Position Time, falling objects
In summary, the conversation discusses a problem involving a rock being dropped from a cliff and the time it takes for the sound of impact to reach the top of the cliff. The formula for calculating the height of the cliff is given, and it is explained how to solve for h using the equations for time of the rock and sound. Ultimately, the individual needs help understanding how to solve for h in this problem.
dwilson89
Please help! I've been both conceptually blocked for quite some time and need help fast!
A rock is dropped from a sea cliff, and the sound of it striking the ocean is heard 4.0 later. Given the speed of sound is 340m/s, calculate how high the cliff is in meters.
If h is the height of the cliff, time taken by the rock to fall is given by
h = 1/2*g*t1^2.
Time taken by the sound to reach the top of the cliff is t2 = h/340.
Now t1 + t2 = 4 s.
Substitute the values of t1 and t2 in the above equations and solve for h.
h = 1/2*g*t1^2.
Now t1 + t2 = 4 s.
So do you mean solve to T1 in the first equation, then add the two together and solve for h?
Get t1 in terms of h. Then get t2 in terms of h.
& Substitute these into t1 + t2 = 4.
Hello,
I understand that you are looking for assistance with understanding the concept of position and time for falling objects. It is completely normal to feel stuck or blocked when learning new concepts, and I am here to help you.
In the scenario you have provided, we have a rock that is dropped from a sea cliff and the sound of it hitting the ocean is heard 4.0 seconds later. We also know that the speed of sound is 340m/s. To calculate the height of the cliff, we can use the equation d = 1/2gt^2, where d is the distance, g is the acceleration due to gravity (9.8m/s^2), and t is the time.
First, we need to find the time it takes for the rock to fall from the cliff to the ocean. We can do this by dividing the total time (4.0 seconds) by 2, since the sound has to travel both ways (from the cliff to the person's ear and back). This gives us a time of 2.0 seconds for the rock to fall.
Now, we can plug in the values into the equation: d = 1/2 (9.8m/s^2)(2.0s)^2. This gives us a distance of 19.6 meters, which is the height of the cliff.
I hope this helps you understand the concept better. Remember, it is important to take your time and break down the problem into smaller parts to fully understand it. If you need any further assistance, please do not hesitate to ask. Keep up the good work!
Related to Position Time, falling objects
1. What is position-time graph?
A position-time graph is a graphical representation of an object's position as it changes over time. The horizontal axis represents time and the vertical axis represents position. The slope of the graph is equal to the object's velocity.
2. How does gravity affect falling objects?
Gravity is a force that pulls objects towards the center of the Earth. This force causes falling objects to accelerate towards the ground at a constant rate of 9.8 meters per second squared.
3. How do you calculate the acceleration of a falling object?
The acceleration of a falling object can be calculated using the formula a = g, where g is the acceleration due to gravity (9.8 m/s^2). This means that regardless of the mass of the object, it will accelerate towards the ground at the same rate.
4. What is the difference between speed and velocity?
Speed is the rate at which an object moves, while velocity is the rate at which an object moves in a specific direction. In other words, velocity takes into account both the speed and direction of an object's motion.
5. How does air resistance affect the motion of falling objects?
Air resistance is a force that opposes the motion of an object through air. The larger the surface area of an object, the more air resistance it experiences. This means that air resistance can slow down the acceleration of a falling object and ultimately affect its position-time graph.
