Undergrad Is there a bad intuition or bad explanation in quantum entanglement?
  • Thread starter Thread starter syed
The discussion centers on the complexities of quantum entanglement and whether current quantum mechanics (QM) theories are complete or merely reflect a failure of classical intuition. Participants debate if the inability to fully grasp entanglement indicates a gap in our understanding of reality or simply a limitation of classical explanations. The conversation highlights the inadequacy of common analogies, such as the shoe analogy, which oversimplify the nature of entangled particles. A proposal for a "Completed Classical Mechanics" (CM+) suggests a need for a more robust framework to reconcile classical and quantum theories. Ultimately, the dialogue emphasizes the ongoing quest to understand entanglement within the broader context of quantum field theory and classical mechanics.
syed
TL;DR
Title
I keep reading throughout this forum from many members that the general motivation for finding a deeper explanation within QM, specifically with regards to quantum entanglement, is due to an inability to grasp reality based off of classical intuitions. On the other hand, if QM was truly incomplete, and there was a deeper explanation that we haven't grasped yet that would explain why particles tend to be correlated to each other seemingly instantly despite vast separated distances, then that would mean our current theory simply failed to explain all of reality.
In other words, a failure of an explanation seems to suspiciously look the same as a failure of an intuition. So my question is for the people who propose that there is nothing more to reality when it comes to quantum entanglement, or that reality is fundamentally stochastic: how do you differentiate between quantum entanglement simply not obeying your intuitions vs. physicists just not having a complete theory of quantum entanglement yet?
syed said:
TL;DR Summary: Title
The question is whether the textbook and the more complete interpretations are truly complete, in the sense of being able to describe all the results of all possible experiments involving quantum effects. It seems a legitimate question, since we don't know in advance "all the results of all possible experiments involving quantum effects" to truly know if QM is complete in its domain.
Whether QM is complete or incomplete is a separate issue from seeking a classical explanation for entanglement (which contradicts Bell's theorem).
Well even regarding the second point, what's the difference between a "non classical" explanation and an incomplete explanation?
Here is a usual scheme for entanglement
  • There are two entangled particles.
  • Alice receives one of the particles, Bob receives the other one. Alice and Bob are far away from each other.
  • Alice measures the spin z of her particle, it collapses the result of spin z of Bob's particle.
The bad analogy of quantum entanglement that is repeated in most popular physics content:
  • There is a pair of shoes (it can also be gloves). The pairs are put randomly in two boxes.
  • Alice receives one of the boxes. Bob receives the second box.
  • When Alice opens her box, she knows instantaneously the chirality (left/right) of Bob's shoe before Bob opens his Bob. It is like if Alice collapsed Bob's shoe.
Why is it a very bad analogy:
  • You are basically explaining the entangled particles with a hidden variable model and there is no issue with that here.
  • You kind of want to imply that the particles, contrary to the shoes, were not defined before measurement, but where is that required here? Somebody that challenges quantum mechanics is not going to be convinced with this analogy.
  • There is only one observable (spin-z, shoe chirality). Any Bell-like inequality or even the orginal EPR paper have at least another incompatible observable (spin at different angles/position-momentum). This is key.
A better analogy: GHZ experiment as explained by Mermin device.
The idea that QM is incomplete whereas, presumably, CM is complete, has colored the foundations of physics for too long. I suggest that QM is complete in the sense that it has enough resources to model any collection of data from multiple experimental sources: that is, QM is empirically complete.
OK, so what about CM? I suggest taking the no-go theorems as an indication that CM is incomplete, which I suppose leads quickly to asking how CM could be completed to be as-complete-as QM? I presented such a completion well enough for it to be published in Annals of Physics in 2020, where I call that Completed Classical Mechanics 'CM+'.
The starting point for that construction as I had it there was Koopman's Hilbert space formalism for CM, which makes it possible to compare QM with CM in the shared mathematical context of Hilbert spaces. There are two key aspects, which can be characterized as
  • QM allows arbitrary unitary transformations whereas CM allows only the much more restricted canonical transformations; fixing this difference is straightforward and allows us to model incompatible experimental contexts in a classically natural way, as contextuality, within CM+. This change can be thought of as introducing the tools of Generalized Probability Theory into CM.
