Parallel tangent plane.
In summary: Substituting these values into the equation of the hyperboloid, we get 9(k/18)^2 -45(-k/18)^2+5(-k/5)^2 = 45. Simplifying, we get k^2 = 45, which means that k = ±√45.Substituting these values of k into our expressions for x0, y0, and z0, we get two points on the hyperboloid: (±√45/18, √45/18, -√45/5). These are the points on the hyperboloid where the tangent plane is parallel to
AndreTheGiant
28
Find the points on the hyperboloid 9x^2 -45y^2+5z^2 = 45 where the tangent plane is parallel to x+5y-2z = 7.
Ok so the tangent plane is parallel to the x+5y-2z=7 when their normal vectors are parallel. So that means that the normal vector for the given plane (1,5,-2) should also be a normal vector for the tangent plane to the hyperboloid.
So since the equation of the plane can be written as
(1,5,-2) . (x-x0,y-y0,z-z0) = x - x0 + 5y -5y0 -2z + 2z0 where -x0 - 5y0 +2z0 = -7
and the equation of the tangent plane to the hyperboloid can be written as the gradient at (x0,y0,z0) . (x-x0,y-y0,z-z0)
the gradient is (18x0, -90y0, 10z0) at (x0,y0,z0). and it has to be equal to the normal vector (1,5,-2).
So 18x0 = 1, -90y0 = 5, 10z0 = -2? and then solve for x0,y0,z0 and that is the point I'm looking for?
Just wanted to know if I'm doing this right.
Yes, you are on the right track with your approach. However, there are a few corrections and clarifications that I would like to make.
Firstly, when you say that the normal vector for the given plane should also be a normal vector for the tangent plane to the hyperboloid, this is not entirely correct. The normal vector for the given plane (1,5,-2) is a direction vector for the plane, but it is not a normal vector. To find the normal vector, we need to take the coefficients of x, y, and z in the plane equation and form a vector (1,5,-2), which is the normal vector.
Secondly, when you say that the equation of the plane can be written as (1,5,-2) . (x-x0,y-y0,z-z0) = x - x0 + 5y -5y0 -2z + 2z0, this is also not entirely correct. The equation of a plane in vector form is (x-x0,y-y0,z-z0) . n = 0, where n is the normal vector and (x0,y0,z0) is a point on the plane. So in this case, the equation of the given plane would be (x-x0,y-y0,z-z0) . (1,5,-2) = 0.
Now, to find the point on the hyperboloid where the tangent plane is parallel to the given plane, we need to find a point (x0,y0,z0) that satisfies both equations: 9x0^2 -45y0^2+5z0^2 = 45 and (x-x0,y-y0,z-z0) . (1,5,-2) = 0.
So, as you correctly identified, the gradient of the hyperboloid at (x0,y0,z0) should be parallel to the normal vector of the given plane (1,5,-2). This means that the gradient vector (18x0, -90y0, 10z0) should be a scalar multiple of (1,5,-2). This leads to the equations: 18x0 = k, -90y0 = 5k, 10z0 = -2k, where k is the scalar multiple.
Solving these equations, we get x0 = k/18
1. What is a parallel tangent plane?
A parallel tangent plane is a geometric concept used in mathematics and physics. It is a plane that is parallel to a given surface and touches the surface at exactly one point, known as the point of tangency. This plane is also called a tangent hyperplane or a tangent plane at a point.
2. How is a parallel tangent plane different from a regular tangent plane?
A regular tangent plane is a plane that touches a surface at a single point and is perpendicular to the surface's normal vector at that point. On the other hand, a parallel tangent plane is a plane that is parallel to the surface and touches it at one point. This means that the parallel tangent plane is not perpendicular to the surface's normal vector.
3. What is the use of parallel tangent planes in real-world applications?
Parallel tangent planes have many applications in fields such as engineering, physics, and computer graphics. They are used in the study of curved surfaces and their properties, such as curvature and slope. In engineering, they are used to design efficient structures and to analyze stress and strain on surfaces. In computer graphics, they are used to create smooth surfaces in 3D modeling and animation.
4. How do you calculate a parallel tangent plane to a given surface?
To calculate a parallel tangent plane, you need to know the equations of the surface and the point of tangency. First, find the normal vector to the surface at the point of tangency. Then, find the equation of a plane that is parallel to this normal vector and passes through the given point. This plane will be the parallel tangent plane to the surface at that point.
5. Can a surface have more than one parallel tangent plane?
Yes, a surface can have multiple parallel tangent planes. This is because there can be multiple planes that are parallel to a surface and touch it at a single point. However, the normal vectors to these planes will be different, so they will not be parallel to each other. Therefore, each parallel tangent plane will have a different point of tangency on the surface.
