Projectile Olympiad Question
In summary, the question asks for the minimum launch angle for a cannonball to reach a height larger than the horizontal distance it travels when returning to the ground. Using the equations for distance and time, the minimum angle is found to be 75.9°.
poseidon007
A cannonball is launched with initial velocity of magnitude v0 over a horizontal surface. At what minimum angle θmin above the horizontal should the cannonball be launched so that it rises to a height H which is larger than the horizontal distance R that it will travel when it returns to the ground?
(A) θmin = 76◦
(B) θmin = 72◦
(C) θmin = 60◦
(D) θmin = 45◦
(E) There is no such angle, as R > H for all range problems.
d = (vi+vf)/2)*t
H = (1/2)(v0sinθ)(t) and R = (v0cosθ)(t)
Thus, if H = R, then (1/2)(v0sinθ)(t) = (v0cosθ)(t)
=>tanθ = 2, so θ = 63.4°. I'm probably making a really obvious mistake here, but I'm not seeing it. Any help would be appreciated.
Do you need to include the effect of gravity somewhere? [EDIT: Nevermind, you are using the equation d = (vi + vf)*t/2 which doesn't require knowing the acceleration.]
poseidon007 said:
d = (vi+vf)/2)*t
I think I now see what you're doing. Does the t in the H equation represent the same time as the t in the R equation?
ohhhh i see now. the t in the H equation is the time to get to maximum height, which is half of the t in the R equation. so it would really be (1/2)(v0sinθ)(t/2) = (v0cosθ)(t) which gives tanθ = 4 so θ = 75.9° (A). Thanks so much!
Good job.
Related to Projectile Olympiad Question
1. What is the Projectile Olympiad Question?
The Projectile Olympiad Question is a physics problem that involves calculating the trajectory of a projectile launched at a specific angle and velocity, taking into account factors such as air resistance and gravity.
2. How is the Projectile Olympiad Question solved?
The Projectile Olympiad Question is typically solved using equations from classical mechanics, such as the kinematic equations and the Newtonian equations of motion. Other methods, such as using computer simulations, can also be used to solve this problem.
3. What are the applications of the Projectile Olympiad Question?
The Projectile Olympiad Question has practical applications in fields such as engineering, ballistics, and sports. It can also be used to understand and predict the motion of objects in the natural world, such as the flight of a bird or the trajectory of a falling object.
4. What are the key factors to consider when solving the Projectile Olympiad Question?
The key factors to consider when solving the Projectile Olympiad Question include the initial velocity and angle of the projectile, the effects of air resistance and gravity, and the distance and height of the target or landing point.
5. Are there any real-life examples of the Projectile Olympiad Question?
Yes, there are many real-life examples of the Projectile Olympiad Question. For instance, in sports such as baseball, soccer, and golf, players must calculate the trajectory of a ball to make accurate shots. In engineering, this question can be used to design and test rockets, projectiles, and other flying objects. It can also be applied in military operations to determine the range and trajectory of weapons.
21K
