Can a piece that expands when blood flows through it decrease pressure?
  • Thread starter Thread starter xfactor352
    Fluids Pressure
The discussion centers on whether a piece that expands when blood flows through it can decrease pressure in a tubing system. It is noted that if the flow is slow and friction losses are minimal, pressure remains constant throughout the tubing. However, if friction losses occur, pressure will decrease along the tubing, influenced by Bernoulli's principle. The concept of an expanding piece resembles the function of a pressure regulator, which also manages pressure changes. Overall, while the idea has merit, the dynamics of fluid flow and pressure regulation are complex.
xfactor352
If i have a syringe used to pump blood through a set of tubing that becomes smaller and smaller, the pressure will obviously increase until it gets to the smallest diameter of the tubing. However, if I create a piece that expands when the blood flows through it, will this decrease the pressure?
The idea is that the blood displaces the walls of the tubing, thus reducing pressure. Is this idea physically possible?
Welcome to PF!
Actually, if the flow is slow enough that there isn't much loss due to friction, pressure is constant throughout the tubing. If there is loss, the pressure will decrease the further along in the tubing it gets. And that's even without adding in the additional decrease in static pressure (conversion to velocity pressure) due to the speeding up of the fluid and Bernoulli's principle.
You may want to look into Bernoulli's principle actually -- it explains a lot about your question: http://en.wikipedia.org/wiki/Bernoulli's_principle
That sounds a lot like how a regulator works. There's more to it than that, though: http://en.wikipedia.org/wiki/Pressure_regulator
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
