Why is water pressure increased in a plastic bag in a bucket?
The discussion revolves around the phenomenon observed by pottery students regarding the rehydration of clay when placed in a sealed plastic bag submerged in a bucket of water. Participants explore the reasons behind the increased effectiveness of this method compared to other approaches, focusing on concepts such as pressure, density, and potential chemical interactions.
  • One participant notes that when clay is placed in a bag of water and submerged in a bucket, it becomes fully permeated within two days, unlike when it is simply placed in water.
  • Another participant suggests that temperature differences might play a role, although they acknowledge that the water is from the same source and at room temperature.
  • A participant introduces the idea of displacement and density, proposing that the pressure from the surrounding water in the bucket may enhance the water's ability to infuse the clay.
  • One participant conjectures that hydrostatic pressure may not significantly impact the water infiltration process, suggesting that capillary action could be more influential.
  • Another participant raises questions about the differences between the water inside and outside the bag, speculating on factors like pH and gas content that might affect clay hydration.
  • Some participants discuss variations in methods, including adding water inside the bag or using water with clay suspended in it, to enhance the rehydration process.
  • Concerns are expressed about the permeability of the plastic bag and whether it allows for gas or water exchange, with one participant seeking clarification on this point.
Participants do not reach a consensus on the mechanisms at play, with multiple competing views regarding the roles of pressure, density, capillary action, and chemical properties in the rehydration process. The discussion remains unresolved.
Participants acknowledge limitations in their understanding of the underlying physics and chemistry, including assumptions about the properties of the materials involved and the effects of water pressure and density on the clay's hydration.
ImaginaryTango
TL;DR
If I put clay in a bag of water, tie it up, put it in a bucket, the water permeates the clay - but why doesn't it do that in a big of water or just in the bucket alone?
I'm not a physicist or even a physics student, I'm a pottery student and there's a conundrum that's been puzzling potters in my area for a while. We've found that if a block of clay dries out, the fastest and best way to revitalize the clay is to put it in a bag of water, tie the bag so it's sealed, then put it in a 5 gallon bucket of water. In the diagram, that's D:
If we take the clay and put it in a bag of water, like in B, and let it sit for several days, the water has permeated the outside layers of clay, but only about 1" into the block. The same with C - if we take the clay and put it in a 5 gallon bucket of water, only the outer inch gets revitalized (or, probably a better term is remoisturized). But if we put the clay in the bag of water, the in the bucket, as in D, and fill it to the same level as we did in C, within 2 days, the entire block of clay is good for use - water has permeated through the entire block.
I've tried asking this in some physics forums and been told it's a chemistry issue, but when I ask in chemistry forums, I get responses that say something along the line of, "I think it's because..." but never a clear answer. (I've also had physics forums reject it because I couldn't include images in the question or had to ask the full question in the title and didn't know how to summarize it clearly in that short a space.) From what replies I have seen, it seems like it has something to do with pressure, but I don't understand why there would be more pressure in D than in C. (Or, even, since it's not even 18" of water depth, in B.)
Why does the clay get fully permeated in D but not in B or C?
Could it be a temperature difference? 18” of water is about 0.05 atmospheres, so it is some pressure but not a lot.
Good thought, but the water is from the same source. I know when I do this, I fill the bag, tie it off, then fill the bucket. And since it sits for about 48 hours, in my studio, it's at room temperature.
------ Added: -----
I wrote a long edit to this reply that got deleted - which may be just as well. I think it has to do with displacement. You have the water density, the density of the dry clay, and the density of the clay when it's infused with water. There's also the density of the clay around the edges when only those edges have been infused.
I think the density, from least to highest, would be:
1. Water
2. Clay
3. Infused clay
4. Clay edges infused with more than "normal" water. (And 3 & 4 might be reversed - not so sure!)
In B and C, when you put the clay in the water, it displaces water and the water and the outside water will have enough pressure to push water into the clay. As it does, the amount of water displaced goes down. Here's the part I'm unsure of, and I think the water infuses only into the clay to the point where the water pressure on the clay is no longer strong enough to infuse the clay anymore. (I've also tried to think through this and can see that the water infused into the outer edges of the clay may be equal to something to do with the difference of density of the clay and the density of water.)
The same thing happens like this in both B and C.
