Can a Segment of the Real-Line Have the Same Magnitude as the Whole Real-Line?
  • Thread starter Thread starter Lama
    Magnitude Set
The discussion centers on the concept of cardinality and whether a segment of the real line can have the same magnitude as the entire real line. It highlights that two sets have the same cardinality if a one-to-one correspondence exists between them, exemplified by the function f(x) = (1 - 2x) / (x(1 - x)), which maps the interval (0, 1) onto the entire real line. The conversation also touches on the distinction between cardinality and length, noting that while intervals can have the same cardinality as the real line, their lengths differ. Participants debate the implications of a "fixed scale" and the nature of self-similarity in relation to fractals, ultimately asserting that the real line's cardinality remains unchanged regardless of its fractal properties. The thread concludes with a call for clarity in definitions and concepts related to these mathematical ideas.
Lama
"real line" is used to mean real axis, i.e., a line with a fixed scale so that every real number corresponds to a unique point on the line. http://mathworld.wolfram.com/RealLine.html
If the real-line scale is fixed, then how a part of the real-line has the same magnitude of the real-line?
Mathematics news on Phys.org
Two sets have the same cardinality if you can find a one-to-one correspondence that maps one set onto the other.
Consider this an advance warning, Organic; if you try to use this thread for theory development, it will be deleted. You've used up all of your second chances.
Ok Hurkyl,
I got it, can you please answer to my question?
Organic ? Who's Organic ?
Lama said:
Ok Hurkyl,
Cantor proved this - try Googling it. In fact R^n - n-dimensional real space - is as big too.
Well, the main question is what do you mean by "part" and what do you mean by "magnitude"?
I will assume by "part" you mean an interval whose endpoints are not the same.
If by "magnitude" you mean simply the cardinality of the sets, then it's done by showing a 1-1 correspondence. For example, a 1-1 correspondence between the interval (0, 1) and the whole real line can be given by the function f(x) = (1-2x)/(x (1-x)); this function maps from the interval (0, 1) onto the entire real line.
If by "magnitude" you mean length, then they generally don't have the same magnitude; the real line has infinite length, while most intervals don't.
Hurkyl,
I am talking about a bijection between the real-line and any arbitrary part (or a subset if you will) of it.
So, If the real-line scale is fixed, then how a part of the real-line has the same magnitude of the real-line?
What is a "fixed real line scale", and whatever has that to do with the existence of bijections :confused:
Well, the choice of scale is irrelevant to cardinailty; the line consists of the exact same points no matter which ones I choose to call "0" and "1". So, the question reduces to:
I gave an example of how the interval (0, 1) has the same cardinality as the real line, by presenting the bijection f(x) = (1 - 2x) / (x (1 - x)).
Here is an example of how a part might not have the same cardinality as the real line: the set of points {0, 1, 2} has finite cardinality, but the real line does not have finite cardinality.
Lama said:
I am sorry, but please look at http://mathworld.wolfram.com/RealLine.html
As you see, the words "fixed scale" are used.
He didn't say you should use the words, he said they were not irrelevant to cardinality.
Organic, www, lama, dialog, whatever today, these things are all definitions. Why do you not accept that? Fixed scale is not a well defined term, and I would hesitate to say what it means, but presumably it is to do with distances being euclidean. That has nothing to do with cardinality. "size" is a vague word, and just as we would never say "amount" when referring to chemistry if we were being precise, you need to distinguish between the suggestive descriptions offered as an aid to understanding and the formal rigorous definitions that are used when we come to practise mathematics.
I have found this thread https://www.physicsforums.com/showthread.php?p=228438#post228438 .
Please can someone lock this? Don't suppose he's on a static IP is he?
Can you explain f(x) = (1 - 2x) / (x (1 - x))?
What do you mean "explain" it? It's a rational function defined for all real numbers except and 1. It has vertical asymptotes at x= 0 and x= 1 and a horizontal asymptote y= 0. What more do you want to know about it?
This function maps from the interval (0, 1) onto the entire real line.
But it is not explain how it can be done if the real line has no fractal structure (self similarity over scales).
So, where can I find a mathematical theory that explains why it can be done?
'it' needs to be defined before we can explain 'it'
Please give this definition.
erm, it's your 'it' that you need to define. because your post appears to say that there can be no bijection from (0,1) to R because we don't take into account the 'fractal' nature of it, which is obviously garbage. so what then is the 'it' we need to explain to you?
Matt Grime said:
...which is obviously garbage...
By what knowledge do you come to that conclusion?
Pease share it with us.
because without needing to define 'fractal' the function tan(x) takes the interval (-pi/2,pi/2) bijectively onto R. that is why we can conclude constructively that it was garbage. That is in addition to the example you failed to understand when posted by HallsofIvy earlier in the thread. Do you ever read and understand the response people bother to give?
If we can define the same magnutide among infinitaly many different intervals why can't we conclude that there is a self-similarity between these intervals?
Because the fact that you can find a bijection between different intervals only proves that you can find a bijection between different intervals. You can't just assume that the intervals must also have other similarities if they have one.
And as proof of that, the Koch snowflake of fractal dimension log2/log3, I think, is in bijection with the real line. The unit sqaure is in bijection with the unit interval as is the Cantor set. So, erm, there you go, again.
Please show me where I say that there is more then one self similarity over-scales to the real-line?