  • If we think in a more classical way, one clear question is "What the difference is between quantum fluctuations/noise and thermal fluctuations/noise?" An unequivocal answer to this comes from Quantum Field Theory: quantum noise is Lorentz invariant whereas thermal noise is not invariant under boost transformations. This difference can be used in a classical formalism, but it requires us to work in a Minkowski space formalism, which, together with a desire to match the physics of QFT pushes us into using a classical random field theory formalism.
That out of the way, let us consider the idea of entanglement. I think, crucially, that there is such an idea only if we have an idea of a Hilbert space as a way to model systems and their properties and an idea of a tensor product of multiple Hilbert spaces as a tool for modeling a compound system and its properties. In QFT there is no such idea in the Wightman axioms and it is only by rather hand-waving arguments that we can introduce tensor products (and partial traces, which are natural enough once we have introduced a tensor product). Everything we think we know about entanglement for non-relativistic QM models is tendentious for QFT models, so that my suggestion is that we will be better to come back to entanglement when we better understand the relationship between QFT and CM+.
The ideas in that article in Annals of Physics 2020, in another article in Physica Scripta 2019, and in another in Journal of Physics A 2022 (those are arXiv links, the DOIs for the published versions can be found there) are developed further in various academic talks. As far as I can tell, everybody in physics who comes across these ideas is waiting for someone else to tell them that it's OK or not OK: being published in a reputable old-school physics journal is only a very small step towards ideas becoming widely known (unless an idea makes it into Nature or PhysRevLett or into one a few other very select places). For three of those recent talks, with the most recent, for NSU Dhaka, being the most accessible, I'm told:
  • “A Dataset & Signal Analysis Interpretation of Quantum Mechanics” (Announcement, YouTube, PDF) Colloquium, School of Engineering and Physical Science, North South University, Dhaka, May 18th, 2025.
  • “A Dataset & Signal Analysis Unification of Classical and Quantum Physics” (Announcement, YouTube, PDF) Special Physics Seminar, Physics Department, Yale University, May 1st, 2025.
  • “A Dataset & Signal Analysis Interpretation of Quantum Field Theory” (YouTube, PDF) Philosophy of Physics Seminar, Oxford University, October 24th, 2024.
I emphasize that these do not present a complete story. It will take more than just my blundering about in a complex world to repair a century of misdirection. I don't even claim that I'm getting anything 'right'. This is my best attempt at valley-crossing, which I hope might give someone else the right push for them to do something much better.
Very interesting. One question: Are there differences between CM and CM+, or does CM+ simply represent the idea that CM is complete? Is CM+ a hidden-variable theory, or is it something even deeper?
QM is KNOWN to be incomplete, although not regarding entanglement (I make no argument either way on that) but rather because it cannot handle gravity. QM is incomplete because it cannot handle the actions of subatomic particles.
We need a merge of the two into a Quantum Gravity Theory to make both complete. It's possible that that will never happen.
Both are "complete" within their own spheres of influence.
Likes pines-demon and javisot
CM+ includes contextuality/measurement incompatibility, which allows multiple experiments to be modeled in a single algebraic structure, exactly as one finds in QM. This, I claim, is classically natural.
CM+ can be thought of as a hidden-measurement theory: though it begins as ordinary CM, it's more a version of thermodynamics by the end of my talks. Another way to think about how CM+ is different is that it's more like Signal Analysis than it's like CM: in the first instance there is no idea of a particle in signal analysis as an explanation for features of a noisy signal, which is different from CM, which begins with there are particles.
The idea that particles can be added later, if they can be justified, is closer to how QFT is than to how QM is. IMO, our interpretations ought to be addressing QFT in a natively QFT way instead of saying "for QFT everything is just the same as for QM".
If you watch some of that NSU Dhaka talk, which some people have liked and some have even liked a lot, let me know how you feel about it. You can have a look at the slides before committing to watching.
Allori has a nice overview of different types of explanation used in quantum foundations here:
https://www.mdpi.com/2624-960X/5/1/7
The two types we contrast in our papers and new book are constructive vs principle. If you want a constructive account of QM, you're looking for an explanation of entanglement via dynamical laws governing the behavior of microphysical objects (aka causal or mechanistic explanation). For example, in the kinetic theory of gases the temperature of a gas is understood constructively via the mean kinetic energy of the gas molecules. According to constructive approaches to QM, such as Bohmian mechanics, standard QM is definitely incomplete.
