Is Weight Force an Apparent Force on a Rotating Plate?
The discussion centers on whether weight force is considered an apparent force on a rotating plate. It is established that in classical mechanics, weight is treated as a real force, while centrifugal force is an apparent force experienced by someone on the rotating plate. The conversation also touches on the concept of approximately inertial systems, clarifying that the Earth is considered approximately inertial due to its low rotation rate rather than the effects of gravity. Additionally, the impact of centrifugal force on the calibration of scales used for weighing is highlighted, emphasizing its significance in commerce. Overall, the participants reach a consensus on the treatment of forces in these contexts.
nebbione
Is the weight force an apparent force ? Sorry but on the web i can't find anything.
For example if i should think about a man that is on a rotating plate,what are the apparent force ?
I think surely the centrifugal force but should i consider even the wight force of the man ?
In General Relativity it is, in classical mechanics it is not.
As this is classical mechanics, you can (and should) treat gravitation as a real force.
Ok thank you very much!
Another question: so when we talk about approximately inertial systems like the earth, the Earth is said to be approximately inertial because it is rotating around the sun right ? and not because we feel the gravity, right =
It is approximately inertial because the rotation rate of the Earth on its own axis is low. The centripetal acceleration associated with the rotation rate of the Earth (at the equator) is approximately 0.03 meters/sec^2.
If you are only quoting the acceleration of gravity to one or two significant figures, this deviation is insignificant.
If you are selling pork barbecue by the pound, this acceleration is significant. In order to be legal for use in commerce, a scale must accurately report the mass of the object being "weighed". Since a spring-based scale responds to apparent weight, this means that the calibration of the spring-based scale must reflect the centrifugal force resulting from the rotation of the Earth on its axis.
Thank you very much! Now i have no doubts!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
