Method of image charges: any extension for oscillating fields?
The discussion explores the potential extension of the "Method of image charges" to oscillating fields, particularly in the context of radiating problems rather than nearly-static scenarios. The user is interested in applying this method to the near-field of electrostatic antennas while ensuring causality in phase and group velocities. Responses highlight that image currents are relevant in antenna design, especially for whip and monopole antennas utilizing ground planes. However, the complexity of alternating fields introduces challenges, such as the need to account for delays, which complicates the applicability of the image method. The user seeks references to support their pedagogical application of these concepts.
lalbatros
I was wondering if the "Method of image charges" could be extended even partly or approximately to oscillating charges.
I am not considering nearly-static problems, but really radiating problems.
After all, the Poisson equation and the wave equation are rather close !
Therefore, I thought that maybe in the near-field of an (electrostatic) antenna there could be a way to re-use this good old method.
I must stress however that I want causality to be (reasonnably) ensured, as I am mainly interrested in phase and group velocities results.
Have you seem somthing similar?
Thanks
Sure, take a look at image currents. Many antennas, i.e. whip and monopole, use a ground plane and image theory in their operation.
Born2bwire,
Of course, alternative fields can produce alternating images.
However, this does not imply that this would lead to a useful image method of calculation.
For static fields, the method is obvious and simple, when applicable.
However, for alternating fields, delays have to be taken into account.
For my application (pedagogical), I need to keep a good account of these causal delays.
Would you have some reference for your suggestion?
Tanks!
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