In D, you put the clay in the bag and seal it and you have the clay displacing water in the bag. Then you put the big in the bucket and the bucket water will apply enough pressure to try to make the bag shrink ot the size of the amount of water being displaced. So now the water in the bag is not only creating pressure to infuse the clay, but it has outside pressure that will push on the bag to try to make it as small a displacement as possible.
Now there's the inside pressure in the bag, that is pushing out against the bag, but also into the clay. But as long as it can continue to push water into the clay, it will not be pushing against the bag and against the bucket water pressure until as much water as possible has been absorbed by the clay.
So the displacement of the bag in the bucket is going to add extra pressure on the water inside the bag to reduce the displacement of the clay and that will be more pressure than what you get when you put the clay only in the bag or in the bucket.
The hydrostatic pressure at the clay surface will be the same whether the clay is enclosed in a bag, or free. While higher pressure could be of value, I conjecture it probably is not of great importance in this experiment, being of such low head.
The action of water infiltration is less sensitive to the water pressure, than it is to capillary action as the water moves into the clay pores, and from pore to pore as the clay is rehydrated.
A plastic bag is not impervious to gas or water, some types of plastic being less or more so depending upon composition and thickness.
Situations B and C are the same - a clay form surrounded by water.
D is different in that the plastic bag is employed as a permeable membrane allowing gas, water, perhaps ion exchange between the fluid within the bag and that without. ( within and without should be antonyms, and if not, I just made then so ).
Question is what is the difference between the two separate waters that would allow more water infiltration into the clay. Has the pH level changed due to dissolution of clay salts or compounds rendering the clay less hydrophobic in a general sense? CO2 content, O2 content?
I am throwing out some chemistry. Hopefully some will stick. What the actual mechanism truly is might be found with testing the water content of the interior. ( personally, I lean to pH, as clays are more basic than acidic, but that is only a hunch ).
Did you actually try C?
In several articles about this process I've found, they add a bit of water inside the bag to moisturize the clay and add water outside the bag for pressure.
E.g.,
One could do a version of C, but not with initially clean water, but water that already has as much as possible clay suspended in it.
Small point - what I'm doing is basically what a lot of the local potters do, so you could say I'm following "tradition" or "local lore."
I haven't, but I know others who have. I also have not tried different amounts of water in the bag, since others have said, "This works," and I tried it and it did - filling the bag with water until it comes up to near the top of the clay, maybe even over. The bags are the bags the clay comes in, so there's often not a lot of extra space in the bag. In the local community, we don't put any holes in the clay itself, like she does in the video.
I check my bags after 48 hours and it's in good shape for use. Again, I went by what others said - give it a couple days. It could be just fine after 24 hours, I just haven't checked it that soon.
I'd like some clarification or expansion of this point before moving on, since it's confusing me. When I fill the bag with water, and I've tested this, I don't see any signs of water permeating the bag. Before using a bag, I fill it with water, tie it off, dry it with a towel, and leave it in a dry 5 gallon bucket, check later to see if there is any water on the bag or in the bucket. Then I move it around and leave it again. (A few times I did this, thought a big was in good shape, only to find a pinpoint leak that wasn't leaking due to the position of the bag in the bucket.) While I don't think this applies to anything in the discussion, I have found that if there is tiny leak in the bag itself, it doesn't work. I'm not disagreeing with you - I'm asking for more information about this.
I don't see how there could be any difference between the two waters at the start. I have a sink in my studio with a curved high water spout. I put the clay in the bag, fill the bag with water until it comes close to covering the clay, then tie it off. Then I put this in the bucket and fill the bucket. So the bag and bucket are filled from the same water source, with less than a minute between them. As for any changes in the water, yes, there could be something from the clay that dissolves within the bag. I don't know and I wasn't thinking in terms of chemistry, so I don't have pH strips to test the water. And, yes, maybe there's a change in the bucket water. I could see that maybe the outer one releases air trapped in that water over the next few hours, and in that bag, any released air might stay in the bag or might permeate the bag and escape.
But if something is dissolving from the clay and into the water, I would think that would work the same if I just used B or C. (And, you're right, they're the same - but I did try both ways and neither worked.)
