How many carriers for phased array?
  • Context: Undergrad
  • Thread starter Thread starter Esquilo
Esquilo
Good morning, I haven't been to the forum in a while and I've been having problems with my email. I hope everything is fine now. As per the title, I'd like to create pulses (5Hz - 8Hz) in specific regions of space. For example, 5Hz arrives in one area, and 8Hz is nearby. To create this effect, I'd like to use phased arrays with 16 patch antennas, but I'm unsure whether to use a single carrier frequency of 800MHz and then pulse at 5Hz and 8Hz, or use two carrier frequencies to avoid interference between the spaces. So, how many carriers should I use to avoid interference between the spaces
I think you might as well go with two carrier frequencies. Either way, you will need two beam-forming circuits that are independently gated then added together. Especially with only 16 elements, you should get fewer artifacts with separate frequencies - you will avoid regions of unintended persistent constructive or destructive interference..
Can you say more about the application? How "nearby" are the two areas, and how far are the areas from your antenna array? Why have you chosen 800MHz as the carrier frequency? What sort of receiving things are in the two areas?
Thanks for your reply, using two carriers, one 800 MHz pulsed at 5 Hz pointing to one area and one 700 MHz pulsed at 8 Hz pointing to another area, if the two waves interfere in a space of a few centimetres I get the beating of the carriers (100 MHz) and the beating of the pulses (8,3,5,13 Hz) so too much interference
chose the 800 MHz frequencies because they are more manageable as a technology and also have a fairly wide half-wavelength of about 23 cm, so the areas to be focused are half the wavelength of the 800 MHz carrier, the application is musical and will not affect living beings in any way, I do not want interference (or as little as possible) when the two areas interfere, so to have the least interference I have to use one carrier or two carriers??
Perhaps I don't understand exactly what you are aiming for, but the "beating of the carriers (100 MHz)" isn't commonly considered a problem. In fact, I thought you would want to stay in a narrow band - so I was thinking something like 800MHz and 800.1 MHz.
And now that you are posting that you are concerned about this beating showing up in the audio - it should be of no concern. You should have a low pass filter that will kill anything above 20KHz.
800 MHz and 800.1 MHz are always two carriers, it's not the difference that interests me, I would just like to understand in which situation there is less interference using two beams, in the first case we have two beams with equal carriers and each different pulse, and in the second case we have two beams with different carriers and also different pulses, in which of these two cases there is less confusion or noise using a phased array
There is a way to compute a minimum hardware solution to the problem.
I think you must first specify a map of the target area, with the critical signal and separation levels that must be met. That mapped space should be specified by angles in azimuth and elevation, centred on the bore-sight of the array.
Once you have specified the critical levels in dB, in the places that matter, and maximum floor where it does not matter, the map can be deconvoluted using 2D FFTs to give the minimum source phased array, that will generate the required target fields, when excited by the two carriers.
An alternative for a narrow field, would be to use monopulse like design, where you have two elements, one on each side of the focus of a parabolic dish. Each element is then driven by a separate carrier, with dish size and element separation causing inter-fingering of the far fields.
You have presented a problem that is 100 years old. How to build a blind landing system for aircraft, or generate a beam navigation system for bombing your enemy.
https://en.wikipedia.org/wiki/Lorenz_beam
https://en.wikipedia.org/wiki/Battle_of_the_Beams#Knickebein
What device are you using to detect these pulses?
Can that device be tuned to either carrier frequency?
When you device is tuned to a carrier frequency, how wide is the channel that it is receiving? Since that frequency channel does not have an abrupt low and high limit, it is usually plotted out or described in more detail.
If the two receivers are able to reject signals that are 50KHz away from their center carrier frequency, then there will be no cross-channel interference. Each receiver will hear it pulses and not hear the other pulses.
About that 800MHz:
I am guessing that you will be implementing this with delay lines that are simply coax cable lengths.
Your wavelength will be 37.5cm and you will be doing your beam forming by pre-calculating the phase differences and cutting the 16 cables for each frequency by hand. Your patch antenna elements should be spaced out in 18cm intervals.
I see from your Profile that you are in Germany. I have designed and qualified RF products for use in Germany, and 700-800MHz definitely lies within the regulated frequency bands. What is your strategy for transmitting RF energy in these regulated bands? What ramp shape and duration will you be using to turn on and off your transmitters to avoid generating harmonics in other bands?
