What is negative frequency(fourier transform)
Negative frequencies in Fourier transforms arise from the mathematical representation of signals, where both positive and negative components contribute to the total power. They are primarily a mathematical tool to simplify the analysis, with no direct physical reality. The concept is rooted in Fourier series, where Euler's identity allows for the inclusion of complex exponentials, leading to the emergence of negative frequencies. While negative frequencies themselves lack physical significance, they can represent independent modulation signals in complex frequency analysis. Thus, complex frequencies effectively encapsulate multiple degrees of freedom in signal modulation.
ankities
in Fourier transforms of normal baseband sigal , spectral components are replicated on both +ve and -ve sides of frequency axis.
i know that both -ve and +ve frequency components contribute to the total power of the signal
but i don't know the physical significance of the -ve frequencies used?
are these -ve frequencies just the mathematical imaginary tool ?
There is no physical reality of the negative frequency. It is, as you say, a mathmatical tool.
However, the negative frequencies only emerge because we wish to simplify the Fourier transform.
It is perfectly possible to have a Fourier Transform without any imaginary and negative components.
If you look into Fourier Series (from which Fourier Transforms are developed), you will see that it can be represented as
f(t) = a_{0} + \sum_{n}a_{n} cos(n\omega t + \theta_{n}) + \sum_{m}b_{m} sin(m\omega t + \theta_{m})
It is only because we wish to simplify this that we make use of eulers identity that
e±iθ = cos(θ) ± i sin(θ)
When substituting this you will get "negative frequencies" when deriving all the formulas.
Perhaps it would be more precise to say that there is no physical reality of complex frequencies in general, and that any real signals consist of a sum of positive and negative complex frequencies:
cos(ωt) = \frac{e^{+jωt} + e^{-jωt}}{2}
On the other hand there is a physical reality to complex frequencies when we use them to describe modulation.
Specifically, they represent a *pair* of real modulation signals.
There are two independent degrees of freedom when modulating a sinusoid; phase/amplitude in polar coordinates, I/Q in rectangular coordinates. We can incorporate both of these independent signals into our single complex frequency expression.
In other words just as complex numbers can represent a pair of real numbers on an Argand diagram, complex frequencies can represent a pair of orthogonal modulation components of a real sinusoid.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
