Law of the lever: Conservation of energy or angular momentum
The discussion revolves around the law of the lever and its relationship with conservation principles, specifically conservation of energy and angular momentum. Participants explore the implications of these principles in both static and dynamic scenarios, questioning the validity of derivations based on energy conservation in the context of the lever.
  • Some participants argue that derivations of the law of the lever using conservation of energy may only work coincidentally due to the shared units of energy and torque.
  • Others suggest that the law of the lever can be derived from conservation of linear momentum or angular momentum, indicating multiple foundational approaches.
  • A participant notes that the static lever law can be derived without invoking torque, using only linear forces on a truss structure.
  • There is a mention of virtual displacements and the mathematical handling of limits in the context of the lever's operation.
  • One participant raises a broader question about whether the similarity in units between energy and torque indicates a deeper connection or is merely coincidental.
Participants express differing views on the validity and applicability of energy conservation in deriving the law of the lever, with no consensus reached on whether the derivations are fundamentally sound or coincidental.
Some limitations include the dependence on definitions of work and torque, as well as the unresolved mathematical implications of static versus dynamic scenarios.
greypilgrim
Hi,
Some "derivations" of the law of the lever argue with conservation of energy: If one arm of the lever of length ##r_1## is pulled by a distance ##s_1## with force ##F_1##, the other arm moves by a distance ##s_2=s_1 \frac{r_2}{r_1}##. From conservation of energy ##E=F_1 s_1=F_2 s_2## it follows $$F_2=F_1 \frac{s_1}{s_2}=F_1 \frac{r_1}{r_2}\enspace.$$
However, the law of the lever also holds in static situations where ##s_1=s_2=0## and no work is being done and above derivation breaks down. A derivation that both includes moving and static situations uses the fact that all torques must vectorially add up to zero which follows from conservation of angular momentum.
So I wonder if the derivation using conservation of energy only works coincidentally, because energy and torque share the same unit. From a Noetherian perspective, the derivations are very different, the first following from homogeneity in time, the other from isotropy in space.
As a more general question, is it mere coincidence that energy and torque have the same unit or is there more to it?
You can consider virtual displacements if you like.
The limit for ##s_2 \to 0## is well-defined and gives the same result. The attempt to divide by zero is a purely mathematical problem.
You can derive the static lever law without invoking the concept of torque, using only linear forces on a truss structure. There were several threads on this here.
That's interesting, so the law of the lever can actually be derived either from conservation of energy, conservation of linear momentum OR conservation of angular momentum independently, hence by Noether's theorem either from homogeneity in time, in space or isotropy in space?
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 53 ·
