Why ##a^0=1##?
  • Context: Undergrad
  • Thread starter Thread starter Mike_bb
Mike_bb
Hello!
I have problem in understanding why ##a^0=1##.
I represent ##a^x## as ##1*a*a*a*a*...*a## (x times)
Why ##a^0=1##? Why is ##a^0## not equal to ##0##?
Thanks.
It's consistent with ##a^{n+1}=a\cdot a^n##
Or, more generally, ##a^{n+m}=a^na^m## implies ##a^0=1##, because otherwise ##a^{n+0}\neq a^n##.
Mike_bb said:
Hello!
Thanks.
Well if your ##x## is zero, then you will have no ##a##'s, so just the ##1## in the begining.
  • Love
Another way to look at it
##a^0 = 1##
##a * a^0 = a * 1##
##a^1 = a##
Of course you can reverse the steps and conclude that ##a^0 = 1##
##a^0=a^1a^{-1}=a\frac{1}{a}=1##
Exponents are about multiplication, and 1 is the multiplicative identity.
If exponents represented repeated addition the zeroeth power would be 0, the additive identity.
Very similar to post #6.
$$ a^0=a^{x-x}=\frac{a^x}{a^x}=1 $$
This has several excellent answers and I cannot improve on them. I just have this persistent nagging voice wanting to express this abstractly, if perhaps not actually usefully for a beginner.
Namely, all answers point out, one way or another, that exponentiation is a function that changes addition into multiplication, hence changes zero into 1. (It also has positivity and continuity hypotheses.)
[edit: I have added a necessary condition for uniqueness that I originally forgot to mention.]
I.e. if a>0, then f(x) = a^x, is a homomorphism from (Q,+) to (R>0,*). I.e. a function from rationals to positive reals, such that, for all real x,y, f(x+y) = f(x)*f(y).
As a consequence, f carries the additive identity, namely 0, to the multiplicative identity, namely 1.
Indeed it is the only such homomorphism such that f(1) = a.
If you want such a uniqueness statement also for the exponentiation function defined on all reals, i.e. for the function f(x) = a^x, from (R,+) to (R>0,*), you need a continuity hypothesis on f, but this is unnecessary for the desired statement about 0 and 1; i.e. the value of the function at zero is always uniquely determined, no matter what the value is at 1.
For the same reason, i.e. because logs change multiplication into addition, the value of a logarithm function at 1 is always zero, no matter what (positive) base is chosen for the log. And a continuous log function L, from (R>0,*) to (R,+), is determined by a choice of positive a, (i.e. the base), such that L(a) = 1.
##a^0## can't be ##0## because if ##a^0=a\cdot 0 =0## for every ##a##, then ##0^0=0##, that is not true in mathematics ... In addiction ##a^0=a^{0+0}=a^0\cdot a^0##, now ##a^0=\left(a^0\right)^2## that is only if ##a^0=1## or ##a^0=0##. By the nosense of ##a^0=0## follow that ##a^0=1##.
Ssnow
$$a^x:=\exp(x\ln a),\quad \exp(x):=1+\sum_{k=1}^\infty\frac{x^k}{k!},\quad a>0$$
Nearly the best answer!
Also nearly the best answer!
I think this is one of those things that we 'learn' first - as a bit of trickery and then follow it up with a believable proof.
I agree with that, because that's the way I learned it:
a^0 is defined as 1.
Only now do I see why it is so.
So much like how some of us can refer to Laws Of Exponents and what happens when applying the Laws when you have a number to power of 1 in numerator and same number to power of 1 in denominator --- Boom ! Exponent 0; already understanding the ration is 1.
In arithmetic, ##x^k## is defined recursively. The recursive step is ##x^k=x^{k-1}x##. What is the base case then, ##x^0##? For the recursion to work it just has to be 1.
  • Agree
@symbolipoint, thank you.
In any of the earlier posts, nobody mentioned the solution for ## 0^0 ##. Using post #8 for defining ## 0^0 ## will generate the result ## 0^0 =0^{x-x}=0^x/0^x=0/0 ##, which is undefined.
