Measuring viscosity with torsion pendulum
In summary, we can calculate the viscosity of the oil by using the damping coefficient and the angular velocity of the disc in a torsion pendulum.
Rosengrip
We have a round disc with radius of 10 cm and mass of 1 kg, suspended on a wire and lying on a thin (1 mm) layer of oil. We torsionally nudge it and we get some info out of it:
At angular velocity of 10 s[tex]^{-1}[/tex] the amplitude is maximal.
At angular velocity of 12 s[tex]^{-1}[/tex] the amplitude is 1/2 of maximal amplitude (is reduced by half)
What's the viscosity of oil?
Torsion pendulum motion equation:
[tex]\phi[/tex]=[tex]\phi[/tex]0 * e^-(beta*t)(cos(w*t) + phase)
beta - coefficient of damping
w- angular velocity
F = -c*v (force, opposing the oscillation of pendulum)
c - coefficient of damping
v - velocity
I was thinking along the lines that first I need to find a dampening cofficient (but I need a force for that) and then I got really lost (dampening increases with angular velocity, it's a bit confusing).
Any point in the right direction would be greatly appreciated.
The Attempt at a SolutionThe damping coefficient (beta) can be calculated by using the following equation:β = F/(mv) where F is the force opposing the oscillation of the pendulum, m is the mass of the disc, and v is the velocity. Since the force is dependent on the viscosity of the oil, we can use the following equation to calculate the viscosity of the oil:μ = F/(Av) where A is the area of the disc and v is the velocity. Using the given information, we can then calculate the viscosity of the oil as follows:At angular velocity of 10 s^{-1}:F = mv*β μ = F/(π*(10 cm)2*10s^{-1}) μ = 1 kg*10s^{-1}*β/(π*100 cm2*10s^{-1}) μ = β/(10π cm2/s) At angular velocity of 12 s^{-1}:F = mv*β/2 μ = F/(π*(10 cm)2*12s^{-1}) μ = 1 kg*12s^{-1}*β/(2*π*100 cm2*12s^{-1}) μ = β/(20π cm2/s) Since the damping coefficient (β) is the same for both angular velocities, we can equate the two equations to solve for β:10π cm2/s = 20π cm2/s β = 10π cm2/s Therefore, the viscosity of the oil is 10π cm2/s.
1. What is a torsion pendulum?
A torsion pendulum is a device used to measure the viscosity of a fluid by observing its oscillation period and amplitude when subjected to a torsion force.
2. How does a torsion pendulum measure viscosity?
A torsion pendulum measures viscosity by twisting a sample of the fluid between two plates, which generates a torque. The resulting oscillation of the pendulum is then used to calculate the viscosity of the fluid.
3. What are the advantages of using a torsion pendulum to measure viscosity?
One advantage of using a torsion pendulum is that it is a simple and relatively inexpensive method compared to other viscosity measurement techniques. It also allows for non-destructive testing of the fluid sample.
4. What types of fluids can be measured with a torsion pendulum?
Torsion pendulums can be used to measure the viscosity of both Newtonian and non-Newtonian fluids. This includes liquids, gels, and even some semi-solids.
5. Are there any limitations to using a torsion pendulum to measure viscosity?
One limitation of using a torsion pendulum is that it is not suitable for high viscosity fluids or fluids with high yield stress. Additionally, the accuracy of the measurements can be affected by factors such as temperature and the presence of impurities in the sample.
