What happens to the missing time?
  • Thread starter Thread starter amalmirando
    Time
The Earth's rotational period is approximately 23 hours and 56 minutes, leading to a daily discrepancy of about four minutes when compared to the 24-hour clock. This difference arises because the Earth must rotate slightly more than once each day to account for its orbit around the Sun, ensuring the Sun appears in the same position daily. Leap days and leap seconds are implemented to correct for these discrepancies over time. The discussion emphasizes the importance of understanding these timekeeping adjustments in relation to Earth's movements. Overall, the additional four minutes are reconciled through periodic adjustments in our calendar system.
amalmirando
What happens to the missing time??
It has been observed that the Earth's rotational period to be roughly 23 hours and 56 minutes.But the clocks we use indicate 24 hours. So there should be a difference of 4 minutes for each day. Could somebody please explain what happens to this additional 4 minutes?
Astronomy news on Phys.org
Since the Earth is also revolving around the Sun (in addition to rotating), it needs to turn slightly more than one full rotation in order for the Sun to be in the same apparent position in the sky from day to day. This difference is approximately four minutes.
(And of course, we account for the "approximate" nature with leap days, leap seconds, etc...)
The animation here is a bit slow, but helps visualize:
http://csep10.phys.utk.edu/astr161/lect/time/timekeeping.html
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
