How Do You Calculate the Thermal Energy to Melt a Copper Bar?
  • Thread starter chameleon1
  • Tags
    Stuck
The what?In summary, specific heat capacity is the amount of heat required to raise the temperature of a substance by 1 degree Kelvin per unit mass. Latent heat of fusion is the amount of heat required to change a substance from solid to liquid state. To calculate the thermal energy required to convert a 40 kg copper bar from a temperature of 280 K to molten metal at 1360 K, we need to consider both specific heat capacity and latent heat of fusion. The total thermal energy required is the sum of the energy needed to raise the temperature to 1360 K and the energy needed for the phase change.
chameleon1
Define specific heat capacity and latent heat of fusion.
Copper melts at a temperature of 1356 K with a latent heat of fusion
of 210,000 J/kg (Joules per kilogram). Calculate the thermal energy required
to convert a copper bar with a mass of 40 kg at a temperature of 280 K into
molten metal at 1360 K if the average specific heat capacity of copper (liquid
and solid) is 385 J/kg/K (Joules per kilogram per Kelvin) in the temperature
range considered here
energy SCH(specific heat capacity) * mass * change in temp
i tried to use this formula but the numbers am gettin isn't write , if possible can someone guide me on how to do this or what am i doing wrong, am good with biology but am am also learning physics which is very difficult for me .
Welcome to PF.
Maybe if you show your calculation it will be easier to figure what may be going awry?
Thanks for the welcome .
SHC heat change is 1360 k - 280 k = 1080K
1080 k * 40kg (mass) = 43200
43200 * 385 j/kg/k = 16632000
to calculate quantity of thermal energy, then multiply mass, the specific heat capacity (for liquid water this is 4.19J/g degrees Celsius), and the change in temperature. and this is what i used but the number is tooo high and loooks wrong , i don't know what i am doing wrong
LowlyPion said:
Welcome to PF.
What about the 210,000 j/kg to melt it to liquid?
do i need to divide 210,000 by 40kg mass = 5250 OR??
Didn't it say it was J/kg?
Is divide the right thing to do?
not sure, is there a formula which you can telll me , sorry i don't want to sound stupid, but maths and physics are not my thing but i have tooo to this its one of my modules please help me further and next time i would be able to this myself
You figured the energy needed to raise the temp of the 40 kg.
But now you still need to consider the heat of fusion - the energy that will make it liquefy. If you need 210,000J to liquefy 1 kg of cooper already at 1360 K, then how much more to liquefy 40 kg?
Add the 2 together and you have your total thermal energy.
so 210,000 j/kg * 40kg = 8400000
but what do i need to add it too in order to get the thremal energy
What about the energy to get if from 280K to 1360 K?
so 1350k - 280k = 1070k
so 1070k needed to get it to 1360k
then add 1360k to 8400000 but most likely not OR?
LowlyPion said:
Have you just completely forgotten about what you calculated here already?
https://www.physicsforums.com/showpost.php?p=2129871&postcount=3
am lost with all this numbers now , tell me how to do this as i have tried already, once you tell me it will stick into my head , what's the answer to this ridddle :)
You figured out in post 3 how much energy it took to raise the copper to the melting point of 1360K.
Then you figured how much to melt the block, once it got to 1360K
Total energy required then is the sum of those 2 energy requirements.
and what was The i had figured how much to melt the block, once it got to 1360K
Are you asking about what you found in post 10?
The results of post 3 and post 10 added together should be your answer.
16632000 + 8400000 = 33432000 j/kg
Thats the answer and that's the right sysmbol i put at the end?
No. They asked for energy.
That would just be in Joules.
16632000 + 8400000 = 33432000Q
Q = m x T x Cp
Q = change in thermal energy
m= mass of substance
T = change in temperature (Tf – Ti)
Cp = specific heat of substance
i got this from a website
so is it 33432000 Q OR what's the symbol for the thermal energy
J for joules.
Btw:
Check your math again.
LowlyPion said:
J for joules.
Btw:
1080 k * 40kg (mass) = 43200 from post 3
so 210,000 j/kg * 40kg = 8400000 from post 10
= 43200 + 8400000 = 8443200 is that right if it is what is the symbol i should put at the end
Not quite.
43200 is merely kg*K. You've forgotten the 385 J/(K*kg)
You found the right answer to that part of it - raising the temperature of 40 kg to the melting point in 3. Why resistant to accepting it now?
This problem is fairly straightforward if you pay attention to the units.
They give you the specific heat needed to raise the temp of 1 kg of copper by 1 degree K. That's 385 J/(K*kg)
Well you have 40 kg and you have 1080 degrees to raise it.
That's simply 385*40*1080. That gets the number of J's needed to get it to the melting point.
Even though it is at the melting point it is still solid. That's where the heat of fusion comes in. 210,000 J/kg is needed to get it to melt. And of course that is in addition to what you already found. That is given as J/kg so to figure J then you need to multiply 210,000J/kg*40kg to yield the Joules required.
385*40*1080 = 16632000
210,000J/kg*40kg = 8400000
16632000 + 8400000 = 25032000j/kg this is thermal energy needed
thats right now
thats right now
At last. The Emerald City.
hahaahaha 26 posts to get it right yesssssssssss
1. What is the best approach to solving a problem when I am stuck?
The best approach to solving a problem when you are stuck is to take a step back and reassess the situation. Break down the problem into smaller, manageable parts and try to identify where you are getting stuck. It may also be helpful to consult with colleagues or do some research to gain a new perspective on the problem.
2. How can I effectively communicate my problem to others to get help?
When seeking help with a problem, it is important to clearly communicate the issue you are facing. Start by providing a brief summary of the problem and what you have already tried. Be specific and provide any relevant details or error messages. This will help others understand the problem and provide more targeted assistance.
3. How can I stay motivated when I am stuck on a difficult problem?
Staying motivated when facing a difficult problem can be challenging. One strategy is to take a break and come back to the problem with a fresh perspective. It can also be helpful to remind yourself of previous successes and the importance of solving the problem. Seeking support from colleagues or mentors can also provide motivation and encouragement.
4. What are some common mistakes to avoid when trying to solve a problem?
When solving a problem, it is important to avoid making assumptions and jumping to conclusions. This can lead to overlooking important details or potential solutions. It is also important to avoid getting too focused on one approach and being open to different solutions. Lastly, it is important to avoid procrastination and tackle the problem head-on rather than avoiding it.
5. What resources can I use to help me when I am stuck with a problem?
There are many resources available to help you when you are stuck with a problem. These can include colleagues, mentors, online forums, and documentation. It can also be helpful to utilize debugging tools or collaborate with others to brainstorm solutions. Additionally, there are many online learning platforms and tutorials that can provide guidance and help you expand your problem-solving skills.
