Metal Deflection system/ Draft included
Designing a metal deflection system to induce and deflect aluminum tin using a positively charged plate is theoretically possible, but may require high voltage for effective operation, which could be impractical. The discussion highlights that magnetic deflection systems are commonly used in industrial applications, such as cement grinding plants, to remove metallic parts without significant costs. A suggestion is made to consider using a solenoid as a pusher element for separation, although questions arise about its effectiveness compared to other methods. The potential of using eddy currents for better separation is also mentioned as a more viable alternative. Overall, the feasibility and cost-effectiveness of such a system remain key concerns.
Harmony
I am wondering if:
1. Is it possible to design such system? I am trying to induce the Aluminium Tin, then deflect it using a positively charged metal plate.
2. If so, what is the cost needed? Let say I want to deflect the tin for about 5cm from the center, and the size of the design should not exceed the size of 80cm*80cm
You did not explain the principle of your device.
I guessed this is based on electrostatic forces.
If I guessed correctly, I think it will not work. You would require very high voltage to get a small force.
Metal deflection is very much used in industry.
For example, in cement grinding plants, metalic parts could damage some equipements.
They are removed with magnetic deflection systems. This is very common.
These devices commonly remove mettalic part from large bulk flows (more than 1000 t/h) without problem.
The same principle can be applied at any scale.
Thanks for your advise. Can you give me some link on the magnetic defelction system? And is it possible to design it without high cost?
Why not use a simple separate solenoid as the pusher element?
How does a solenoid separator help to separate metal from non-metal?:confused:
Oh, I see your point. But I don't think you can use electrostatic fields for the separation either. Probably using eddy currents would work better?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
