Projectile Motion- SPH4U Grade 12 Physics
In summary: With the acceleration known, you can use kinematics to find the speed of the 5 kg mass at the top of the ramp. Finally, use projectile motion equations to find the horizontal range. In summary, a pulley device is used to accelerate a 5.0 kg mass up a ramp with a 4.0 m length and a coefficient of friction of 0.26. The mass is accelerated by a falling 20.0 kg mass suspended over a frictionless pulley. After reaching the top of the ramp, the 5.0 kg mass detaches from the rope and becomes projected from the ramp. By analyzing each mass separately and applying Newton's 2nd law, the acceleration of the 5
AkadouYoroi
A pulley device is used to hurl projectiles from a ramp (uk=0.26) as illustrated in the diagram. The 5.0-kg mass is accelerated from rest at the bottom of the 4.0 m long ramp by a falling 20.0-kg mass suspended over a frictionless pulley. Just as the 5.0-kg mass reaches the top of the ramp, it detaches from the rope (neglect the mass of the rope) and becomes projected from the ramp.
*there should be an attached image at the bottom*
a) Determine the acceleration of the 5.0-kg mass along the ramp. (Answer: 6.4 m/s2 up the ramp)
b) Determine the tension in the rope during the acceleration of the 5.0-kg mass along the ramp. (Answer: 68 N along the ramp)
c) Determine the speed of projection of the 5.0-kg mass from the top of the ramp. (Answer: 7.2 m/s)
d) Determine the horizontal range of the 5.0-kg mass from the base of the ramp. (Answer: 9.5m)
a) I know that to find acceleration, i need to find the total net force of the system and divide by the two masses. I found the Fgx for the 5.0 kg object using (5.0)(9.0)cos30, the Fg for 20.0 kg object (20.0)(9.8), and the Ff of the system, using uFn. I don't get the quite answer. I am not sure if I missed any calculations, or my components are not correct.
b) I believe this might have been a component I've missed in part A, but I do not really know how to start off the tension calculation. I believe it involves using the frictional force to calculate the tension, but I am not sure.
c) I tried solving using the Vfy=V1y+ayt equation, and finding the value of t using y=1/2ay(t)2. (Sorry about not doing subscripts). I end up with an answer that's about 3.0s. But I think its because I might be confusing myself, because I've never done a projectile motion that involved mass in it.
Im not sure where to start, since it involves masses. I am not too sure if the object accelerated from rest in the question indicates something I should be doing.
Thank you so much.
The answers are posted with the questions, but I had a tough time getting to the answer, or not knowing how to start it.
  • motion.doc
The best way to attack this problem is by analyzing each mass separately. What forces act on the 5 kg mass? On the 20 kg mass? Apply Newton's 2nd law to each, which will give you two equations. That will allow you to solve for the two unknowns: tension and acceleration.
Hello,
Thank you for providing the problem and your attempt at solving it. Projectile motion is a fundamental concept in physics and it is important to have a good understanding of it.
a) To find the acceleration of the 5.0-kg mass along the ramp, you need to consider the forces acting on the mass. The only forces acting on it are its weight, which is directed down the ramp, and the frictional force, which is directed up the ramp. Using Newton's Second Law, we can write:
ΣF = ma
Where ΣF is the sum of all the forces acting on the mass, m is the mass of the object and a is the acceleration. In this case, we can write:
ΣF = Fg - Ff
Where Fg is the weight of the mass and Ff is the frictional force. The weight can be calculated using Fg = mg, where g is the acceleration due to gravity (9.8 m/s^2). The frictional force can be calculated using Ff = μFn, where μ is the coefficient of friction (0.26 in this case) and Fn is the normal force, which is equal to the weight of the mass in this case. Therefore, we can write:
ΣF = mg - μmg = (1 - μ)mg
Substituting the values, we get:
ΣF = (1 - 0.26)(5.0)(9.8) = 34.6 N
Now, we can use Newton's Second Law to find the acceleration:
a = ΣF/m = 34.6/5.0 = 6.92 m/s^2
Note that this is the acceleration along the ramp, which is directed up the ramp.
b) To find the tension in the rope, we need to consider the forces acting on the 20.0-kg mass. The forces acting on it are its weight, which is directed down, and the tension in the rope, which is directed up. Using Newton's Second Law again, we can write:
ΣF = ma
ΣF = Fg - T
Where Fg is the weight of the mass and T is the tension in
Related to Projectile Motion- SPH4U Grade 12 Physics
What is projectile motion?
Projectile motion is the motion of an object in a curved path due to the influence of gravity. It is a combination of a horizontal constant velocity and a vertical acceleration due to gravity.
What factors affect projectile motion?
The factors that affect projectile motion are the initial velocity, angle of launch, air resistance, and the acceleration due to gravity. These factors determine the shape and distance of the projectile's path.
What is the difference between horizontal and vertical components in projectile motion?
The horizontal component of projectile motion is the initial velocity in the x-direction, which remains constant throughout the motion. The vertical component is the acceleration due to gravity, which causes the object to accelerate downward at a constant rate.
How is the range of a projectile calculated?
The range of a projectile is the horizontal distance it travels before hitting the ground. It can be calculated using the formula R = (v0,x2 * sin2θ)/g, where v0,x is the initial horizontal velocity, θ is the angle of launch, and g is the acceleration due to gravity.
How does air resistance affect projectile motion?
Air resistance, also known as drag, can affect the motion of a projectile by slowing it down and changing its trajectory. This is because air resistance acts in the opposite direction of the projectile's motion, causing a decrease in its velocity and range.
