Solving Inequalities: Tips & Tricks for Beginners
  • Thread starter Thread starter ezsmith
    Inequalities Type
When solving inequalities, the direction of the inequality sign changes only when multiplying or dividing by a negative number. For example, in the inequality 3x ≤ 9, the correct solution is x ≤ 3, not x ≥ 3. It's important to verify solutions by substituting values back into the original inequality to ensure they hold true. Additionally, taking the reciprocal of both sides of an inequality also reverses the inequality sign. Understanding these rules is essential for accurately solving inequalities.
ezsmith
Hi, I used to do all this type of inequalities but I have not practice this for almost a year and I have totally forgotten and didn't know why did the sign change.
For example: If it's 3x ≤ 9
The answer: x ≥ 3
Is this right? I have actually forgotten in what circumstances we are suppose to change the inequalities. Input and explanation will be much appreciation. Thanks!
Mathematics news on Phys.org
It's actually the other way around, i.e., x <= 3.
You can always test your answer. For example if x = 1, then 3x <= 9. But x is not greater than 3. Thus your answer is wrong.
You only change the inequality when the coefficient is negative ( -x > 0 <=> x < 0).
More precisely, the direction of the inequality changes when you multiply both sides of the inequality by a negative number. This includes division, as well, since division by a number is the same as multiplying by the reciprocal of that number.
The direction of the inequality changes if you take the reciprocal of each side. For example, 2 < 3, but 1/2 > 1/3.
All of these replies got it right. What helped me when I was learning about inequalities, was to treat it like an equal sign. Then the only additional thing to remember when solving them is to change the direction of the inequality any time you multiply or divide the equation by a negative number.
Also, as was pointed out above. you can always check to make sure the answer makes sense by plugging it back in.
good luck!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
