How Does Conductivity Increase in N-Type Semiconductors?
In summary, in n-type semiconductors, the conductivity increases as the number of free electrons in the conduction band increases. However, increasing the number of electrons also decreases the number of holes, which can also contribute to conductivity. Therefore, there is no net increase in conductivity. The concept of "hole current" refers to the movement of holes in the valence band, which corresponds to the movement of electrons in the conduction band.
gracy
2,486
83
How conductivity increases in n type semiconductor as ni^2 (formula nh multiplied by ne=ni^2 where nh=number of holes per unit volume and ne=number of free electrons per unit volume and ni=number of intrinsic charge carrier per unit volume remain constant?What is the use of increased number of electrons in conduction band as increasing number of electrons in conduction band decreases number of holes which were also capable of producing current i.e increasing conductivity.So overall no net increase in conductivity because as we are increasing number of electrons in conduction band at the same time we are loosing number of holes.please explain this.
Holes in the conduction band cannot produce a current. There is nothing that could move. Same with electrons in the valence band - they are bound and cannot move.
so why there is a concept called ' HOLE CURRENT'?
The hole current is caused by holes in the valence band (this corresponds to electrons in the conduction band).
Likes mfb
I can explain the concept of N-type semiconductors and how the conductivity increases in this type of semiconductor. N-type semiconductors are made up of materials such as silicon or germanium that have impurities added to them. These impurities, also known as dopants, introduce additional electrons into the material, creating an excess of free electrons.
The formula nh multiplied by ne=ni^2, where nh is the number of holes per unit volume and ne is the number of free electrons per unit volume, represents the equilibrium between the number of holes and free electrons in an N-type semiconductor. This equilibrium is maintained by the number of intrinsic charge carriers, ni, which remains constant.
Now, to address the question of how the conductivity increases in an N-type semiconductor, we need to understand the role of the excess free electrons. These free electrons are able to move more easily through the material, making it easier for electricity to flow. This is why N-type semiconductors are known as good conductors.
As the number of free electrons increases, the number of holes decreases. This is because the free electrons fill the holes, leaving fewer holes available for current flow. This decrease in the number of holes may seem counterintuitive, but it actually contributes to the increase in conductivity. This is because the holes, being positively charged, can hinder the movement of free electrons. So, by decreasing the number of holes, the free electrons can move more freely, resulting in a higher conductivity.
In summary, the increased number of electrons in the conduction band of an N-type semiconductor does not directly contribute to an increase in conductivity. However, by decreasing the number of holes, it allows for easier movement of the free electrons, resulting in a higher conductivity. This is why N-type semiconductors are commonly used in electronic devices where high conductivity is desired.
What is an N-type semiconductor?
An N-type semiconductor is a type of material that has an excess of negatively charged particles, called electrons, which allows it to conduct electricity. This is achieved by doping the semiconductor with impurities such as phosphorus or arsenic.
How does an N-type semiconductor differ from a P-type semiconductor?
N-type semiconductors have an excess of electrons, while P-type semiconductors have an excess of positively charged particles, called holes. This difference in charge carriers leads to different electrical properties and allows for the creation of electronic devices such as diodes and transistors.
What are some common applications of N-type semiconductors?
N-type semiconductors are commonly used in electronic devices such as transistors, diodes, and solar cells. They are also used in integrated circuits and sensors.
How are N-type semiconductors manufactured?
N-type semiconductors are typically manufactured through a process called doping, where impurities are intentionally added to the semiconductor material. This can be done through diffusion, where the impurities are diffused into the material, or through ion implantation, where the impurities are implanted into the material using high-energy ions.
What are the advantages of using N-type semiconductors?
N-type semiconductors have several advantages, including high conductivity, low resistance, and high stability at high temperatures. They also have a wide range of applications in electronic devices and are relatively easy to manufacture.
  • Atomic and Condensed Matter
  • Classical Physics
  • Electrical Engineering
