Water's Property: Droplets Stay Stuck in Inverted Tumbler
  • Thread starter Thread starter Milind_shyani
    Property Water
When a stainless steel tumbler is inverted after being filled with water, droplets remain stuck to the walls due to surface tension. This phenomenon is influenced by the contact angle between the water and the tumbler material; a lower contact angle allows water to cling more effectively. In contrast, if mercury were used instead of water, it would not adhere to the tumbler due to its high contact angle with steel. Understanding these principles highlights the interplay between surface tension and material properties. The discussion emphasizes that surface tension is not the sole factor; contact angle also plays a crucial role.
Milind_shyani
Hi
When we fill a tumbler( of stainless steel) with water and then invert it ie empty it . The tumbler gets empty except a few drops of water. even if you keep the tumbler inverted for hours the water droplets do not fall down they remain stuck to the walls of the tumbler.
I hope you all reply soon
Hi - you didn't ask any questions there, but the effect you are talking about is surface tension...
Hi
I know what surface tension is but is this the only reason for it
A little bit more. This phenomenon depends on the contact angle between water and the tumbler material as well. For example, if you test with Hg instead of water, there must be no Hg held in the tumbler any more. The contact angle of Hg against steel is too high.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