What are the receivers for these transmissions? Are you just turning on and off lights or sounds or something with this? If so, why no just use IR transmissions from the transmitter(s) to the receivers to accomplish the same thing without having to do the very involved RF qualification work?
[Post edited by a Mentor to remove accidental inclusion of the non-translated version of the below text]
About that 800MHz:
The system for detecting the signal is also an antenna as a receiver, the channel width must not exceed a quarter wavelength, my system is similar to the theremin but I would like there to be little interference in case the two signals interfere in space, considering the fact that I will hold the receiving antenna with my hands, and I could alter the diffraction and in some points the wave shortens or lengthens, because obviously it is not always perfect, so in which of the two cases do you get less background noise if there were interference?
use a phased array for this very reason, to keep the signal in the Fresnel zone within a meter of the source and thus not interfere with the regulated bands, the pulse rises are pulsed and therefore rectangular, and the receiving system is a similar antenna, but I will pick it up with my hands and these in contact with the 800 MHz could create diffraction problems and therefore shorten the waves which is why they could interfere, so in which case there would be less interference??
What is your planned transmit power in dBm? What is the maximum allowed RF level detected for Germany's Level A and Level B tested at 3 meters in dB?
That is probably not going to work, since you will be generating harmonic noise in other bands.
You need two radio receivers.
Each receiver will include an antenna and some circuitry.
The channel width is described in Hz. So, if one of your receivers is tuned to an 800.1Mhz center frequency, then it will be sensitive to a range of frequencies around 800.1MHz. To make this simple (and it isn't this simple), if your receiver channel width is 80KHz, then when tuned to a center frequency of 800.1MHz, it will respond to signals in the range of 800.06 to 800.14MHz.
A theremin - so one of those two frequencies will be controlling pitch, the other volume. You will have two receivers. I believe theremins are controlled by capacitance - but your will be different.
I don't think we need to get into exactly how you will design your theremin - only on those two radio receivers you will be using.
57 and 47 dbm at 3 meters, yes you are actually right with square signals I have many harmonics and therefore a lot of noise I will have many filters I will see what to do
yes I should use maybe more than two receivers, I could make a system similar to metal detectors but it would be too difficult, and as berkerman said I would generate too many harmonics with the pulses, so I think my idea is too complicated for me to implement
Yikes, you may be missing a minus sign or something there... :wink:
From a Google search on VDE Level B at 3m test distance:
216 MHz – 960 MHz: 46.0 dBuV/m (Quasi-peak)
So you still need to do the conversion to dBm, but 47dBm is crazy high.
I finally saw that your application is a theremin, so I'm even more confused now but I'll try do some reading about that when I get a chance. If it's all near-field stuff around your hands, you may be able to use a low enough Tx level that you will obey the regulatory requirements for RF transmissions. But I guess I'm still not understanding how 800MHz is good for detecting human hands (or water, etc.). It seems like using the "microwave oven" ISM band would be better for that, but again, I need to do more reading.
I finally saw that your application is a theremin, so I'm even more confused now but I'll try do some reading about that when I get a chance. ... But I guess I'm still not understanding how 800MHz is good for detecting human hands (or water, etc.).
I wasn't going to get into his theremin design. But if we do, why would we use a phase array instead of two or three directional antennae? This really looks like a rabbit hole.
@berkeman @.Scott Yes, I've checked more closely these past few hours, and the theremin solution is the most efficient. I'll definitely be thinking about using Huygens metasurfaces or similar superlenses that can overcome the diffraction limit. I don't know much about them yet, so I can't talk about this topic right now. But as soon as I've studied the topic more, I might create a new thread on metamaterials that overcome the diffraction limit.
If you pulse one carrier at both 5Hz and 8Hz you are, by doing this, causing a mixing process between the two pulse trains. In effect the two pulse trains are being applied to an AND gate. On the other hand, if you use two carriers, the total power received by an observer will now have three levels, two, one and zero.
It's not clear (to me) what you actually want to achieve . I think it would be necessary to specify what the system needs to achieve before deciding on how to achieve it. A diagram always helps in these cases and avoids people chasing off in random directions.
Afaics, to approach a steered array system then you should really think in terms of phase, rather than frequency; the two are equivalent, of course, but it's phase that determines the pattern of the array. Two frequencies will produce a sweeping pattern that's governed by the frequency difference, a constant phase difference will produce a fixed pattern, which you can vary as you please.
To produce a (controllable) phased array, it would involve a number of transmitters (one to each antenna) and drive them with a common rest frequency. Then you would phase modulate them with appropriate signals.
