Why water compressibility is neglicable
Compressibility refers to the change in volume or density of a substance under pressure. Water's compressibility is negligible, with only about a 2% change in density up to 7000 psi, making it effectively incompressible for most practical applications. In comparison, oils also exhibit low compressibility, similar to water, and are considered incompressible under high pressures. The discussion highlights that both water and synthetic oils behave similarly regarding compressibility, with no significant differences noted. Understanding these properties is crucial for applications involving fluid dynamics and pressure systems.
bigbrother
can anyone help me to have simple definition for compressibility and oil compressibility and why water compressibility is neglicable and for synthetic oils what is the effect of compressibilit on them compared to wter and diesel
Compressibility can be looked at as the change in volume with change in pressure. Or, similarly, you can look at in terms of change in density with respect to pressure.
If you look at the density of air over a range of pressures, you'll see that it doesn't take much pressure to have a significant affect on the density. However water's density will only vary about 2% up to pressures of about 7000 psi.
It is a judgment call on whether or not to use the incompressible assumption or not.
many thanks for your response but kindly could you advice about the oil comperssibility compared to water
They are both incompressible up to some very large pressures. I'll see if I can't dig some actual numbers up.
many thanks for this valuable link
but could you please confirm with me what i understood from this is that oil comperssibility is the same as water,no great diferrences between them
is that true
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
