Pseudo forces on a person in a park-swing
  • Thread starter Thread starter marellasunny
    Forces
A discussion on pseudo forces in a swing scenario centers around a 40kg girl using a swing, with emphasis on the role of inertial forces. Participants clarify that when neglecting inertial forces, the tension in the swing's chain is solely due to the girl's weight. The conversation highlights that while the swing's frame of reference may suggest an apparent centrifugal force acting on the girl, this does not constitute an action-reaction pair as per Newton's third law. It is noted that the real centripetal force exerted by the swing opposes the inertial centrifugal force, but both forces act on the same object, the girl. The complexities of inertial forces and their implications in this context are thoroughly examined, leading to a nuanced understanding of forces at play in a static scenario.
marellasunny
This is a very basic question,I also attempt to learn more from it.Some additional info would also be of great help.
A girl whose mass is 40kg is using a swing set.The diameter of the wire used for constructing the links of the chain is 5mm.Determine the average normal stress in the links at the bottom of the swing,assuming that the INERTIAL FORCES CAN BE NEGLECTED.
Q.The question is regarding the INERTIAL FORCES.I have drawn the resolution of forces diagram(attached and I am not sure it's correct).Here,where does one include the inertial/pseudo forces in this accelerating frame of reference?
Q.Is this inertial force- 'pseudo' in the sense that the sagging of the swing appears from a imaginative force taking the swing as the reference frame?
Hope the questions are clear.Please view the attachment diagram.
Ignoring inertial forces in this problem means that tension is due to supported weight only. You basically solve this problem for swing at lowest point and v=0.
Ignoring the mass of the chain and the swing, the only inertial force would be equal to the reaction force of the girl's 40kg body to centripetal acceleration, which is exerted onto the swing. From the swings rotating frame of reference the inertial force is the apparent centrifugal force exerted on the girls body. The swing exerts a real and non-inertial force onto the girl to oppose both the inertial force (swing frame of reference, or reaction force if using an inertial frame of reference) and weight.
As K^2 mentioned, it appears that you're supposed to assume that the girl and the swing are at rest, and not moving, but that isn't a very interesting problem, since the only force opposed by the chain is due to the girl's weight.
rcgldr said:
Ignoring the mass of the chain and the swing, the only inertial force would the reaction force
I find it very misleading to talk about inertial forces as reaction forces. Inertial forces are never part of a Newtons 3rd action-reaction pair.
There is no centripetal acceleration in the rest frame of the swing, where inertial forces appear. The swing and body are static here.
rcgldr said:
The swing exerts a real and non-inertial force onto the girl to oppose both the inertial force and weight.
This is correct. The real centripetal froce on the body by the swing is opposing the inertial centrifugal force on the body. But they are not an action-reaction pair. They both act on the same object (the body), unlike action-reaction force pairs which act on a different object each. The reaction force to the real centripetal force on the body by the swing is the real reactive centrifugal force on the swing by the body.
My last edit to my post didn't take (the forum froze on me and I forgot to check my post later). I re-editted my previous post back to what I intended to post before, with some clarification. I only meant to state that the inertial force from the swing's frame of reference was equal to the reaction force from an inertial frame of reference.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
