Proving One-to-One Function: Non-Graphical Method Using Fractional Equation
  • Thread starter mindauggas
In summary, the conversation discusses ways to determine if a function is one-to-one without graphing it. Some methods include looking at the function's inverse, checking for asymptotes, and finding the function's roots. The conversation also explores the concept of multiplicity in relation to one-to-one functions.
mindauggas
127
Is there a way to show that the function [itex]\frac{2x^{2}}{x-2}[/itex] is/is'nt one to one, non graphicaly (without drawing the graph)?
I tried to following: To determine whether this function is one to one, look at what happens if two values of x give the same y: suppose [itex]2a^{2}/(a-2)= 2b^{2}/(b-2)[/itex]. Multιply both sides by [itex](a-2)(b-2)[/itex] to get [itex]2a^{2}(b-2)= 2b^{2}(a-2)[/itex]. That is the same as [itex]2a^{2}b-2a= 2b^{2}a-2b[/itex]. Trying to show, that that two different values of x cannot give the same y (this is an adaptation sugested by HallsofIvy on a similar problem). But got stuck.
Help much needed here :)
Isn't it easier to try and find an inverse function?
Does the inability to find an inverse imply the absence of one-to-one'ess whit strict necesity?
On the other hand how will i know that the inverse does not exist (instead of not being able to find it) ??
Are there any analitical methods to determine one-to-one'ess in general?
Just keep working:
##a^2(b-2)=b^2(a-2)##
##a^2b-2a^2-ab^2+2b^2=0##
##ab(a-b)-2(a+b)(a-b)=0##
Since we don't want ##a=b## divide out the ##a-b##.
##ab-2a-2b=0##
##a(b-2)=2b##
##a = \frac{2b}{b-2}## Take, for example, b = 3, a = 6.
mindauggas said:
Does the inability to find an inverse imply the absence of one-to-one'ness with strict necessity?
No, but if solving y=f(x) for x gives a result with a ± sign, then you know the function is not one-to-one.
Some other ways you might know that this function is not one-to-one are at least somewhat related to the graph y=f(x), even though you can determine them without actually graphing the function.
The graph has a slant asymptote of y = x + 4, and a vertical asymptote at x=2. These two thing together are incompatible with being one-to-one.
The function has a zero of even multiplicity (multiplicity 2) thus it is not one-to-one .
Thanks for these criteria of determining not-one-to-one'ness. But could you elaborate on this quoted part? why are these asymptes incompatible with a function whitch has them being one-to-one?
LCKurtz said:
Just keep working:
##ab-2a-2b=0##
##a(b-2)=2b##
Some other ways you might know that this function is not one-to-one...
I'm not so sure about that one. Consider$$
f(x) =\left \{ \begin{array}{rl}
x^3,& x\le 0\\
x^2,&x>0
\end{array}\right.$$Here both f(0) and f'(0) are 0 and f''(0) doesn't exist, so it has a root of multiplicity 2.
[Edit, added later:] Looking at a couple of alternate definitions of multiplicity on the internet, f''(0) not existing might kill this counterexample. This may not be multiplicity 2. Also the definition in terms of limit is that a root r is multiplicity n if$$
\lim_{x\rightarrow r}\frac{f(x)}{(x-r)^n}$$is a non-zero number. That doesn't work for my example either.
LCKurtz said:
Just keep working:
##ab-2a-2b=0##
##a(b-2)=2b##
Sorry, for returning to this exercise after such a long time, but I realize that I have doubts about how to interpret the result. If we do not get a=b, that means that there are more than one x in terms of which y can be expressed? Thus making the function not one-to-one?
You were looking for two different values ##x=a## and ##x=b## such such that$$
f(x)=\frac {2x^2}{x-2}$$had the same value. My example in post #4 was ##x=3## and ##x=6##. Do they work?
In your first post, you started by looking at
[tex]\frac{2a^2}{a- 2}= \frac{2b^2}{b- 2}[/tex]
and multiplied both sides by (a- 2)(b- 2) to get [itex]2a^2(b- 2)= 2b^2(a- 2)[/itex]]
As LCKurtz pointed out: You can continue that to get [itex]a^2b- 2a^2= ab^2- 2b^2[/itex] and you can write that as [itex]a^2b- ab^2= 2(a^2- b^2)[/itex], [itex] (a- b)(ab)= 2(a- b)(a+ b)[/itex]. With [itex]a\ne b[/itex], we can divide by a- b to get [itex]ab= 2(a+ b)[/itex]. What LCKurtz then did was choose values of a and b that satisfy that: if a= 3 and b= 6, ab= (3)(6)= 18= 2(9)= 2(3+ 6).
Yes, they do give the same value.
i understand what was done and sugested, but what does it mean exactly and precisely in terms of one-to-ones? For example: "this the function is nor one to one, because we got two values of x in that give the same y". But what then is the meaning of the derived term a=2b/b-2 ? Is it just a tool to generate posible values of x for which we would get the same y? A mental aid? Or does it necesarily give all the x's for which we get the same y? (for example b=1 gives a=-2 and they both give the same f(x) when put into the equation).
You started by setting f(a) = f(b) so you had two, hopefully different, x's giving the same y. The idea was to see if that was possible or not because that will tell you whether f is 1-1. The end result of that was the equation a = 2b/(b-2). In particular, it did not come that a had to equal b. All you have to do to show the function isn't 1-1 is to find 2 values of x giving the same f(x). b = 3 and a = 6 are one choice. b = 1 an a = -2 are others. There are more, but you only need one.
Clear enought. Thanks :)
Related to Proving One-to-One Function: Non-Graphical Method Using Fractional Equation
1. What is "One-to-one'ess question"?
"One-to-one'ess question" refers to a type of question in which there is a direct relationship between the question and the answer. This means that there is only one correct answer for each question, and it cannot be interpreted in multiple ways.
2. How is "One-to-one'ess question" different from other types of questions?
"One-to-one'ess question" is different from other types of questions, such as open-ended or multiple-choice questions, because it requires a specific, factual answer. It does not allow for interpretation or personal opinions.
3. What are some examples of "One-to-one'ess question"?
Examples of "One-to-one'ess question" include questions that ask for a specific date, number, or fact, such as "What year was the Declaration of Independence signed?" or "How many planets are in our solar system?" These questions have one correct answer that can be easily verified.
4. How can "One-to-one'ess question" be used in scientific research?
"One-to-one'ess question" can be used in scientific research to gather specific data and information. By asking direct questions, researchers can obtain precise answers that can be used to support their hypotheses and conclusions.
5. What are some strategies for creating effective "One-to-one'ess question"?
To create effective "One-to-one'ess question", it is important to use clear and concise language, avoid vague or ambiguous terms, and focus on specific details. It can also be helpful to use multiple "One-to-one'ess question" in a series to gather more comprehensive data.
  • Precalculus Mathematics Homework Help
