B Imaginary Pythagoras
  • Thread starter Thread starter DaveC426913
The discussion centers on the validity of using imaginary numbers in geometric representations, particularly in the context of the Pythagorean theorem. Participants explore whether a triangle can exist in the complex plane with a hypotenuse of zero length, noting that while mathematically possible, it lacks real-world significance. The conversation touches on Minkowski geometry, where time and space are represented with imaginary components, and mentions the implications of using complex numbers in mathematical functions. Suggestions for further reading include resources on relativity and the distinction between real and complex analysis. The thread concludes with a humorous note about the title's pun.
DaveC426913
TL;DR
Is this geometry valid?
I posted this in the Lame Math thread, but it's got me thinking.
Is there any validity to this? Or is it really just a mathematical trick?
Naively, I see that i2 + plus 12 does equal zero2.
But does this have a meaning?
I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero?
Ibix offered a rendering of the diagram using what I assume is matrix* notation:
which I assume makes the apparent paradox go away, but does that mean the first diagram is not valid?
* never learned matrices
I suppose it is theoretically possible to have a triangle with zero length hypotenuse if you look at it edge-on in an abstract 3D space - i.e. the two axes are superimposed.
Mathematics news on Phys.org
A triangle in the complex plane would have the lengths of all of its sides as real numbers; i.e., as the magnitudes of the various quantities. ##|i| = 1##.
I'm not sure what the equation scrawled in the diagram is saying. Is the left side of the equation ##2^{ab}##? If so, I don't understand how that can be equal to a matrix.
If both legs are equal in size and one lies on top of the other, the hypotenuse of such a triangle would be zero, but that's not a very interesting triangle.
The problem here is, that ## i ## is not a length. If you write it as real vectors like in the Gaußian plane of complex numbers, then it becomes wrong. If you consider it as a complex equation, then it is correct, but lacks the interpretation in the real world.
You have two vectors in the complex plane:
##Z_1=(0,i)## and ##Z_2=(1,0)##.
Noting that ##Z_1-Z_2 = (-1,i)##, the magnitude of the hypotenuse squared is
##|Z_1-Z_2|^2=(-1,i)^*\cdot(-1,i)=(-1,-i)\cdot(-1,i)=1+1=2.##
This is the sum of the magnitudes-squared of the sides, ##|Z_1|^2+|Z_2|^2.##
DaveC426913 said:
TL;DR Summary: Is this geometry valid?
That's one representation of Minkowski geometry, where the vertical axis is time and the horizontal axis is spatial. The spacetime distance in ##c =1## units is given by:
$$(\Delta s)^2 = -(\Delta t)^2 +(\Delta x)^2$$This is sometimes represented using "imaginary" time.
PS the paths of zero distance are those followed by light.
Likes nasu and Mike_bb
Fascinating crossover. Can you suggest where I can read up on this more? (I'm not post-secondary edumacated, so the hard maths is over my head, but the physics may not be*)
*yes, the irony of the notion that these can be separated does not escape me.
This is essentially the difference between ##\mathbb{R}^2## and ##\mathbb{C},## and what distinguishes real from complex analysis: squares are no longer automatically non-negative. This has a significant impact on functions.
If you are interested in Minkowski spaces and a notation with imaginary time, then you should read about the Wick rotation. It translates between the two.
I recommend
Reflections on Relativity
Book by Kevin Brown
I recommend correcting the thread title! I assumed someone would have done it by now.
I assumed a pun attempt. "Pitagyros" is one I remember from my school days during more racist times.
I'm also rather un-edumacated so thanks for these suggestions.
There are many valid mathematical systems in use. You will need to define the rules where this is valid. Argand chose to make the imaginary axis at right angels to the real axis in the Argand Plane. The imaginary axis is associated with the real axis. The Pythagorean Theorum does not work in the Argand Plane since it is essentially a 1 dimensional object. However if you use the imaginary axis of one Argand Plane with the real axis of a different Argand Plane the example you showed is valid. Two Argand Planes can intersect in a single point at right angels to each other forming a four dimensional coordinate system. Which is what you have done.
Note the last diagram from my Insight https://www.physicsforums.com/insights/relativity-rotated-graph-paper/
As others have said, the 0-hypotenuse could suggest a lightlike vector in special relativity.
I don't use complex-numbers in special-relativity.
Below, I use real numbers with a Minkowski spacetime metric.
The vertical-3 is for a timelike-vector and the horizontal-3 is for a spacelike vector.
(The segments count the number of light-clock diamonds along the segment.
The choice of which diagonal distinguishes timelike from spacelike.
All light-clock diamonds have the same area... and are traced out by a standard light-clock carried by the piecewise-inertial observer.
The square-interval is the area of the causal-diamond between two events. It is zero for DF since the diamond is degenerate.)
Try Triangle-4 (You may have to scroll down.) Use the tool in Geogebra toolbar to decorate a segment with light-clock diamonds.
You can drop your own endpoints. Return to the cursor in the toolbar to move the endpoints of your segment.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 54 ·
  • · Replies 31 ·
