Vibration Isolation in Beams
In summary, the conversation discusses the need to dampen a boom arm attached to a vehicle, with specific requirements for deflection and acceleration. The suggestion is made to create a finite element model to determine the vibration modes and analyze the response of the beam to acceleration, in order to determine the best location and parameters for a damper. A final check is suggested using a transient dynamic analysis of the full FE model.
richard368
I wish to dampen a boom arm, which at its fixed point is connected to a vehicle (arm length is 5m long).
The boom is 'L shaped' is attached to the to of the vehicle and extends 5m in the horizontal, then the second leg hangs down 5m, almost to the ground. The end of the boom arms contains lead with an approximate mass of 1000kg. The boom itself is made from box section steel, dimensions are shown in the pdf.
The vehicle has a maximum acceleration, in this case, of 0.25m/s/s, I wish for the deflection at the end of the boom arm to be no more than +/-10mm.
Once a steady velocity of 0.4m/s is reached the deflection at the end of the boom arm needs to be no more than +/-5mm, within 3 seconds.
When modelling it by hand what do I need to take into account the rotation of the horizontal beam, due to torsion? What else?
I need to know I am correct with my evaluation of the displacement of the end of the boom firstly. Then I can model it on FEA to calculate what damper I need. Or can this be done by hand??
Please help
Kind regards
Henry
[PLAIN]https://www.physicsforums.com/newattachment.php?do=manageattach&p=
  • Boom arm.pdf
I did a quick hand calculation based on the dimensions in your drawing, and the mass of the beam itself was significantly bigger than the 1000 kg "load".
So, I would suggest the first thing to do is make a finite element model to find the vibration modes of the arm. You will probably find there are several modes that will contribute to the motion you want to control.
You could then make a 1-DOF model for each mode and find the response of the beam to the pulse of acceleration of the vehicle. That will show which modes you need to worry about, and you can then decide on the best place to put a damper and what its parameters should be.
A final check (to make sure you didn't ignore anything important) would be to do a transient dynamic analysis of the full FE model.
What is vibration isolation in beams?
Vibration isolation in beams is a technique used to reduce or eliminate the transmission of vibrations from one beam to another. This is important in structural engineering and construction to ensure the safety and stability of a building or structure.
Why is vibration isolation important in beams?
Vibrations in beams can cause structural damage, reduce the lifespan of a building or structure, and even affect the comfort and safety of occupants. Vibration isolation is important to prevent these negative effects and maintain the integrity of a structure.
What are the common methods used for vibration isolation in beams?
The most common methods for vibration isolation in beams include using damping materials, isolator mounts, and flexible joints or bearings. These techniques work to absorb, dissipate, or redirect vibrations to prevent them from affecting the structure.
How do you determine the appropriate level of vibration isolation for a beam?
The appropriate level of vibration isolation for a beam depends on factors such as the type of structure, the expected level of vibration, and the materials used. Engineers use mathematical models and simulations to determine the best approach for each specific case.
What are the benefits of using vibration isolation in beams?
The benefits of using vibration isolation in beams include increased structural integrity and safety, reduced noise and discomfort for occupants, and a longer lifespan for the structure. It can also prevent damage to sensitive equipment and improve the overall performance of a building or structure.
  • Mechanical Engineering
