How to Determine the Coefficient of \(x^{12}y^{24}\) in a Polynomial Expansion?
  • Thread starter tylerc1991
  • Tags
    Theorem
In summary: 9, k_3 = 3 k_1 = 2, k_2 = 0, k_3 = 18 k_1 = 2, k_2 = 3, k_3 = 12 k_1 = 2, k_2 = 6, k_3 = 6 k_1 = 3, k_2 = 0, k_3 = 15 k_1 = 3, k_2 = 3, k_3 = 9 k_1 = 4, k_2 = 0, k_3 = 12 k_1 = 4, k_2 = 3,
tylerc1991
166
What is the coefficient on [itex]x^{12} y^{24}[/itex] in [itex](x^3 + 2xy^2 + y + 3)^{18}[/itex]?
Multinomial Theorem:
[itex]\displaystyle \left( \sum_{k = 1}^m x_k \right)^n = \sum_{k_1 + \dotsb + k_m = n} \binom{n}{k_1, \dotsc, k_m} \prod_{i = 1}^m x_i^{k_i}[/itex]
Using the multinomial theorem, the expansion of [itex](x^3 + 2xy^2 + y + 3)^{18}[/itex] has terms of the form
[itex]\binom{18}{k_1, k_2, k_3, k_4} (x^3)^{k_1} (2xy^2)^{k_2} (y)^{k_3} (3)^{k_4} = \binom{18}{k_1, k_2, k_3, k_4} x^{3k_1} 2^{k_2} x^{k_2} y^{2k_2} y^{k_3} 3^{k_4} = \binom{18}{k_1, k_2, k_3, k_4} x^{3k_1 + k_2} 2^{k_2} y^{2k_2 + k_3} 3^{k_4}.[/itex]
The [itex]x^{12} y^{24}[/itex] occurs when [itex]3k_1 + k_2 = 12[/itex] and [itex]2k_2 + k_3 = 24[/itex]. We also know that [itex]k_1 + k_2 + k_3 + k_4 = 18[/itex]. This is where I get stuck, since I have 3 equations and 4 unknowns. Is my work correct up to this point? Is there another equation that I can use to find each [itex]k_i[/itex]? Thank you!
Yes, your work is correct up to this point. You are correct in saying that you have 3 equations and 4 unknowns, so you cannot solve for each k_i individually. However, you can use the fact that k_1, k_2, k_3, and k_4 are all non-negative integers to narrow down the possible values of k_i.
First, we know that k_2 must be even in order for 2^{k_2} to be a perfect square. This means that k_2 can only take on the values 0, 2, 4, 6, ..., 18.
Next, we can use the equation 3k_1 + k_2 = 12 to solve for k_1 in terms of k_2. We get k_1 = (12 - k_2)/3. Since k_1 must be a non-negative integer, this means that k_2 must be a multiple of 3.
Finally, we can use the equation 2k_2 + k_3 = 24 to solve for k_3 in terms of k_2. We get k_3 = 24 - 2k_2. Again, since k_3 must be a non-negative integer, this means that k_2 must be less than or equal to 12.
Using this information, we can now list out all the possible values of k_1, k_2, and k_3 that satisfy the given equations:
k_1 = 0, k_2 = 0, k_3 = 24
k_1 = 0, k_2 = 3, k_3 = 18
k_1 = 0, k_2 = 6, k_3 = 12
k_1 = 0, k_2 = 9, k_3 = 6
k_1 = 0, k_2 = 12, k_3 = 0
k_1 = 1, k_2 = 0, k_3 = 21
k_1 = 1, k_2 = 3, k_3 = 15
k_1 = 1, k_2 = 6, k_3 = 9
k_1 = 1, k_2 =
Related to How to Determine the Coefficient of \(x^{12}y^{24}\) in a Polynomial Expansion?
What is the Multinomial Theorem?
The Multinomial Theorem is a mathematical formula that allows us to expand the power of a sum of multiple terms. It is an extension of the Binomial Theorem, which only works for two terms.
What is the difference between a binomial and a multinomial?
A binomial is a polynomial with two terms, while a multinomial is a polynomial with more than two terms. The Multinomial Theorem is used to expand the power of a multinomial expression.
How is the Multinomial Theorem used in real life?
The Multinomial Theorem is used in many fields, including statistics, physics, and engineering. It is used to solve problems involving probabilities, combinations, and expansions of polynomial expressions.
What is the formula for the Multinomial Theorem?
The formula for the Multinomial Theorem is (a1 + a2 + ... + an)m = ∑k1+k2+...+kn=m (m! / k1! k2! ... kn!) a1k1 a2k2 ... ankn, where a1, a2, ..., an are the terms and m is the power.
Can the Multinomial Theorem be used for negative or fractional powers?
No, the Multinomial Theorem only works for positive integer powers. If the power is negative or fractional, the Binomial Theorem can be used instead.