In contrast, quantum information theorists have developed a principle account of QM whereby its stochasticity is an unavoidable consequence of the observer-independence of Planck's constant h, and entanglement is not a dynamical effect due to some nonlocal or superdeterministic or retro causal mechanism, but a kinematic fact that follows from the relativity principle and Planck's radiation law. Accordingly, QM is as complete as possible.
As Allori writes, "people favoring different theories have profoundly different motivations guiding their search for a satisfactory theory, which leads them to favor specific explanatory structures."
Likes Peter Morgan and PeterDonis
So basically, on the "principle account" view, entanglement in QM is viewed as analogous to, say, relativity of simultaneity, length contraction, and time dilation in SR.
My reservation about this is that entanglement in QM seems to have consequences that are hard to view as "kinematic", such as violations of the Bell inequalities. Those seem analogous to invariants in SR, which are not just "kinematic".
Or, to put it another way, one can make predictions in SR without ever having to make use of any "kinematic" effects like relativity of simultaneity, length contraction, or time dilation: just use something like the tensor formalism that is used in GR. But I don't see any analogous way to make predictions in QM without ever having to make use of entanglement or the properties of entangled states.
Likes iste and PeroK
Exactly. Entanglement, superposition, complementarity, and randomness all follow necessarily from the relativity principle and the observer-independence of h, just like relativity of simultaneity, length contraction, and time dilation all follow necessarily from the relativity principle and the observer-independence of c.
The fundamental invariant of SR is the spacetime line element and the fundamental invariant of QM is the qubit. Those invariants entail the kinematic consequences listed above.
I'm not sure what you mean by this. Please elaborate :-)
In QFT, as in SR, I take kinematics and dynamics to be merged into a single 3+1-dimensional model of the world (my feeling is that anyone can choose whether to think of that as how the world really is or as a model.) We can still distinguish kinematics and dynamics for that kind of model if we like, but we have to introduce some kind of additional structure for us to be able to do so.
Further, in QFT, entanglement only becomes a concept for us to 'use' if we introduce tensor products and partial traces; doing that is nontrivial, so I prefer to think of the physics as about measurement results in a state that is constructed as a model of part of the world by applying measurement operators to modulate a vacuum state. The vacuum state is an ideal object that is nonlocally defined to be Poincaré invariant and, it turns out, applying measurement operators to modulate that vacuum state typically also has nonlocal (but manifestly Lorentz invariant) consequences.
I'm not sure I understand. The definition of an entangled state of a quantum system is simple: it's a state that can't be expressed as a product of states of subsystems. All you need to make that well-defined is a definition of the subsystems.
As a tensor product of states. If we consider the Wightman axioms, they do not mention tensor products at all. There is a very weakened sense in which we can construct tensor products for 'systems' that exist only at space-like separation to each other (because the algebras of observables for regions of space-time that are at space-like separation are required to commute by the Wightman axioms), but that is not the same as the concept of a system in QM, which persists for all time.
The Wightman axioms can be discounted because they do not have any interacting models in 3+1-dimensions, however the free fields that are the starting point for perturbation theory are models of the Wightman axioms and as of now there is no accepted alternative axiomatization for interacting QFTs.
The idea of subsystems and systems is adequately defined in terms of tensor products in QM, but I feel that QFT is where we should focus our efforts at constructing natural interpretations of quantum physics. Furthermore, given the issues that arise when we consider properties of subsystems for a state that is constructed as a nontrivial sum of tensor product states of the subsystems, I have found it worthwhile to reconsider those issues in a no-systems ontology of space-time regions in QFT, where entanglement is not an available concept. OTOH, I have been thinking in terms of QFT for over 30 years and it turns out that I often fail to explain well enough how I have found that worthwhile.
Ah, I see; you're really thinking in terms of QFT, not non-relativistic QM. In QFT the whole idea of the "state" of a system is problematic, so the definition I gave for an entangled state is problematic as well. You basically have to work in the non-relativistic approximation.
Likes Peter Morgan
This is a very interesting discussion. Do either of you know of references that compare and contrast standard (non-relativistic) QM with the non-relativistic limit of standard relativistic QFT? Can they possibly make differing predictions? After all, many standard QM texts "second quantize" the Schrödinger equation to arrive at the QFT of the many-particle equation for electrons. Shouldn't the electron-sector of QED limit to exactly this non-relativistic QFT and make the same predictions, including for entanglement?
