How Do You Calculate Sample Size for a T-Test?
  • Thread starter tedpark1212
  • Tags
    Statistics
In summary, the required sample size for the first question is 829 with a significance level of 0.05 and 283 for the second question with a significance level of 0.01. Keep in mind that these calculations are based on certain assumptions and may vary depending on the specific parameters. It is always best to double check your work and consult with a statistician or expert if needed.
tedpark1212
So I made an attempt to solve question 1, but I am stuck with question 2. I know that I need to use binominal distribution, but am unclear of the proper steps. Can anyone provide some help?
1. Suppose you want to show the significance of an effect size of 0.20 between your sample mean and a hypothesized mean. You intend to conduct a two-sided one-sample t-test. The sample variance is σ2 = 1.0. You assume that the population is large, or effectively infinite. If you want the test to have a power of 0.80, what is the required sample size for the following?
Attempt to solve:
• A level of significance of α = 0.05
n = 2 σ2 (Z (beta) + Z (alpa/2)) 2/ effect size2
n = 2(1) ( 1.28 + 1.96) 2/ 0.202------ for α = 0.05
n = 2 (20.9952) / 0.04
n=524.88
n= 525
The required sample size is 525 with a level of significance of α = 0.05.
• A level of significance of α = 0.01
n = 2 σ2 ( Z (beta) + Z (alpha/2) ) 2/ effect size2
n = 2(1) ( 1.28 + 2.575) 2/ 0.202------ for α = 0.01
n= 2 (14.86) / 0.04
n=743.05
n= 743
The required sample size is 743 with a level of significance of α = 0.01.
2. After some research, you determine that the size of the population is N = 350. If you want the test to have a power of 0.80, what is the required sample size for the following?
Hi there,
Thank you for sharing your attempt at solving the first question. It looks like you have the right formula, but there are a few errors in your calculations. First, the critical values for alpha/2 and beta may be different depending on the sample size. Second, the effect size should be squared in the formula.
For the first question, using a significance level of 0.05, the correct formula would be:
n = (2*1*(1.96+0.842)^2)/(0.20^2) = 829
So the required sample size would be 829.
For the second question, we would need to make some assumptions about the population size and the effect size. Assuming a large population and the same effect size of 0.20, the formula would be:
n = (2*1*(1.96+0.842)^2)/(0.20^2*(1-350/829)) = 283
So the required sample size would be 283.
I hope this helps! Let me know if you have any further questions or need clarification on anything.
Related to How Do You Calculate Sample Size for a T-Test?
What is the importance of sample sizes in statistics?
Sample sizes are important in statistics because they represent the number of observations or measurements that are included in a study or experiment. A larger sample size can provide more accurate and representative results, while a smaller sample size may not accurately reflect the population being studied.
How do you determine the appropriate sample size for a study?
The appropriate sample size for a study depends on various factors such as the research question, the level of precision desired, and the variability within the population. Generally, a larger sample size is needed for studies with a larger population size and smaller effect sizes.
What is the minimum sample size required for statistical significance?
The minimum sample size required for statistical significance depends on the desired level of confidence and the effect size of the study. Generally, a larger sample size is needed for a higher level of confidence (e.g. 95% vs 99%) and a smaller effect size (e.g. smaller difference between groups).
What are the risks of having a small sample size?
Having a small sample size can lead to biased or unreliable results. It may also limit the generalizability of the findings to the larger population. In addition, small sample sizes may have a higher chance of Type II error, which is failing to reject a false null hypothesis.
What are the advantages and disadvantages of using a large sample size?
The advantages of using a large sample size include increased accuracy and precision of results, greater representativeness of the population, and the ability to detect smaller effects. However, a large sample size can also be costly and time-consuming to obtain. Additionally, if the population is highly homogeneous, a large sample size may not be necessary and could potentially waste resources.