The mathematical expression ## 0^0 ## has different interpretations, and it is defined depending on the context.
It can be proved that $$ \lim_{x\to0^+}x^x=1 $$, but it cannot be proved that ## 0^0=1 ##. To support the continuity of function ## x^x ## on the interval ## \left[0,\infty\right) ##, ## 0^0 ## can be defined as equal to ## 1 ##.
One more illustration is the power series $$ e^x=\sum_{n=0}^{\infty}\frac{x^n}{n!} $$, where ## e^0=1 ## holds only for ## 0^0=1 ##.
There are other examples with their own interpretations of ## 0^0 ##, and all these examples have one thing in common, and it is that they are all based on convenience. There is no example that assigns the value to ## 0^0 ## other than ## 1 ## except in scenarios where ## 0^0 ## is undefined.
Could you explain how does it work? How is it possible to combine an empty product with original factors (see below)? Thanks.
"The product of any factors combined with an empty product equals the original factors. Just as multiplying by ##1## does nothing, an empty product is treated as doing nothing."
Why not define ##a^0 = 0##? And take it from there. For example:
The usual index rule for all integers ##m, n## is:
$$x^mx^n = x^{m + n}$$Whereas, your index rule is limited to non-zero integers ##m,n##:
$$x^mx^n = x^{m + n} \ \ (m + n \ne 0)$$$$x^mx^n = 1 \ \ (m+n = 0)$$You could make a YouTube video on how mathematicians have got it wrong for centuries!
Thx. But I'm interested in the explanation that mentions empty product.
I guess the rationale is this:
Start with ##0##, add ##a## you get ##a##. Add ##a## again you get ##2a##. In this case you start with the additive identity (##0##).
Start with ##0##, multiply by ##a## you get ##0##. And so on. That leads to nothing except ##a^n = 0## for all ##n##
Instead, start with the multiplicative identity ##1##:
Multiple by ##a## you get ##a##; multiply by ##a## again, you get ##a^2##.
It's more rational that you start at ##a^0 = 1##, the multiplicative identity, rather than the additive identity.
In fact, if you consider the real numbers as a field, then ##\mathbb R - \{0\}## is the multiplicative group. There is no zero element in the multiplicative group. Whereas, ##\mathbb R## (including ##0## and ##1##) is the additive group.
  • Love
If you have a number and you choose not to multiply it by anything, should it turn into a zero? Or should it stay the same?
It should stay the same.
Exactly. So you want "multiply by no ##a##s" to be "multiply by 1".
We can also work backwards:
$$a^3 \times a^{-1} = a^2$$$$a^2 \times a^{-1} = a^1 = a$$$$a \times a^{-1} = 1 (= a^0)$$$$1 \times a^{-1} = a^{-1} \dots$$In particular, there's no way that ##a^0 = 0## can fit that pattern in any shape or form.
  • Agree
As an undergraduate answer, this is one of the best answer (more than sufficient). The implicit prerequisite is that you're working in the conventional algebraic structure (a field where exponent laws hold and $a \neq 0$).
View from the other end of the tunnel:
Having learned my basic Maths in the 50s ,I was taught how to use log tables and the 'rules' of how to use them, I was perfectly happy tp use the 'four figure tables' (Godfrey and Siddons - I pinched a book and still have it) and just went through the motions for numbers greater than 1, using 'bar' numbers for numbers less than 1. my dad gave me his slide rule and I got to appreciate the log scale. The distribution of the numbers was very familiar long before the analytical side was presented.
Not acceptable for 'modern' educationists but total numpties could use those tables 'cos they had no option if they needed results.
  • Agree
Starting from the beginning, using basic calculus.
If f(x) = x^i where i is an integer. df/dx = i*x^(i-1). ∫(x^i)dx = (1/(i+1))*x^(i+1) + C. Note the formula is not true if i = -1. So what is ∫(1/x)dx? Well, because of the C that appears in the integral, this will be solved by defining a definite integral ln(x).
