Momentum: Freight cars problem
So in summary, the three freight cars of equal mass traveling at 6.7m/s down a straight track collide with two stationary identical cars, resulting in all five cars being coupled together. If the tracks are frictionless, the speed after the collision will be 4.02m/s [Down].
Sandro Romualdez
Three freight cars of equal mass are coupled together. The freight cars are traveling at 6.7m/s down a straight track when they collide with two more stationary identical cars. If all five cars are coupled together after the collision, then what is their speed if they are on frictionless tracks?
Law of conservation of momentum: p=p' or m1v1+m2v2=m1v1'+m2v2'
From the question I can figure out that
m1 = 3x
m2 = 2x
v1 = 6.7m/s [Down]
v2 = 0m/s
and I need to find vsys'
the msys after the collision will equal 5x
am I right if I use:
m1v1+m2v2=msysvsys'
→ (3x)(6.7m/s [D])+(2x)(0m/s) = 5x(vsys')
→ 20.1x kg·m/s = 5x(vsys')
→ vsys' = 4.02 m/s [D]
and the speed after the collision will be 4.02m/s [Down]?
m1 = 3x
m2 = 2x
v1 = 7.5m/s [Down]
v2 = 0m/s
m1v1+m2v2=msysvsys'
→ (3x)(7.5m/s [D])+(2x)(0m/s) = 5x(vsys')
→ 24.5 kg·m/s = 5x(vsys')
→ vsys' = 4.9 m/s [D]
and the speed after the collision will be 4.9m/s [Down]?
I don't see why you swap from 6.7 to 7.5 for the initial velocity.
Likes Sandro Romualdez
Whoops, my mistake. I changed the speed now and calculated accordingly.
So you should be right when you correct that.
Alright, thank you.
1. What is momentum?
Momentum is a physics concept that refers to the quantity of motion an object has. It is calculated by multiplying an object's mass by its velocity.
2. How is momentum related to freight cars?
In the freight cars problem, momentum is used to determine the force needed to stop a train of connected freight cars. The momentum of the train is transferred through the couplers and brakes to the locomotive, allowing it to come to a stop.
3. What factors affect momentum in the freight cars problem?
The two main factors that affect momentum in the freight cars problem are the mass of the train and its velocity. The greater the mass and velocity, the greater the momentum and the more force is needed to stop the train.
4. How is momentum conserved in the freight cars problem?
In accordance with the law of conservation of momentum, the total momentum of the train before and after the brakes are applied remains the same. This means that the forward momentum of the train is transferred to the locomotive and then dissipated through the braking system.
5. How is momentum used to solve the freight cars problem?
To solve the freight cars problem, the momentum of the train is calculated using the formula p = mv, where p is momentum, m is mass, and v is velocity. This calculated momentum is then used to determine the force needed to bring the train to a stop.
