Finding the greatest number in each row a matrix
  • Thread starter Thread starter physicophile
    Matrix Row
The discussion centers on finding the maximum number in each row of a matrix using C code. The original code shared by the user has several issues, particularly with the initialization of variables and the logic used to iterate through the matrix. Participants suggest improvements, such as using the first element of each row as the initial maximum value to reduce the number of comparisons needed. The use of DBL_MIN for initialization is questioned, as it may not be necessary. Additionally, there are recommendations to include checks for special cases like NaN (Not a Number) and INF (infinity) to make the code more robust. Overall, the conversation emphasizes optimizing the approach to finding row maxima while ensuring the code handles edge cases effectively.
physicophile
Hi, everybody. Could some one please help find the greatest number in each row of a matrix, this is what i have so far.. am i one the right track? (using C code)
Float big;
Big = -9999999.99999
for( i==0) {
for( j = 0; j < n; j++) {
if( *(mat + (j*0) + 0) > big) {
bigc1 = *(mat + 0*j + 0);
for( i==1) {
if( *(mat + (j*1) + 1) > big) {
bigc2 = *(mat + 1*j + 1);
for( i==2) {
if( *(mat + (j*2) + 2) > big) {
bigc3 = *(mat + 2*j + 2);
Technology news on Phys.org
There were enough issues to warrant a full example for a matrix [n] x [3]:
Code:
/* max per "row" */
#include <stdlib.h>
#include <limits.h>  /* we need DBL_MIN */
/* find max in each row of a matrix or table */
void max_per_row( double *result,
                          double matrix[][3],
                          const int xmax,
                          const int ymax)
	int x=0, y=0;
	for(y=0; y < ymax; y++)
		result[y]=DBL_MIN;
		for(x=0; x < xmax; x++)
			if ( matrix[y][x] > result[y] )
				result[y]=matrix[y][x];
int main(int argc, char **argv)
	double test1[3][3]={ {-10, -20, 0},
                         {-13, 0,  13},
                         {-99, 99.99, 100.01}};
    double result[10]={0};
    int y=0;
    max_per_row(result, test1, 3, 3 );
    for(y=0; y < 3 ; y++)
    	printf("max row %d = %f\n", y, result[y]);
    return 0;
Why do you (both) use DBL_MIN? If you are looking for the greatest number you can use first number from the row as an initial value. That saves one comparison per each row. Or am I missing something?
I implemented the OP's program in the way he wrote it. Yes, using the first value does eliminate one comparison.
Code:
         for(x=1, result[y]=matrix[y][0]; x < xmax; x++)
To be closer to bulletproof: isnan() or something like it should be in there too. Which adds more overhead back into the mix. This code is devoid of checks. INF and NAN values may cause problems
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
