties of Majorana fermions make them promising candidates for creating more stable and robust quantum bits.
