What is the Power Dissipated in a Bulb with a Set Firing Angle?
  • Thread starter David J
  • Tags
    Angle
In summary, the power dissipated in the bulb with a firing angle of ##\alpha=\frac{\pi}{3}##, a voltage source of 230V @ 50Hz, and a rating of 100W is approximately 80.317W. This is calculated by first converting the source voltage to its peak value, then using the equation ##Vload = 325\sqrt\frac{\left(2\pi -\left(\frac{2\pi}{3}\right)+\sin\left(\frac{2\pi}{3}\right)\right)}{4\pi}## to find the load voltage, and finally calculating the bulb's power dissipation using ##P=IV##. It is important
David J
If the firing angle is set to ##\alpha = \frac{\pi}{3}## estimate the power dissipated in the bulb if it is rated at ##100w## and the voltage source is ##230V## @ ##50Hz##
[/B]
##Vpeak = \frac{230}{0.707}## = 325V
##Vload = 206Vrms##
The bulb is rated at 100w so ##100=\frac{230}{I}##
##I rms=\frac{100}{230}=0.43A##
##R=\frac{230}{0.43}=534.884##
[/B]
I have just started looking at this question and picked up on an old post from 2015
(Triac - Power dissipated in light bulb)
In that post they had taken the given voltage of 230V (assuming it to be rms) and calculated the peak value by dividing by 0.707 to give a peak value of 325V. I get that part.
The next part is to calculate the "load" voltage using ##Vload = 325\sqrt\frac{\left(2\pi -\left(\frac{2\pi}{3}\right)+\sin\left(\frac{2\pi}{3}\right)\right)}{4\pi}##.
I am a little confused by this as I have tried following this equation many times and I cannot end up with a value of 206 and I was wondering if someone could give a little advice.
I am guessing that ##\alpha=\frac{\pi}{3}## is the time / part of the wave when the firing takes place so it maybe at a lower part of the sine wave so to speak. This the value that everyone was getting of 206V rms
If I can understand how to arrive at the value of 206 I should be able to complete this and was wondering is anyone could point out why I cannot arrive at 206. Is the equation wrong or probably I am not carrying out the calculation correct ?
Tanks in advance for any help with this
You can derive the expression for Vrms in terms of source voltage and firing angle.
Plot the output voltage and use the definition of rms voltage.
You should keep more digits during your calculation of the bulb resistance. In particular, you've kept only two digits in the intermediate value for the current, truncating after the second digit. As a result your bulb's resistance value will be a bit high.
For your calculation of Vload, is your calculator set to degrees or radians mode?Edit: FYI, the previous thread being referred to is here:
I was working in degrees. I changed it to radians and it worked out correctly
##v peak= \frac{230}{0.707}##
##Vload=325\sqrt\frac{\left(2\pi-\left(\frac{2\pi}{3}\right)+\sin\left(\frac{2\pi}{3}\right)\right)}{4\pi}##
##Vload=325\sqrt\frac{\left(6.283185307-2.094395102\right)+0.866025403}{12.56637061}##
##Vload=325\sqrt\frac{4.188790205+0.866025403}{12.56637061}##
##Vload=325\sqrt\frac{5.054815608}{12.56637061}##
##Vload=325\sqrt {0.402249445}##
##Vload=325\times0.634231381##
##Vload=206.125199 V##
I found the ##I rms## using ##\frac{100}{230}=0.434782608 amps##
I found the ##R## using ##\frac{230}{0.434782608}=529 \Omega##
So the current flowing through the filament at the firing time will be equal to ##I=\frac{206.125199}{529}=0.389650659 amps##
So the Power dissipated in the filament during the firing time will be equal to ##I=206.125199\times 0.389650659=80.3168\omega##
I think this is correct now. Thanks once again for the help, much appreciated
1. What is a triac and what is its purpose?
A triac is a type of electronic switch that can control the flow of electricity. It is commonly used in circuits to regulate the power output and can be found in devices such as dimmer switches and motor speed controllers.
2. What is a firing angle and how does it affect a triac?
A firing angle is the point at which a triac is triggered to conduct electricity. It determines when the device will turn on and how much power will be allowed to flow through it. Different firing angles can be used to control the output of a circuit.
3. What factors influence the firing angle of a triac?
The firing angle of a triac can be influenced by several factors, including the control signal (such as a voltage or current input), the load resistance, and the characteristics of the triac itself (such as gate sensitivity and thermal resistance).
4. How can the firing angle of a triac be controlled?
The firing angle of a triac can be controlled by adjusting the control signal, which can be done manually or through an automated system. Additionally, external components such as resistors and capacitors can be used to modify the control signal and, in turn, the firing angle of the triac.
5. What are the advantages of using a triac over other types of switches?
Triacs offer several advantages over other types of switches, including their ability to control both AC and DC currents, their simplicity and low cost, and their ability to handle large amounts of power. They also have a high switching speed and can be used in a wide range of applications.
18K