We define ln(x), x > 0, called the natural logarithm, as ln(x) = ∫(1 to x) (1/y) dy. Note ln(1) = 0 and ln'(x) = dln(x)/dx = 1/x. ln'(x*y) = y/x*y = 1/x (using f(g(x))’ = df/dx = (df/dg)*(dg/dx) = f'(g(x))*g'(x)). Hence, since they have the same derivative, ln(xy) = ln(x) + C. Let x = 1. ln(y) = C. ln(x*y) = ln(x) + ln(y). This is why the definite integral was from 1 to x. It leads to the simple relation ln(x*y) = ln(x) + ln(y).
An inverse of a function f(x), g(x), is a function such that f(g(x)) = x and g(f(x)) = x. Let e(x) be the inverse of ln(x). That ln(x) has an inverse is evident from its graph. Let a = e(x), b = e(y). ln(a) = x. ln(b) = y. e(x+y) = e(ln(a)+ln(b)) = e(ln(a*b)) = a*b = e(x)*e(y). Let e(1) = e, called Euler’s number. It is a very important number in math. e^n = e*e*…*e, n times. So e^n = e(n). So far, e^n has only been defined for n a natural number. This allows us to define e^x for any x as e(x), and from now on we will use e^x instead of e(x).
a^x is defined as e^(x*ln(a)). a^(x+y) = e^((x+y)*ln(a)) = e^(x*ln(a))*e^(y*ln(a)) = (a^x)*(a^y)
a^x = a^(0 + x) = a^0*a^x. Dividing by a^x, we have a^0 = 1, which is what was asked - it pops out here without any further ado.
a^(x-x) = (a^x)*(a^-x) = 1. a^-x = 1/(a^x)
(a^x)^y = e^(y*ln(a^x)) = e^(y*ln(e^(x*ln(a)) = e^(y*x*ln(a)) = a^(x*y)
a = a^(x/x) = (a^(1 /x))^x or (x√)a = a^(1/x).
From this, you should be able to derive all the exponent rules given in a Precalculus text, only this time for any real numbers. For example x^a/x^b = (x^a)*(1/x^b) = (x^a)*(x^-b) = x^(a-b),
The logarithm of x to base a will be written as loga(x) and is the inverse of a^x, if it exists. Suppose a^x has an inverse, then a^(loga(x)) = x. e^(loga(x)*ln(a)) = x. ln(x) = loga(x)*ln(a). The logarithm to base a is defined as loga(x) = ln(x)/ln(a). We want to show that ln(x)/ln(a) is the inverse of a^x. a^(ln(x)/ln(a)) = e^(ln(a)*ln(x)/ln(a)) = e^ln(x) = x. loga(a^x) = ln(a^x)/ln(a) = ln(e^(x*ln(a))/ln(a) = x*ln(a)/ln(a) = x. Hence the inverse of a^x, loga(x) exists and is ln(x)/ln(a)
loga(x) has the usual properties of logarithms. loga(xy) = ln(xy)/ln(a) = (ln(x) + ln(y))/ln(a) = loga(x) + loga(y).
Now we look at some calculus. log(e^x) = x. (1/e^x)*(e^x)’ = 1. e^x = (e^x)’. The derivative of e^x is the same function. Very interesting.
Let's find the derivative of x^a when a is not just an integer but any real number. (x^a)’ = (e^(a*ln(x))’ = e^(a*ln(x))*(a*ln(x)’ = e^(a*ln(x))*a/x = a*(x^a)/x = a*x^(a-1). Hence, the general formula is the same as when a = n.
See how what is often done in precalculus in a handwavy sort of way is much easier with a smidgen of basic calculus. Teaching-wise, we should, IMHO, replace precalculus with introductory calculus, covering precalculus topics using a much more elegant calculus-based approach. Nothing hand-wavy.
Thanks
Bill
Hello!
I decided to solve following equations:
1) Let ##2^x=0##: ##2^x=2^{2x}## and then ##x=0##. ##2^0=0##
2) Let ##2^x=1##: ##2^x=2^{2x}## and then ##x=0##. ##2^0=1##
Could anyone explain how is it possible that ##2^0## has two values ##0## and ##1##?
Thanks.
  • Skeptical
  • Sad
  • · Replies 25 ·
  • · Replies 29 ·
