Understanding Kirchhoff's Rules for Solving Electrical Circuits
  • Thread starter Thread starter member 392791
    Rules
When using Kirchhoff's rules, it's crucial to identify the direction of current flow through a resistor, which always moves from high potential to low potential. To clarify potential differences, start by marking the direction of the current; this will help determine which end of the resistor is at a higher potential. When traversing a resistor in the direction of current, a voltage drop of -IR occurs. Understanding these conventions is essential for solving DC circuit problems effectively. Properly identifying potential differences simplifies the application of Kirchhoff's rules.
member 392791
Hello,
I am having difficulty when trying to solve problems requiring kirchhoffs rules. The problem I seem to be having is following the convention used by my book. I can't tell when the current is gaining potential going across a resistor, or atleast going from low potential to high potential.
The problem seems to stem from not knowing which end of the resistor is at higher potential than the other, so I can do either +IR or -IR
If anyone can clarify, that would be great. Thank you
The current in a resistor always flows from high potential to low potential. So, once you mark the direction of the current through the resistor, the high potential and low potential ends of the resistor become obvious. Generally, when you are solving dc circuits, and you are required to find the current in a resistor, you start by marking the direction of the current. Then, you mark the high potential end and low potential end of the resistor in such a way that the current is flowing from high potential to low potential.
Select your loop. When a resistor is traversed in your chosen loop, along the direction of current, then there is a voltage drop -IR.
Thank you for the responses, much appreciated.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
