Method of image charges: any extension for oscillating fields?
The discussion explores the potential extension of the "Method of image charges" to oscillating fields, particularly in the context of radiating problems rather than nearly-static scenarios. The user is interested in applying this method to the near-field of electrostatic antennas while ensuring causality in phase and group velocities. Responses highlight that image currents are relevant in antenna design, especially for whip and monopole antennas utilizing ground planes. However, the complexity of alternating fields introduces challenges, such as the need to account for delays, which complicates the applicability of the image method. The user seeks references to support their pedagogical application of these concepts.
lalbatros
I was wondering if the "Method of image charges" could be extended even partly or approximately to oscillating charges.
I am not considering nearly-static problems, but really radiating problems.
After all, the Poisson equation and the wave equation are rather close !
Therefore, I thought that maybe in the near-field of an (electrostatic) antenna there could be a way to re-use this good old method.
I must stress however that I want causality to be (reasonnably) ensured, as I am mainly interrested in phase and group velocities results.
Have you seem somthing similar?
Thanks
Sure, take a look at image currents. Many antennas, i.e. whip and monopole, use a ground plane and image theory in their operation.
Born2bwire,
Of course, alternative fields can produce alternating images.
However, this does not imply that this would lead to a useful image method of calculation.
For static fields, the method is obvious and simple, when applicable.
However, for alternating fields, delays have to be taken into account.
For my application (pedagogical), I need to keep a good account of these causal delays.
Would you have some reference for your suggestion?
Tanks!
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
