Back of the envelope derivation of Larmor's equation
  • Thread starter Thread starter FranzDiCoccio
    Derivation
The discussion centers on a geometric derivation of Larmor's equation for the power radiated by an accelerating charge, credited to EM Purcell. Participants express confusion about how the ratio of radial and azimuthal components of the electric field is calculated, particularly in relation to the "kink" in field lines. Clarifications reveal that the derivation relies on the direction of the electric field rather than its magnitude, emphasizing that field strength is related to line density. The conversation highlights the importance of understanding these components for grasping the Larmor formula's implications in electromagnetism. Ultimately, the derivation is deemed useful for conceptual understanding, despite some lingering questions about its completeness.
FranzDiCoccio
"back of the envelope" derivation of Larmor's equation
Hi all,
I stumbled on a derivation of the Larmor's equation for the power radiated by an
accelerating charge that makes use of geometric arguments.
http://www.cv.nrao.edu/course/astr534/PDFnewfiles/LarmorRad.pdf" credits it to EM
Purcell.
The derivation seems nice, perhaps for recalling how things work without cumbersome
calculations. However, there is something I do not completely get.
The geometric argument shows that the electric field has a component perpendicular
to the radial direction. This is convincing enough. What I do not completely understand
is how they calculate the ratio of the radial and orthogonal component of the field.
The ratio they use applies to the "kink" in the field lines (this is clearer in the second
derivation). But how are the radial and azimuthal components
of the "kink" (i.e. a portion of field line) connected to the same components of the field
itself? Isn't the field amplitude related to the density of the field lines?
I sort of see that the field lines are denser when \theta = \pi/2, but doesn't that
affect both components equally (radial and azimuthal)?
Does any of you see a simple argument to relate the field amplitude in a certain direction
to the projection of the "kink" in that direction?
Thanks a lot for any insight
F
All that was used in the derivation was that the fact that the electric field is directed along the 'kink' that was drawn. Field lines describe the direction of the electric field, and the derivation of the formula you mention only needed that direction. Nothing about the strength (magnitude ) of the field went into it.
Love the concluding remark:
I've never understood why the Larmor formula isn't even mentioned in most introductory textbooks. In fact I never saw it in all of my undergraduate education. Yet it's simple to interpret, and it has all sorts of interesting uses. I've already mentioned antennas. You can also understand why the sky is blue and polarized, and explain why a classical Rutherford atom, with electrons orbiting around the nucleus, would be unstable, radiating away all its energy in a fraction of a nanosecond. More generally, the Larmor formula ties electromagnetic waves to their source, making it clear that radiation requires not just motion, but also acceleration of charged particles.Once you have the Larmor formula, why bother to cover Maxwell's equations?
For a second year E&M course, I like how a few experiments with pith balls, wires and magnets suffice to imply so much (e.g., special relativity and optics). But I think the concluding remark is correct with reference to first year physics (before students acquire the math prerequisite for Maxwell's equations anyway); much simpler to start from the principles of relativity and of electric charges, use lower math, and focus more on the everyday world around us (as opposed to abstractly focussing on fields around different charge/material geometries).
FranzDiCoccio, note that the qualitative section of the web page is really not referring to a "kink", but to the smooth gradients of a continuously varying field. (Back to the kink, the field lines must join up since the definition of field lines is that they only terminate at the location of a charge - and the number of them crossing a surface is a measure of the amount of charge enclosed. Yes, their spacing - not length - expresses field strength.)
Hey xboy,
thanks for your reply. I do not understand it, though. Why are you saying that the field strength is not involved in the derivation?
The very first equation in the pdf document gives the ratio of the field amplitudes along
the radial and azimuthal directions, doesnt'it?
Eq. 2D2, gives the amplitude of the azimuthal component, and it is emphasized that it
is larger than the radial one in the far-field limit.
You need the amplitude to evaluate the Poyinting vector that eventually results in the
Larmor Equation.
Hi cesiumfrog,
thanks for your comment. I do realize that the field lines vary smoothly.
This is seen in the nice pictures in the html document.
However in this simple construction the field lines are piecewise straight lines, right?
I was referring to the small piece of each field line contained in the spherical shell as "the kink". That's the bit whose radial and azimuthal components are c \Delta t
and \Delta v t \sin \theta, respectively.
I'd say that the ratio in the first equation should be evaluated based on the density
of the azimuthal component of the lines to the density of their radial component.
What I do not see is why this ratio is simply given by the ratio of the components
of "the kink".
I am afraid that this "simple" derivation might be less "self-contained" than it suggests.
I mean, I like it, but if my question above has no simple and convincing answer, I think
this derivation is more confusing than useful. You can use to convince yourself that
there is an azimuthal component, but the proof that this "wins" over the radial one in the
far field is a bit weak.
Thanks again
Franz, I did not mean that the derivation does not require the field strength. What I meant was the formula for the ratio of the two components.
Suppose we have an arbitrary vector v along a particular direction ( making theta with x-axis, say) Then the ratio : \ v_y / \v_ x = \ tan \theta , isn't it? We know that even if we don't know the magnitudes of the components. So if you know the direction, you know the ratio between the components, even if you do not know the magnitudes.
The magnitude of the field is, as you rightly say, dependent on the density of field lines. But for the ratio between the two components of the field line, we only need the direction.
xboy,
yes, I think now I see what you mean, thanks.
I guess I was confused about the fact that one can use the value of E_r "just before" the kink. But on second thought, that makes sense.
Plus, one can use an infinitely thin "pillbox" at the "bending point" to convince oneself that
the radial component is actually that one. This is discussed in this more detailed "[URL version
[/URL]of the arguments illustrated in http://physics.weber.edu/schroeder/mrr/MRRtalk.html" (fig. 4.6).
Yes, I think now I'm happy of my understanding of this derivation of the Larmor's equation!
Thanks again
F
PS The derivation is credited to JJ Thomson in the "[URL notes[/URL].
Very interesting.
If you wish to understand this Larmor em radiation, I recommend reading "Elementary Classical Physics, Vol 2, Weidner and Sells, Acclerating charges and electromagnetic waves. In my edition, it's chapter 41-4, page 1024.
I used this textbook to teach PHY-112 long, long ago.
Good luck.