Reading what I just quoted from you and this part over again, it raises a question in my mind about possible gas in the glay as the clay dries out. I don't know how that would interact with anything in this situation, though. I can imagine a few things, like maybe for some reason, in B and C, as it dries out, and maybe air makes its way in where the water was (wondering about this - since there's really no noticeable shrinkage as the clay dries out - there is notable shrinkage when I throw a piece and leave it out in the open air to dry out. But that's out in the open air for a good while. (Again, I know my experience in this is quite limited - I'm just adding points like that in case they matter to those who know physics or chemistry or both.)
I'm fine with that - my whole thing about displacement and pressure was an attempt to throw out what I thought might be involved. And I may not have quoted or replied to your point about capillary action, but I think that's an important point: What is creating an effect on capillary action in D that isn't there in B or C? I can test pH, but I don't know what else I can test.
I'm thinking if I do testing, that may be tricky, considering how much clay I used over the holidays, for making presents, and what's left. Seems to me I need to take one type of clay, cut the brick in half, put one half in something like D and one in something like B and test the pH in them after, what, maybe 12 hours? That way we'd be sure that there is or isn't a pH difference between B and D. (Don't see a need to test C, since we're talking about the change inside the bag.)
I think you're thinking along the same lines as @256bits with that - what makes the water different chemically. Playing the devil's advocate here, but I can think of 2 points that might indicate that the used water is an issue is that I would think that leaving the clay in for 48 hours or so would lead to clay suspended in the water in C. And that's something we've discussed locally - whenever we've done B or C, even leaving it in for extra time, the water only permeates into the edges (and maybe 1" inwards) in the clay.
If you have a sous vide you could test temperature dependence. Room temperature and residential water temperature can fluctuate. I don’t think that variable has been adequately controlled
Yes, but C doesn't have the same suspended clay concentration as D, where the suspended clay is prevented from dissipating throughout the whole bucket by the bag.
With regards to B vs D: Is the bag really so full of water, that it has the same shape as in D, as shown in the picture? Or does it sag to the bottom, and stick to the clay at the top?
What about the possibility that capillary action is responsible?
By itself, capillary action will tend to draw water into the clay. This will tend to expel any entrained air. If the clay is entirely immersed, there is nowhere for the entrained air to go. It is trapped and will be under some pressure. At best, it can attempt to bubble out the top. But surface tension will resist bubble formation. If, on the other hand, the clay has a surface exposed to air, then the entrained air has an exit pathway. Capillary action can then fully displace the entrained air.
The plastic bag is helpful because it ensures that air inside the bag will reach 100% relative humidity. The exposed clay will not dry out.
Pore size of plastic film is very small, much more so than the experiments that show the surface tension of water not allowing water to escape say from an eye dropper.
some literature.
https://www.researchgate.net/figure...tic-films-used-in-packaging-17_tbl1_225207929
Polymers and plastics are permeable and their barrier properties may impact their suitability for a specific application. In packaging, for example, ineffective barrier properties for plastic films may render the enclosed product vulnerable to surrounding environmental factors, such as water, humidity, and oxygen, including its future storage.
https://www.intertek.com/polymers-plastics/barrier-properties/
The main gases that affect the shelf life and packaged stability of most products are oxygen and water vapour and so we provide Water Vapor Transmission Rate (WVTR) via industry established methods ASTM D1653, Water Vapor Transmission of Organic Coating Films and ASTM E96 Water Vapor Transmission of Materials. We can also provide testing to ASTM F1249, Standard Test Method for Water Vapor Transmission Rate Through Plastic Film and Sheeting Using a Modulated Infrared Sensor and ISO 15106-2, Plastics - Film and sheeting - Determination of water vapour transmission rate.
The Oxygen Transmission Rate (OTR) is an important determinant of the packaging protection afforded by barrier materials particularly for film, sheeting, laminates, coextrusions, or plastic-coated papers. We measure the OTR via ASTM D3985, Oxygen Permeation of Flexible Barrier Materials Using a Coulometric Sensor ASTM D3985, ISO 15105 to determine the permeability coefficient, permeance and transmission rates.
I thought of that also.
The water-water plastic film can be important for molecular water and gas transport, more so than an air-water plastic film.
Maybe, depending upon what's happening.
I mentioned capillary action in post 4. It is how the water moves from pore to pore in porous medium, much like paper sucking up water. Clays will do the same, as well as sand at the beach, up to a point where the capillary pressure matches gravity. The surface tension of water will draw water along a surface, and thus from pore to pore.
