Symmetric, antisymmetric and parity
  • Thread starter Thread starter Sacroiliac
    Parity Symmetric
Sacroiliac
Problem 5.5 In David Griffiths “Introduction to Quantum Mechanics” says:
Imagine two non interacting particles, each of mass m, in the infinite square well. If one is in the state psin and the other in state psim orthogonal to psin, calculate < (x1 - x2) 2 >, assuming that (a) they are distinguishable particles, (b) they are identical bosons, (c) they are identical fermions.
(a) a2 [1/6 – 1/(2*pi2)(1/n2 + 1/m2)
(b) The answer to (a) - (128*a2*m2n2) / pi4(m2 - n2) 4
But this last term is present only when m,n have opposite parity.
(c) The answer to (a) plus the term added in (b) with the same stipulation as in (b)
What does this mean? It seams to be saying that all three particles would have the same separation unless their states have opposite parity. Is this correct? Bosons and Fermions would have the same separation unless their states have odd parities? I never heard of this before, how does this work?
bosons, fermions, and distinguishons ?
Hi,
The way to solve the problem goes as follows:
if the particles are distinguishable, then the wave function is psi_n(x1) psi_m(x2). If they are fermions, then you have to use the antisymmetric form: 1/sqrt(2) (psi_n(x1) psi_m(x2) - psi_n(x2)psi_m(x1))
and if they are bosons, then you have to use the symmtric form:
1/sqrt(2) (psi_n(x1) psi_m(x2) + psi_n(x2)psi_m(x1))
This for the technical part. Now the interpretational part is more difficult, and the effects are called "exchange effects" But in general, fermions tend to "repulse" each other and bosons tend to "attract" each other. But not with a term in the hamiltonian, but purely through these exchange effects.
cheers,
Patrick.
In case anyone's interested...
I finally found the answer to this question in Quantum Physics of Atoms molecules etc. by Eisberg and Resnick on page 315.
I'd try to explain it but I don't think I can pull it off.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