Any 'beat' between received signals will only be detected if the receiver bandwidth is as wide as their frequency separation (it's the vector / phasor sum of signals that produce whatever beat that's observed)
renormalize said:
A standard Theremin uses 3 oscillators, two working at about 260 kHz and one at 450 khz. Nothing oscillates at nearly a gigahertz. See:
https://web.physics.ucsb.edu/~lecturedemonstrations/Composer/Pages/60.17.html
Haha. 'They' didn't have GHz available to work with when the Theramin was invented.
This is all at a very low frequency so I feel that all that could be done with software (Software Defined Radio). None of that beastly soldering with many plugs and sockets and wires.
@berkeman @.Scott @sophiecentaur @tech99 @renormalize Good morning, here I am again, I had created a new thread on the same topic but it was rightly deleted, so I have to continue here, yes so continuing on a theoretical level with my project, always considering a planar array with a side of 50 cm, in which the cavity patch antennas are divided into two groups, the first group with a carrier of 800 MHz and amplitude modulated at 5 Hz and the second group with the same carrier but modulated at 10 Hz (example values) to create beats, so in your opinion is it better to use cavity patch antennas with a size of half wavelength or a quarter wavelength??
The "beats" you refer to are only beats when your receiver looks at the vector sum of all the signals. You could look at the process in terms of an interference pattern which sweeps from side to side to side but you need a non-linearity (or demodulator of some kind) to cause a beat. What will the analysis software do to achieve what you want?
I feel it would be better if you state precisely what you want in the way of your phase-driven pattern and then decide the best way to achieve it. All your elements could be driven from the same transmitter and the phases of each element could be varied to achieve what you want.
@sophiecentaur Thanks for your reply. So, yes, the receiver question isn't very important at this point, since it can be made of a wide variety of materials. Yes, the beating will occur in the classic way, that is, through phase interference between multiple antennas. But going back to my original question, what size should the patch antennas be? Half-wave or quarter-wave? The beating will occur in the Fresnel region using near-field focusing. My question is, should I choose half-wave for greater signal clarity, or quarter-wave for more antennas?
Good morning,@sophiecentaur I will use the same transmitter for all the cavity patches and I will vary the phases of all the antennas. I'm doing a lot of research and I think the best solution would be the half-wave antenna because it is more symmetrical. The quarter-wave antenna, having a lateral ground plane, requires excellent software to manage it. So, do you also think the half-wave is the right size?
It all depends on what you want the the interference patterns need to be. The best design will depend on the wanted spatial pattern. You have been very vague about this and it is a crucial factor. Have you researched the technique of beam steering with phased arrays? The overall pattern of a set of identical array elements firing in the same direction can be broken down into the element pattern and the array pattern. (The resultant field in any direction can use a 'variable separable' approach. But that only takes you so far; interaction between adjacent elements can affect the radiating currents (mutual Interference). The product of the two functions will give the array pattern. What total angular range do you need? (This only applies when all elements fire in the same direction.)
How do you intend your receiver(s?) to analyse the received signal? This needs to be known(specified) before you take steps to produce your array.
So, yes, as far as the angular range to operate is concerned, the desirable limit would be 5 degrees, but it's difficult to achieve. However, I would like to have a lot of directivity to operate in the Fresnel zone. As for the arrangement, the best one for mine is probably concentric, with the greatest density of antennas in the center. I will avoid mutual interference and grating lobs by spacing the antenna centers half a wavelength apart. The pattern I would like to obtain is to divide all the antennas into two groups: the first group with an 800 MHz carrier and amplitude modulated at 1000 Hz, and the second with the same carrier at 800 MHz and modulated at 1100 Hz (example values). This will allow me to obtain beats in an area in front of the array, at the Fresnel distance, with minimum dimensions equal to half a wavelength (to respect physics).
You describe some of your proposed method but you do not state the actual pattern you require. The depth of the interference pattern will vary with time as the modulation frequency. If the modulation is phase modulation then I imagine you could have a chance of resolving the sign of your angular distance but, as you mention the Fresnel zone, you would need to know the distance from the array in addition to the angle. This is why I say that some more information is needed if you want an opinion in a form that's better than arm waving. Merely demodulating the PM signal is not enough for near field signal, I think.
Is this stuff all a secret? If not, then a diagram and description of what you reckon is going on would be a big help.
  • · Replies 17 ·
  • · Replies 93 ·
14K
  • · Replies 29 ·
  • · Replies 16 ·
11K