256bits said:
Why the bag has an effect upon that is the question.
What is the evidence that it does?
That is a valid application of without, yes.
I'd kind of like to see the OPs test results duplicated. It would rule out experimental error and also provide some numbers to work with.
Or is this already a well-known phenomenon?
By that video from post 5 it appears to be a known phenomena.
The video in post 5 does not show the experiment C.
An expose on clay for anyone interested.
Some aspects of the chemistry of clay - types, weathering hydrolysis of rocks, hydration of clay, pH affect on platelet permanent charge or variable charge platelets.......
https://www.intechopen.com/chapters/76780
That is the proposal in the opening post.
Whether the plastic bag acting as an permeable membrane allowing ion exchange, electron exchange, molecule exchange affecting the solute-solution concentration. or by other means such as flocculation, within the bag is where I started as an investigation, and in turn the rate of hydration of the clay. Actual data is surely not available as to support or deny any claim, except that of the opening post.
In addition, can such a claim be made for all types of clay material.
But it does show D, the method of increasing the rate of hydration from the other methods.
Under uncontrolled conditions, D seems better than C.
Under controlled conditions, that may or may not be true.
ie is the permeability of the bag relevant -
ie is temperature relevant - hydration should be exothermic, is the bag water getting warmer, @Dale
Wow! Thank you for all the replies. I'm still going through them. I have done some quick scanning. I don't have much in terms of equipment and I'm surprised this wasn't just something with a simple answer! I'm not complaining - I just was sure there would be some simple explanation about pressure and displacement. I like that I'm really going to learn a lot from the help here!
Before I start replying to posts, one thought: Most potters do this by dropping the bag of water and clay into a 5 gallon bucket. My teacher was just telling me how one potter drops it in her husband's hot tub. He has not complained about that or found problems like finding clay particles in the filter or that it changes the water by feel, color, or smell.
I don't have one. I see what you're saying about temperature. This happens in my studio and pretty much any potter's studio that knows the trick. I would think, though, that using water from the tap with less than a minute break between filling the bag and filling the bucket would mean the water for both is around the same temp, wouldn't it? And if it works for all potters, some who would use cold water, some hot, and in different studios with different temps, wouldn't that indicate temp is not a major issue - except, maybe in the speed of the recovery?
Note that they both seem to have about the same effectiveness, though - they infuse the clay a ways in, maybe as much as an inch.
Uh - well, I'm not really that much of an artist and not good at drawing! So I just used the square shape because it was quick and easy. But the clay bags are not much bigger than a full block of clay. However, there are times when you're recycling half a block. I fill the bag until the water almost covers the clay. The video linked to above uses less water. I hear some cover the clay. I try to squeeze as much air out as I can. But, yes, some water will make the bottom of the bag spread out and the top, where I tie off the bag, it fits closer to the clay in it. But there is water (at least when I do it) around the clay up until near the top of the clay.
Gavran said:
He's close. I don't know anyone who puts the first bag in a 2nd bag. And I'm not so sure he knows what he's saying when he says the outside pressure pushes the water in. Apparently it does, but how? And why is it that just using method C in my graphic doesn't do that?
I can follow that reasoning and see how it makes sense. I don't think anyone puts clay in water but leaves the top uncovered. But if you put the clay in a bag of water, generally there's still some air there and I would think the air would be able to escape. But this leads to why does D work and not B, by itself?
I suspect you're onto something about the capillary action, but I don't know.
Okay, I need to rephrase that to be sure I follow the point you made in that post, including with the table and literature included. So if I have a big of water, water doesn't leak out due to surface tension, but if that bag of water is in other water, then water could permeate it and water from inside could seep through to outside? I think that's a good point. I don't know how the particle size for clay compares to water molecules, but when I pull the bag of clay out, I see no sign of clay particles in the bucket. Granted, it could be so little I don't see it, but the water in the bucket, at that point, is clear and when I pour the water out of the bag, it's clay colored.
It's well known. Not only from the video, but it's at least local lore. A lot of the potters in this area do this. I think, since it works for us all, that would indicate that water and room temp aren't a big issue since, after a few hours, all the water and the clay are at room temp anyway. Although, as I mentioned in this post, one potter puts the bag in her husband's hot tub. I don't have a way to find out from her how long that takes and if it's faster than what the rest of us see.