I don't see why they would. My understanding is that non-relativistic QM is the non-relativistic limit of standard relativistic QFT.
My understanding is that it does, yes.
One aspect you might not be considering is that, in order to take the non-relativistic limit, you have to choose a particular frame. The usual choice is the rest frame of the experimenter's lab (in which, for example, the Stern-Gerlach devices you're going to use to measure the spins of a pair of entangled electrons, as well as the electron source and the detector screen, are at rest).
There might be some rigorous way to check, but the fact that we have many examples, makes it obvious that the two theories coincide at that limit (Dirac equation reduces to Pauli/Schrödinger equation, Mott scattering reduces to Rutherford scattering, beta decay through W boson reduces to Fermi theory, and so on.)
A while ago @bhobba pointed to an interesting paper by T Padmanabhan: "Obtaining the Non-relativistic Quantum Mechanics from Quantum Field Theory: Issues, Folklores and Facts" (https://arxiv.org/abs/1712.06605).
Likes Peter Morgan, renormalize, pines-demon and 1 other person
Was there a previous discussion on this paper?
bhobba first brought up that paper in 2021. What WernerQH refers too was probably in August 2025. He also brought it up on other occasions, but let's ignore those. I guess what you still remember is the occasion when I brought it up in February 2024, which was also a discussion of "the non-relativistic limit of standard relativistic QFT".
Likes pines-demon
Gentzen, thanks for investigating. :-) My copy of that arxiv paper is dated February 15, 2024. So I probably became aware of it also through Peter Woit's blog. But bhobba has been referring to it frequently.
The intuitions are not obeyed because they are erroneous. There are lots of examples of intuitions being incorrect within every body of knowledge, perhaps especially in physics.
For example, intuition tells you that objects in motion, when left alone, will eventually if not immediately come to rest. But we know that being at rest is not any different from being in motion in a straight line at a steady speed. Our intuition tells us that those two things are different, but they are in fact the same. There is a seeming difference, but that difference is due only to the relative motion of the observer.
Yes but we have confirmation that that intuition is wrong. In this case, we do not have a confirmation that entanglement does not have a further explanation
I thought that erroneous intuition was a claim implicit in your question:
See quote above.
So essentially, my question is for the people who say there is no further explanation to entanglement and that it disobeys our intuitions. How does one distinguish between this and there being a further explanation?
In other words, something could be true and remain counter intuitive, but also false/incomplete which is what leads to it being counter intuitive.
I don't know. This is a philosophical question. Not physics.
I don't think physics can decide this for you.
How about Glaeson's theorem? It means the state is a vector space, which is the rock bottom of entanglement, and as an aside, why QM is probabilistic.
The paper I linked to shows that conventional QM is not the limit of QFT; it is a non-relativistic approximation to it. It can be put in an equivalent form closer to the limit of QFT:
https://faculty1.coloradocollege.edu/~dhilt/hilt44211/AJP_Nine formulations of quantum mechanics.pdf
The limit of QFT is closer to interpretation F. The issue is that it does not require antiparticles, but it would be relatively easy to incorporate them. The point is that modelling observations by operators has these 'weird' implications.
One of the issues here is that some people seem to have trouble with the idea that a mathematical implication can be an explanation.
I have pondered these profound questions for years and have gone through various phases. I understand why people discuss them. However, now, towards the end of my life (I'm 70, not in my 50s when I first started posting here), I think the math itself is the reason.
Thanks
Bill
Thanks
Bill
Math is a language, and in most areas of physics we combine it with theoretical constructs to give an ontological picture. Why should quantum mechanics be different: why should we be satisfied with just the math here when we expect more in other theories?
As an example, we speak of a continuous electromagnetic field that exists everywhere in space, carrying energy and momentum. The equations could be treated as mere computational tools, but the field concept gives a physical entity we can picture. Or in general relativity, weinterpret the math as a dynamical spacetime geometry (space and time themselves bend and stretch), and matter follows geodesics in that curved geometry.
syed said:
How does one distinguish between [there is no further explanation] and there being a further explanation?
By proposing a further explanation. Until this happens there is no explanation, just as a book does not exist until someone writes it.
Likes Peter Morgan, bhobba, Lord Jestocost and 1 other person
  • · Replies 32 ·
  • · Replies 54 ·
  • · Replies 292 ·
12K
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 37 ·
