Derivative of 10^x using limit definition
cmajor47
Obtain the first derivative of 10x by the limit definition.
f'(x)=limh->0 f(x+h)-f(x)/h
f'(x)=limh->0 10x+h-10x/h
I also know that h=1 as x approaches 0.
Now, how do I make it so that you aren't dividing by h=0.
10x+h= 10x10h so
\frac{10^{x+h}- 10^x}{h}= 10^x\frac{10^h- 1}{h}
Now the question is, what is
\lim_{h\rightarrow 0}\frac{10^h- 1}{h}?
To find
I can't plug h=0 in because I would be dividing by 0. Do I plug in 1 since the limit as h approaches 0 is 1?
cmajor47 said:
To find
if you plug h = 0 then 10^h = 1. But you want the next order correction which you explect should be proportional to h. So you expect something of the form
lim_{h\rightarrow 0} ~10^h = 1 + a h + \ldots
where a is some numerical value and the dots represent terms of higher powers in h. The problem is to find the value of a.
Here is the trick: use that any number x may be written as e^{ \ln x}. Then use what you know about rules for logs and then Taylor expand the exponential.
I don't understand what this means. What is "Taylor expanding" and the "next order correction"?
Have you ever seen the relation
e^\epsilon = 1 + \epsilon + \frac{\epsilon^2}{2} + \ldots ?
This is a Taylor expansion.
Have you ever proved using the limit definition that the derivative of e^x is e^x? Then you must have used something similar to the above.
If you haven't proved the e^x case and the expansion I wrote above is not familiar to you then I will let someone else help you because I don't see at first sight any other approach.
EDIT: do you know what the limit as h goes to zero of \frac{e^h -1}{h} gives? maybe you have been told this without proving it. If you know the result of this limit and are allowed to use it, then I can show you how to finish your problem. If not, I don't see how to help, unfortunately.
Best luck!
I've never proved e^x. Thank you for trying to help though.
Sorry. I can tell you that the limit as h goes to zero of 10^h is
lim_{h \rightarrow 0} 10^h = lim_{h \rightarrow 0} e^{\ln 10^h} = lim_{h \rightarrow 0} e^{h \ln 10} \approx 1 + h \ln 10
where I used an identity for logs and then I used the expansion of the exponential I mentioned earlier. Form this you can get the final answer of your question.
Hopefully someone else will be able to find a way to show this result in some other way but I can't think of any!
Best luck
nrqed said:
... Taylor expand the exponential.
Taylor expansion requires knowledge of what the derivative is. But we don't know the derivative, that is what we are supposed to find.
I don't know if this will be useful, but one might try using the definition of e:
<br /> e = \lim_{N \rightarrow \infty} (1+\frac{1}{N})^N = \lim_{a \rightarrow 0} (1+a)^{1/a}<br />
or
<br /> e^A = \lim_{N \rightarrow \infty} (1+\frac{1}{N})^{NA} = \lim_{a \rightarrow 0} (1+a)^{A/a}<br />
Also, the fact that
<br /> 10^h = e^{h \ln(10)}<br />
I suspect this was given as a preliminary to the derivative of ex so the derivative of ex cannot be used. It is easy to see that the derivative of ax, for a any positive number, is a constant times ax. It is much harder to determine what that constant is! It's not too difficult to show that, for some values of a, that constant is less than 1 and, for some values of a, larger than 1. Define e to be the number such that that constant is 1. That is, define "e" by
\lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1
As Redbelly98 said, 10h= eh ln(10) so
\frac{10^h- 1}{h}= \frac{e^{h ln(10)}- 1}{h}[/itex]<br /> If we multiply both numerator and denominator of that by ln(10) we get<br /> ln(10)\left(\frac{e^{h ln(10)}-1}{h ln(10)}\right)<br /> Clearly, as h goes to 0 so does h ln(10) so if we let k= h ln(10) we have<br /> ln(10)\left(\lim_{h\rightarrow 0}\frac{e^{h ln(10)}-1}{h ln(10)}\right)= ln(10)\left(\lim_{k\rightarrow 0}\frac{e^k- 1}{k}\right)<br /> so the limit is ln(10) and the derivative of 10<sup>x</sup> is ln(10)10<sup>x</sup>.<br /> <br /> That is NOT something I would expect a first year calculus student to find for himself!
Moreover, Taylor series are generally taught in second-semester calculus, while covering infinite sequences and series, while the limit
<br /> \lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1<br />
is often demonstrated or proven (if it is not simply stated without proof) in the first-semester course, shortly after having covered limits and while developing the rules of differentiation. I hardly expected that the OP would have seen Taylor series yet...
I believe the proof given in textbooks usually revolves around the limit definition of e, which Redbelly98 gives in post #10.
Agreed. I should not have mentioned Taylor series. They seem so natural to me now that I tend to use them without even thinking about it.
This is why I then asked the OP if he/she had seen the formula you wrote just above. I hope he/she has. Because if he/she has to go back to the limit definition and prove the above identity in order to solve the original question, this problem seems much more challenging than I would expect as an assignment problem at that level!
I suspect that OP's textbook presents the limit
somewhere in the chapter and that a student is just asked to recognize that they could apply it, in something like the manner Halls suggests in post #11...
Sorry, the dereivative of 10^x is of course ln10(10^x) but the Math forum derivation of the derivative of e^x is still helpful
More thoughts on this problem.
f(x)=10^X=e^(x*ln10)
f(x+h)= e^(ln10(x+h))=e^(ln10*x)*e^(ln10*h)
Plugging into definitation of derivative and simplifying gives
f'(x)= limit(h goes to 0) 10^x(10^h-1)/h
tabulating the limit as h goes to 0 of (10^h-1)/h= ln10