Most pottery students, before we learned this trick, have tried both B and C. The results for the 2 are the same: Infusion around the edges, not inside. But, along with that, nobody has compared if infusion is deeper in C than B.
After reading what you included about the bag as permeable, I wonder - could it be that with the bag in water, something, ions, particles, anything, is able to leave the bag in D when it couldn't in B due to surface tension? As I mentioned, though, there is no indication of anything visible in the bucket water in D after the process finishes. But it could be air comes through there. I don't see bubbles on the bag when I empty it all, though.
I don't know at all how this works other than for the clays most people work with by hand. So if there's clays used for industry, that might be something entirely different.
But as we go over this, and since pressure doesn't seem to be a major factor, I have to think the permeability may be a big factor (if I understand it correctly). In my limited understanding, I'm wondering if it could be air or something ionic. Or maybe water permeates through the bag and clay doesn't, which might mean more water comes in to the bag than was there at first, or some water leaves, upping the concentration of clay particles.
I'm not so sure it's just about rate. It's possible that B and C might work if the clay is left for a week or so. My classes at the studio are weekly and when I've had some chunks of clay in there that got too dry, I sprayed the outside of them with water, then put them in a bag and left them a week. The outside edges hydrate, but not the inside, so I mix it and do again. It takes several weeks for this method to work.
Regarding temp, I would say most potters are doing this in an indoor studio, but sometimes they don't heat their studio when they're not working. I would think the whole system would end up at room temperature after a few hours, wouldn't it?
The idea is that with water on all sides, the clay is effectively sealed. Any air in the lump of clay cannot escape without forming a bubble in the surrounding water. No bubble can form because surface tension prevents it.
The pressure that it takes to inflate a bubble increases as the bubble size decreases. For a sufficiently small bubble, significant pressure can be resisted.
That is why B does not work.
In case D with the clay in a bag, there is likely a portion of the clay surface exposed to the air. Air in the clay can be expelled through this surface without the need to create or inflate a small bubble.
Putting this together with the next paragraph, then it seems to me that B should work if there is some air left in the bag so the top of the clay is in that air pocket. Is that right?
So D would depend on the bag not being filled completely and having air in there?
TL;DR: If I put clay in a bag of water, tie it up, put it in a bucket, the water permeates the clay - but why doesn't it do that in a big of water or just in the bucket alone?
The drawings seem to indicate an air pocket in the bag. Is that the case?
I though B & C have about the same effectiveness, while D works better than B & C. I was comparing C & D above, not B & C.
If D works better than C, just by having a bag-wall closer to the clay, than the container walls in C, then it's likely because the bag prevents/slows some kind of exchange/transport in the water that happens more in C than D. It could be ions, heat, gases or similar. To narrow this down, one would have to do controlled experiments, while measuring temperature, pH-level, pressure, etc. in the bag-water for D vs container water for C.
There is some. Like I said, I have no drawing skills, so I used an easy paint program. Generally I (and I hear other potters) will try to squeeze or burb the air out. But most of the time you're working with a cube or partial cube of clay - or lumps of it, and you're not going to get all the air out of it. I fill the bag to almost cover the clay, but not completely. Now that this could be part of the issue, I realize I've never asked if any potters cover the clay with water. I'm pretty sure local "lore" is to partially fill the bag.
If I misstated, I got the letters confused. To clarify: B & C have the same results: The outside part of the clay absorbs water, not the inside. Sorry if I got things mixed up!
Also, again, D works better than B - but I think that's covered when you say the bag prevents or slows some kind of exchange - but wouldn't it be that it allows or speeds up an exchange, not slowing it down?
And it sounds like you're saying that without more information, we don't know. Is that right?
Do do a full controlled experiment would be tough for me due to the need for regular measurements and tools I don't have. Also, another issue is to make the experiment fully controlled, I'd have to use the same clay body in each one and dry out the cubes of clay in the same fashion. So it's not just the water factors, which would be hard to control and measure here, but the clay factors - and those would be even harder to control.
I see there are also chemistry forums here. Is there a way to cross post or maybe I should copy this post and put it in the chem sections? Or tag some people there and ask them to look here? I don't know how much of a crossover there is between sections.
  • · Replies 16 ·
  • · Replies 32 ·
11K
  • · Replies 39 ·
16K
  • · Replies 29 ·