A one self-similarity over scales, this is exactly the definition of a fractal (and Cantor's set http://mathworld.wolfram.com/CantorSet.html proves it Matt).
In short the real-line is a fractal because any unique "fixed place" R member is also used as a global scale factor on the entire real line, as we can see here:
http://www.geocities.com/complementarytheory/Real-Line.pdf
Why are you all against this idea?
eh? what has that to do with the disproof of your assertion that because there is a bijection there must be a fractal nature to it and self similarity over scales, whatever that might mean? bijections have no properties that imply they preserve fractality, for want of a better word. indeed the counter examples i gave you seem to ignore, again, why do you always do that? The cantor set and the real line are in bijective correspondence, as is the power set of the integers and the koch snowflake, and there is no fractal link there between those things is there? they don't all have the same fractal dimension, one isn't even a fractal.
because it's ill thought out, poorly presented, badly explained, uses mathematics wrongly, indeed it is wrong to say that the existence of a bijection must be to do with the fractal nature of the real line, and because, quite frankly, it's you, and your reputation precedes you.
no one would argue against R being a fractal, with fractal dimension 1. People will, have, argued that because R and (0,1) are in bijective correspsondence does not tell you anything about the self similarity of (0,1). the real line and the parabola y=x^2 are in bijective correspondence, and the parabola is not self similar.
I am not talking about some spesific fractal dimension of the real-line, but on the general principle that the real-line is THE "ULTIMATIVE" FRACTAL of any existing fractal including fractal dimension 1.
  • #31
what does it mean to say: "is the fractal of any existing fractal"?
"the" indicates uniqueness, in what sense is the choice of R canonical and unique? For that matter, what things are even allowed to be 'the fractal of any existing fractal'?
  • #32
  • #33
Shemesh said:
If any local R member is also a global scale factor of the entire real-line and this duality defines R members, then the real-line is a fractal
Please show me what is wrong here?
1. you begin with an if for a start, and don't prove that it is a non-vacuous case, but that could be hard because:
2. none of those terms are extant, ie known, or if they are you are using them in a way that is not understood by anyone else
words that need explanation:
local, member (but we presume you mean element), global, scale, factor, duality, fractal (you would need to prove that this statement is equiavalent to the statement R is a fractal)
  • #34
  • #35
matt,
you have more patience than Windows has bugs.
No, maybe not...but you come close.
  • #36
An explanation of Vacuous Truth can be found here: http://en.wikipedia.org/wiki/Vacuously_true#Vacuous_truths_in_mathematics
If you look at http://www.geocities.com/complementarytheory/Real-Line.pdf , you can see that by this model any member (or element) of R set can be simultaneously in both states:
1) As some unique number of the real line (a unique member of R set)
2) As a global scale factor on the entire real-line, which its product is the entire real-line included in itself according to this global scale.
There is no process here but a simultaneous existence of R set on infinitely many unique scale levels of itself.
Because of this self-similarity over scales, we can understand why some segment of the real line can have the magnitude of the entire real-line.
Please understand that we are not talking about some shape of a fractal, but on the infinitely many levels of non-empty elements, which are included in R set.
It is important to stress that there is one and only one magnitude to the real line, which is not affected by its fractal nature.
Any comments?
  • #37
if we take just positive real numbers, the same is true of the right half of the parabola y=x*x, as it is of the tan curve in its principal region. neither is a fractal. or have you just redefind fractal to suit your purposes?
  • #38
You do not understand my argument.
I am not talking about the proprty of some function but on the way of how the magnitude of its elements can be the same in any sub-collection of it.
The fractal nature of the magnitude of R collection do not care about the "character" of any function that has the magnitude of R collection.
For example, take any segment of your non-fractal parabola, and the magnitude remains the same.
By using the word "fractal" I mean self-similarity of the magnitude that can be found in any sub-collection of your function.
  • #39
so fractals have nothing to do with it at all? why am i not even moderately surprised?
  • #40
Matt, self-similarity of some property (and in this case the magnitude of R collection) which can be found in any arbitrary sub-part of the examined system (and in this case the system is the real-line) is nothing but a fractal, got it?
  • #41
so something is a fractal in your new sense if there is a bijection to some proper subset of it? that would be dedekind infinite then, wouldn't it?
  • #42
bijection to some proper subset of it is the clearest sign that we have here a fractal.
I think Cantor also used this property.
  • #43
no, it is just dedekind infinite. it doesn't seem reasonable to say it is therefore a fractal, unless you want to redefine the word fractal to mean dedekind infinite, which is what you're are saying
  • #44
Dedekind used this property, but he did not know that it is actually the property of a fractal.
Cantor defined the Cantor set, but he did not know that it is a fractal.
Chaos theory was developed after their time.
(Also please pay attantion that our standard place value representation method is also a fractal and also surreal numbers)
  • #45
"it is actually the property of a fractal" oh, that makes it all so much clearer...
  • #46
When a collection of elements refers to itself, you can get a fractal.
  • #47
Shemesh, where is that all going? So what if the real line can be represented in different scales.It doesn't mean that you will find "new" properties. If a property of fractals appears with some representations doesn't mean that the real line will have all of the properties of fractals.
  • #48
This isn't going anywhere. This is just an attempt to change to meaning of the word fractal to something general and vague for no reason.
If someone was interested in trying to describe a new or interesting idea, they would use the existing terms with their existing definitions instead wasting all their time redefining things so that nobody can understand what they're talking about.
